Carrara Challenge #40 NOIR WIP - A warm welcome to our PA sponsor, Fenric
1…34689…15
    Lego noir!! luv it heart
    i was browsing Boris Vallejo art images, it's overriding my regularly sheduled mental rainbows,
    had another look at the samples in 1st post to recalibrate my mind to noir mode.
    fixated a bit on the savage noir image.
  • StezzaStezza Posts: 9,302
    edited May 2018
    gotta love lego... except when you stand on it!
    Holy Bat Blast!
    900 x 675 - 899K
    Post edited by Stezza on
  • VyusurVyusur Posts: 2,235
    edited May 2018
    @DesertDude, great modeling! Although I'm not familiar with this genre, I really like your model.
    Post edited by Vyusur on
    edited May 2018
    Very nice work everybody! I'm still wading through the posts, but there is a lot of great information in there. My first attempt will be a pin-up style render. I have had C8.5, but haven't really worked with the Gen figures or their included textures. I decided to work on that angle and the lighting. Like some people, I found the blinds function under the light gel effect to be problematic for what I wanted to do, so I made my own gel/image map in Affinity Photo. I wanted soft shadows, so I blurred the gel. I wanted the lights to showcase the texture work I did, so the light with the gel is high intensity and set to the rear a bit to highlight the skin surface. I will post my scene and light set-up later.
    I used a knife, because with all that is happening in the world, I am hesitant to glorify guns.
    This is a rare one, in that I used pretty much all pre-made content. However, I did do a lot of texture and lighting work. This is straight out of Carrara with no postwork. I will be doing some on it, to enhance the "nior" feel, although I love the color pop on the reds and the light, so I won't go black and white with this one.
    I do have another idea that will uitilize more original content.
    1500 x 2000 - 3M
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    there's radiators?..... oh yes, there they are devil
    edited March 2021
  • DesertDudeDesertDude Posts: 1,239
    @Vyusur - thank you for the nice words. I'm also not familiar with the genre, but looking at all the examples on the web makes me smile - it seems one can make a caricature of any person, yet still conform to a rigid universal model. Don't know if that makes sense...
    @evilproducer - wow! First, great to see you here, and second, what a great render 'out of the box' Carrara. Hope to see more of what you have in store for us.
    @Selina - thank you, yes something brewing here. Every time I make a quick sketch it looks awful from what I see in my minds eye, so I think I just need to assemble a bunch of assets and move the camera around and relax.
    @Stezza - okay, I give up. :)
    Selina said:
    ..also her makeup was annoying me...
    ..also her makeup was annoying me... cheeky
    Hope you don't mind...
    Selina
    Not at all. Critiques are useful and welcome. In this case though, I'm done with the image except for the postwork I want to do. Using full GI is a rarity for me, and I wanted to see how my computer handled it time wise vs. visual payback. It took awhile to render so I am not inclined to do another of the same subject.
    Next on the agenda is using postwork to grunge up and age the image.
    edited March 2021
  • VarselVarsel Posts: 574
    edited May 2018
    Making a camera-prop.
    Hopefully I will be able to find time to enter in something this time.
    Using my old Minolta camera as a reference.
    800 x 600 - 260K
    800 x 600 - 241K
    800 x 600 - 111K
    800 x 600 - 83K
    800 x 600 - 277K
    Post edited by Varsel on
    edited March 2021
    edited May 2018
    Two variations of my Hero .. wink
    Using GMIC filter Black&White and Pencil.
    800 x 1200 - 755K
    800 x 1200 - 511K
    Selina said:
    ..I'm having too much fun with Procedural shaders that I thought I'd share some with you all...
    By using a pattern in the Translucency channel, I created my lamp shade which will throw the pattern on other objects in the shade from the attached bulb. This scene comprises one cone, one bulb, one sphere and one plane. No Ambient lighting and, although it is not necessary for this test, Indirect lighting to add interest to the sphere as it rolls along... To allow the 'throw pattern', Light through Trans. is also enabled.
