GMIC - new plugin available now for Windows
124»
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
  • UnifiedBrainUnifiedBrain Posts: 3,588
    edited May 2018
    Selina said:
    ..Finally:
    • Collages - Instant collage pro - crashes
    • Collages - Negative collage color - crashes
    • Collages - Negative collage new - crashes
    • Collages - Negative collage old - crashes
    • Collages - PictureFX collage - crashes
    • Collages - Print films collage - crashes
    • Collages - Slide collage color - crashes
    All work fine on my PC.  By that I mean there is a definite effect and it has parameters that I can alter.
    I have no clue what a lot of these GMIC filters are supposed to do, however.  Some are very complicated, and you need to spend a LOT of time exploring to understand.  There are some online tutorials, but you have to look for them.
    Post edited by UnifiedBrain on
    edited March 2021
    edited May 2018
    Selina said:
    Can you post the B&W colorize line art result (before and after) is it greyscale or patches of desaturated colour?
    It is not greyscale.  It is similar to what Diomede posted.
    Based on playing with it a few minutes, it is not a filter I would likely use.  Considering that there must be at least 200 filters (with some filters having over 10 parameters), it is not a big loss. :)
  • DiomedeDiomede Posts: 15,401
    edited May 2018
    I admit I don't know what most of these filters are supposed to do.  I tested them in two groups.  Here is group 1, which are the ones which Selina reported had no effect.  For these, I did a test render with a render pass for post effect.  In each, the post effect appears to be flat black, which I presume means no effect.  Here is the list again.
    Lights & shadows - Drop shadw 3d not working correctly for me, nor
    Lights & shadows - Equalize shadow, nor
    Lights & shadows - Slice luminosity
    And I am attaching an example of a test render and the post effect render pass.
    800 x 600 - 23K
    800 x 600 - 8K
    Post edited by Diomede on
    The second group was the collages which Selina reported caused crashes.  I did a similar test, with a test render for each and a post effect render pass.  In each of these cases, I was able to render without a crash, and the render pass included non-black information, which I presume means it did something.
    And again I am attaching one example of a test render and its render pass.  This image was done with the table setting.
    800 x 600 - 64K
    800 x 600 - 79K
    And this was done with the layers setting.
    800 x 600 - 21K
    800 x 600 - 23K
    Selina said:
    I forgot to add:
    • Rendering - 3d random objects also doesn't seem to be working correctly for me
    Did you turn up the opacity slider at the bottom?  Default is set to zero.
    I'm glad Selina brought this one up.  You results, and some of my results with the layers setting, turned out pretty cool.
    edited March 2021
    edited March 2021
    edited March 2021
    edited March 2021
    edited March 2021
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    Film emulation requires writing privileges in the GMIC subdirectory. Could you check whether this directory has writing authorisation for your user. Default is no because it's a subdirectory of the program files directory and is restricted to the admin user.
    edited March 2021
    Selina said:
    Some plugins work and others not in the Film emulation category - I have access - but just to check I'm going to run Carrara as an administrator just to check.
    Films are stored in an archive file and extracted if needed. Some where already extracted in the distribution and that's why they could work while other don't.
    edited March 2021
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,465
    edited May 2018
    I cannot see any difference with those either and get a black image too for the first
    everything else seems to work except preview
    I need to go to the render room everytime
    or rather preview in the plugin, I can spot render in assemble room
    You can check the original effect with this link https://gmicol.greyc.fr/
    Drop shadow 3d indeed requires an alpha channel that is not in place.
    Equalize shadow doesn't do much (if anything) in the original.
    I'll check for the chromatic aberation.and the slice luminosity.
    edited March 2021
    edited March 2021
    I hadn't forgotten. It was just on my (too long) todo list.
    Chromatic aberration won't work. It uses an operator not working in the current implementation.
    Slice luminosity works in "mask" or "mask+background" preview mode . It won't work with "image" or "image+background" mode for the same reason as chromatic aberration.
    I know I have to update to the latest version of GMIC which is supposed to solve some of those operator issue, but it's even further on my to list sad
    edited March 2021
