It's My Party and I'll Complain If I Want To Complaint Thread
13940424445100
  • XyetztXyetzt Posts: 27,555
    kyoto kid said:
    Glad the same people don't set fuel volume standards for aeroplanes.
    Here, avgas is dispensed in litres, but consumption is monitored in US Gallons/hour. Jet-A is dispensed in kilograms OR lbs, but monitored in lbs/hour. Planes HAVE crashed cos the pilot orderd xxx lbs, thinking he was getting kgs . . .
    Oh plane food?
    food for planes. :) 100LL (100 octane low lead) aka avgas for piston engines. A few engines are rated to run on regular car fuel (aka mogas), but these days it's often cut with too much ethanol. Jet-A, is kerosene based fuel for jet engines, turbines and diesels.
  • SummerhorseSummerhorse Posts: 684
    They don't have a gage to check and see if the tank is full before they leave??? Or from the brief glimpse I 've had of a jet's cockpit, there are too many dang gages to keep track of...?
    Totally naive here, but it seems like checking if the fuel tank is full would be right up there on top of the things to do before I take off list.
    looking at food pictures isnt sugar overload, is it?
  • carrie58carrie58 Posts: 4,175
    Complaint : How come the slicer thing that is suppose to HELP you evenly slice things  DOESN'T ...... ended up having to hand slice a bag of apples to dehydrate ......want apple chips
    What happened to Antonia Polygon?  What about Decoco?
    I have often thought about investing in one of those dehydrators,  do they work well?
  • kyoto kidkyoto kid Posts: 42,436
    edited July 2018
    ....this happened in the 1980s with an Air Canada 767 where an improper conversion rate (to Imperial Gallons instead of KG) was used. Thus when the aircraft was refuelled in Montreal only about 5,000 litres instead of 20,000 was added for the trip to Edmonton giving the aircraft only about half the fuel load it needed.  Air Canada's 767s were the first aircraft the airline received which had their fuel calibrated in Kilograms instead of Imperial Gallons/Pounds. Further complicating the situation was a glitch in the new aircraft's fuel quantity indicators where often times on the panel it would read empty even if the aircraft was fully fuelled. To counter this a floatstick measurement was taken at the airport before departure. to determine the fuel load and the aircraft had to released by the chief maintenance officer before departing  This is where the calibration mixup occurred.
    As the aircraft passed over Winnepeg the first engine failed at cruise altitude the second shortly there after as the captain was descending. Effectively it became little more than a giant glider.  The pilots skillfully set the aircraft down at an abandoned RCAF airbase totally "deadstick" (no power) with no major injuries to passengers or crew and only minor damage to the aircraft when the nose gear collapsed on touchdown (which actually helped slow it down as without engines, there were no thrust reversers).
    Post edited by kyoto kid on
    I am angry.  I set up a ride to go to a mandatory meeting and the ride never came.  Hopefully I will not get fired because of this.  I have no way to get to the work meeting now.
    Seems very strange to set up a mandatory meeting on a Sunday evening.
    edited July 2018
    I think that they do,I've made dried onions ,and then dried the apple slices and dehydrate potato slices ,I find they keep better dried out too I do admit I've had the dehydrator for 10 years and have only used it a dozen times
    Post edited by carrie58 on
    is there a gizmo to pit cherries?
    is cherry season have 2 lbs of cherry,  thinkin be yummi to stirthem into yugurt,
  • Charlie JudgeCharlie Judge Posts: 13,635
    Antonia Polygon: https://adh3d.com/antonia.html
    and Decoco is available via the Wayback machine: https://web.archive.org/web/20161125024925/http://members3.jcom.home.ne.jp:80/mowais/freestuff/freestuff.html
    apollo maximes?smiley
    edited July 2018
    Probably if you check Amazon ....  here ....      https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=Cherry+pitter&rh=i:aps,k:Cherry+pitter
    Hopefully you can give your HR  or manager the name of the company you set up the ride with.
    tysmiley
    oh dear, 1 packet of instant grits = 310mg sodium, i always eat 2 at a sitting. >.<
    last week i ate 4 packets in 1 day
    threw out all soup cans from the cupboard.  is all death by sodium.  even the 'low sodium' ones
    I do not want to go to bed, but I must.
    edited July 2018
    what would be the scifi equivalent of the banana in the tail pipe trick?
    lol
    Post edited by Mistara on
    edited July 2018
    Mistara said:
    tysmiley
    Yeah unfortunately the majority of the premade stuff is loaded with salt to make it taste edible ........at least once a month I make my own big pot of soup , and freeze it into 1 and a half cup serveings to eat later and use different spices such as ginger and cayenne  pepper ,(just a touch not enough to burn ) or Mrs. Dash , for seasoning
    carrie58 said:
    Mistara said:
    tysmiley
    sounds like good idea
    Ready for a Monday
    810 x 960 - 65K
  • DanaTADanaTA Posts: 13,412
    It's Darth Kitty!   laugh
    Dana
    Darth Kitty looks annoyed
    ...If you only knew the power of the catnip.
    my pc club expiried
    sipping pedialyte.  yumm electrolytes
    goin to play pool noodles today.
    edited July 2018
    Yep, he's still available too: https://adh3d.com/apollo.html
    and here, also, are some subsections with accessories for him: https://poserdazfreebies.miraheze.org/wiki/Apollo_Maximus
    You can get the password to unzip the figure files at the bottom of this page: http://web.archive.org/web/20150406093853/http://www.antonkisieldesigns.com/~akfiles/htmlpages/ApolloMaximusFree3dhumanfigure.htm
    See also this thread: https://www.daz3d.com/forums/discussion/19765/apollo-maximus-is-back-the-optimal-3d-figure-working-download/p1
    Post edited by Charlie Judge on
    I do not know if I work or not today.  I also feel sick.
    It looks like they do not need me.  Might be good as well since I feel sick.
    Feel better soon!
    Dana