    Selina
    NIce. Going back to your method of rendering using absorption to create a black ans white image (overly simplified), have you tried caustics and a red, blue, and green light? If you have three spotlights in exactly the same spot, oriented the exact same way, then set them to pure red, pure blue, and pure green, you will get a white light. Now, shine that light rig through an object with refraction and enable caustics in the render room, and it will split the light into a rainbow, similar to a prism. Use a single white spot, and it will not split. It is not 100% physically accurate, but it simulates it well enough. Do not use gamma correction.
    edited May 2018
    So, here's my lighting and scene set-up:
    I set up my figure first. I will detail the shading work on her in another post.
    I knew I needed a room for reflected light and for reflections. I wanted a room to suggest a faded opulence, like an old building built in an formerly prosperous area or time. But now, fallen into decay, on its way to becoming a ghetto. I kit-bashed the Rural Chateau, and added a couple vertex walls with "windows" because the ones that were included with the set wasn't what I wanted.
    I was having problems getting the blinds I wanted using the effect under the effects tab, so I made my own alternating solid black and solid white bars in Affinity Photo. I then blurred them quite bit so I would have an effect that worked with the light's soft shadows. I tiled it around twenty times.
    I set the brightness of the light very high and placed it at an oblique angle to shine across the skin and highlight the shader work and also the figure's musculature. I shown the light through one of the "windows" so that it was framed. The falloff and the soft shadows help to sell the effect of maybe a garrish neon sigh showing through a window with open blinds.
    I set up another spot light with a cooler blue color as a counter point to the red light. This is supposed to suggest night lighting coming in from another window on the opposit side of the room. I also wanted it framed by one of my "windows." Framing the two lights lke that, also helped me control where and how intense the reflected light from the Indirect lighting would be.
    My next light was basically a fill light and aimed more or less directly at the model. It was set at a much lower intensity than the other lights. It also has a fairly strong distance fall-off. Also, since it is a shape light, I could use distance squared for the falloff.
    My final light is a very low intensity shape light meant to provide a little illumination to the back hallway.
    Indirect Lighting did the rest.
    2142 x 1468 - 317K
    498 x 1094 - 82K
    2810 x 1626 - 514K
    2722 x 1576 - 501K
    2740 x 1564 - 501K
    2672 x 1524 - 495K
    2748 x 1666 - 697K
    500 x 1670 - 170K
    edited May 2018
    So, here's a couple postworked versions.
    The first version is an oversaturated version I wanted to look like an old transfer print.
    The second is an attempt to make it lool like an old tinted photo.
    1500 x 2000 - 609K
    1500 x 2000 - 3M
  • 3DAGE3DAGE Posts: 3,321
    superb work here from everyone,.
    Selina,. glad to see you're getting into shaders,.
    One nice thing that Carrara can do for you.
    ,.. if you make a plane,. create a procedural shader,. apply the shader to the plane and export it as an OBJ,. Carrara can "convert the procedural shader to a texture map".
    just delete the plane.Obj and Mtl files after export,., and drop the exported shader image into your textures library.
    for example,. creating gel's for lights,. like the venician blinds,.
    use a mixer of a scanline or wires,. blended with a Tile (see pic)
    the "curve filter" operator is really useful to clamp the values, or control the repeat of gradients.
    you can use that to adjust the space between the blinds.
    1140 x 610 - 158K
    thanks.  never noticed curve filter before.
    wuh oh entry thread opened.  i bettah get krakken!!
  • DiomedeDiomede Posts: 15,470
    edited May 2018
    Portrait category - how about the femme fatale's ex husband?    - not an entry
    Wanted to try some caustics with the glass, liquid, and ice cubes.  G2M with Air Defender turtleneck and jacket.
    Hair modeled in the dynamic hair modeler on a custom hair cap.   Cigarette and other props modeled in the vertex modeler.
    B&W is a result of the GMIC film filter, using the Kodak TMax 3200 preset.
