?? Philemo plugin dynamic hair to mesh ??
124»
  • PhilWPhilW Posts: 5,162
    There are a selection of glossy settings to add more shine if required. A lot of it can also depend (as with most things) on the lighting as well. Very diffuse lighting will not give specific highlights while strong direct lights will.
  • HeadwaxHeadwax Posts: 10,524
    edited June 2018
    beaut hair!!
    @PhilW trick is to add a bone to the object before exporting the obj
    except I note the poly count is different (simple sphere was test obj)
    edit i reran test again
    this time I centred bone and object before attaching skeleton
    I attached bone before making my morph (previpusly I added a morph before boning object)
    I then exported with all first four options ticked (in export window)
    when I bring morphed obj back it has correct number of polys
     I assume attach bone before making  morph was the winner step
    Post edited by Headwax on
    HW - thanks. Ill have to try that and see if that works out.
    good luck - please see my edit to above comment
