Lashes Utilities for Genesis 2, 3 and 8 [Commercial]
13»
  • RAMWolffRAMWolff Posts: 10,393
    Hi Hellboy, Great product. Did you ever get any feedback from DAZ about the MR possibility of this product?
    Thank you!
    Richard
  • kadaj777kadaj777 Posts: 126
    Thank you!
    Richard
    I'm about to wake this thread back from the dead!
    I'm also here asking about it being a Merchant resource. I'm currently making a Male character and I need lashes for him.
    I have lash Master for Genesis 8 female and I've tried to convert it to him, but the lashes distort.
    Hellboy said:
    I´m sorry for not being more present in the thread, things went nuts at home just during the release, but everything´s in order now :)
    Mattymanx, I saw your PM, glad you figured it out. One of the issues between genereations I guess :P
    As a vendor, all things MR are extra shiny for me too! So I understand the need for buying products as investment. I would like this to be MR. Actually that was my initial idea for my products under the "Utilities" name, But  I wasn´t sure how to deal with the fact that these are geometry and the adittional steps to rig them, which could be confusing for the vendor. It´s not a regular rigging to avoid distortions, because fiber lashes are very delicate in such a complicated area and they esily distort in a normal rigging. I guess I could leave instructions for that despite the vendor will surely understand just by looking at how they are made.
    I will take a look at similar MR products like the one Phoenix1966 referenced and consult with DAZ, I would be happy to update the product description and let you know if I get a good way to do it! :D
    Thank you very much for the comments and interest, I appreciate it a lot! heart
    You've mentioned that you didn't know how the vendor would be able to rig the lashes. The lashes I use for my characters are fibermesh and I know how to fit them to the figure by the Tutorial that is provided by the Lash Master  Vendor. I think you could do the same with these wonderful lashes you created.
    Here's the Tut for reference: docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/58721/58721_lash-master-merchant-information.pdf
    Thanks!
  • lachilachi Posts: 102
    edited April 2023
    I need help with the male version of this product.
    Apparently there is a bug in the male version because it does not behave correctly when used together with Camera Magic.
    Camera Magic should be able to remember visibility, position, rotation and shapes of a product and it is working fine with the female version of the lashes.
    But when I use Camera Magic on a G8M or G8.1M having lashes, the lashes will be totally distorted.
    I looked at the bones and it seems as if all the bones are not aligned with the bones of the character.
    How can I fix this? How can I re-align the bones of this product with the actual bones of the G8M or G8.1M?
    Post edited by lachi on
  • I know that this is thread for the older product but I could not find a thread for "Lashes Utilities Merchant Resource for Genesis 9" which I just bought today.
    It works great for scene characters, BUT.....................
    Has anyone gotten the G9 version to work as a merchant resource?
    I have followed the directions as best as I could but could not get it to work. The directions aren`t as specific as to make it easy for me to follow. I mean I`ve used Chevybabe25`s Lash Master to create lashes following her detailed merchant resource instruction and got it in the first shot. I even did her Beautiful Brows with no problem.  Her very detailed step by steps and images are exactly what I needed.
    These are the instructions and what I did to follow them.
    1) After shaping lashes as desired, export them as OBJ as base resolution. - Export what? Both the Lashes Utility Genesis 9 root and Lashes Utility Genesis 9 or just Lashes Utility Genesis 9? The no merchant resource instructions say not to mess with Lashes Utilities Genesis 9 Root. (I`ve tried both ways)
    2) Import back the OBJ and use the transfer to rig it to Lashes Utility Genesis 9 Root (not directly to Genesis 9) - I clicked on import, then in the Source window I selected Lashes Utility Genesis 9 Root. And in the Target window I selected the renamed Lashes Utility Genesis 9 OBJ file that I imported. I clecked accept.
    3) Convert to SubD.- OK now there are more files.... Lashes Utilities Genesis 9 parented under Lashes Utilities Genesis 9 Root,  Lashes Utilities Genesis 9 Obj, and Lashes Utilities Genesis 9 not parented to anything. Which to I convert to SubD? (I tried multiple combinations).
    4) Change the material. OK? I guess on the thing I just converted to SubD right? LOL
    5) Save both your customized lashes and the root to your product folder as Figure/Prop Assets. - I did that in multiple combinations.
    6. Make sure to delete morph dials of Lashes Utilities Genesis 9 Root from your final product - Did not get this far as the prop did not fit.
    7) With the pieces properly conformed, select Genesis 9 and save as a Wearable Preset. - Did not comform properly.
    Have I missed anything or did something wrong?
    As stated, I tried multiple combinations multiple times.
    Any help would be appreciated :)
    Thank you