    Some postwork in Photoshop elements to reduce brightness and increase contrast, which I guess could also have been done with GMIC filters.
    My cable TV and internet service is knocked out, so I have to go out to get internet access until it gets fixed.  Holiday here in the States so no luck scheduling an appointment.
    Worst customer service, ever!  They actually hung up on me.  No, I was not ranting or otherwise rude when it happened.
    Simple 3 point lighting setup.
    800 x 1067 - 205K
    1383 x 936 - 117K
    Post edited by Diomede on
    wip 1
    the charmed hair went on Janette like a charm.
    heaven sent projected no fuss, but then i havent activated any body morphs
    next steps
    try to simulate a breeze on the hair
    do a gel i'm happy with
    mebbe add a couple Aikos
    fix the ground
    eek almost 1am, shoulda been asleep an hour ago  doh
    1550 x 875 - 188K
    650 x 500 - 490K
    edited May 2018
    @Varsel that looks pretty cool - both of them yes
    EP great wips ... great radiators wink
    @selina c'mon.... catch up .. great animation examples.. @diomede that's one creepy looking dude!
    Misty... this is coming along nicely.. I like your thought processes.
    Card Shark
    used gels, replicators for the munnies the building render from earlier images.. recycling smiley
    and Ron's brushes.
    800 x 600 - 482K
    @Mistara, nice picture! Your girl reminds me of Mylene Farmer.
    edited March 2021
  • Bunyip02Bunyip02 Posts: 9,345
    edited May 2018
    Excellent work by everyone !!!!!!
    Homage to Blade Runner
    Carrara setup
    Raw render
    Post work
    2276 x 1040 - 736K
    2800 x 1570 - 2M
    Post edited by Bunyip02 on
    edited March 2021
    @Bunyip02, very touching picture, and characters are with obvious likeness. The only thing I lack in your picture is a bright dramatic rim light (with soft shadows of course).
    @Bunyip02, are you using shadow buffers on your lights or maybe less than 100% shadow intensity? I like the concept, it is pretty cool. Blade Runner is the perfect mix of sci-fi and nior. To me, the lighting is flat and the open mouth on the Rutger Hauer inspired character looks like his mouth is lit from within- a telltale  sign of using a shadow buffer. Take a look at the picture of Rutger Hauer you posted, and you will see a rim light on the right side of his head, and a light source coming in from the left that illuminates maybe 3/4 of his face. The rest is in deep shadows. Keep in mind the scene layout you have is different, so what works for the reference image may not work for yours. The idea though, is to provide seperation from the background.
    edited May 2018
    Not much time tonight. I have to go to a meeting with my theatre group to plan a theatre workshop at one of our local libraries later in the month.
    So, I have an idea for a secon scene. I don't know what category this will fall into yet. I just know I have a vision in my mind. To start, I am in the process of lighting up a vintage roadster. I only really have just the car lights at this point.
    1280 x 720 - 259K
    4020 x 1880 - 1M
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Gosh, I'm getting behind.  But that's a good thing when its caused by a surge of interesting renders.
    DesertDude and Selina, thank you for the nice comments on Thug Wars!  There is a final version which I haven't posted yet.
    These are great buildings!
    Stezza said:
    Now that's one creative batmobile. :)
     Great tips and render, EP!  Thanks for joining in.
    Selina said:
    Your experiments are always impressive, Selina, and this is no exception.  So, now it's time to get busy on an entry.  smiley
    Varsel said:
    Looking good, Varsel.  I wish I could see the hat better, and see everything else darker.  Have you experimented with the basic controls (contrast, etc) in GMIC?  Stacking filters is such fun. :)
    edited May 2018
    More work with lighting and atmosphere. I used light linking to enhance the rim light effect. Lots more work to do on skin and other textures. I have an idea I want to try, but I'll wait until I see if it works before I mention it.
    Low anti aliasing and resolution test render.
    1280 x 720 - 848K
