FLUIDOS plugin for Carrara -- version 1.4 update
1131416181926
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
  • AlbertoAlberto Posts: 1,458
    Selina said:
    Hola Alberto,
    Que buena noticia... gracias por todo su trabajo duro y la nueva versión de Fluidos, ¡me lo encanta muchisima!
    Selina heart
    ¡Gracias a usted!
  • 3drendero3drendero Posts: 2,029
    Thanks Alberto.
    News post at CarraraCafe is also updated now:
    http://carraracafe.com/news/the-fluid-sim-plugin-for-carrara-fluidos-1-01-is-released/
  • 3DAGE3DAGE Posts: 3,315
    Thank you Alberto :)
    Much appreciated
  • DUDUDUDU Posts: 1,945
    Thank you Alberto!
    In spite of the fact that I usually use Realflow, your plugin takes more and more place in my workflow.
    I will devote my day of tomorrow to this new version.
    My long project of animation already used it some times.
    Thanks again!
  • 0oseven0oseven Posts: 626
    Hi Alberto
    Reference your advice    'Maybe an OpenCL CPU-only Runtime Package can help you: https://software.intel.com/en-us/articles/opencl-drivers#latest_CPU_runtime.'
    I installed this [which required me to uninstall Intel graphic drivers ]  and during installation a message said I already had an old version of OPEN CL.installed ! Anyway proceeded and now have an updated version but BAD NEWS fluidos still does not load the fluidsim.dll file
    Using the latest version of Fluidos I tried both CPU and GPU setting in your plugin options.  Should I buy a new computer ?devil
    Maybe, but in the meantime, read the PM I sent you.smiley
    3drendero said:
    Thanks Alberto.
    Thank you!
    Much appreciated
    DUDU said:
    Thank you Alberto!
    Thanks again!
    You're welcome. I hope Carrara stays alive and growing.
  • ImagoImago Posts: 5,687
    edited April 2018
    Considering you gave at least 5 extra years of life to Carrara... laugh
    Post edited by Imago on
    No message in INBOX  crying- definitely need a new computer ha ha !!
    I'm afraid so... sad
    Try this:
    https://drive.google.com/open?id=1cUJBEOz4JyjBDWHKq3pjAnL7Sc40VnE6
    It's a fluidsim.dll with no OpenCL at all. It not depends on installed OpenCL. It's a little slower, however.
    Decompress and overwrite the fliudsim.dll of the new Fluidos version.
    All references to openCL in fluid domain properties will be ignored.
    I hope so !
    Alberto -
    I'm dissapointed to tell you the NON openCL version did not work.  I am really appreciative of your effort  to solve my problem . There must be domething in my system stopping the sim running - But What ?
      I dont wish to take up more of your time on this but will attach a few screen shots . There was an addtional message when running the latest  Fluidsim and some information about my system.
    Someone made a suggestion concerning the 'signing ' of .dll files - I looked on the internet for this but couldn't find anything useful - seemed to be advice for developers ?
    Once again thanks to you and those who have tried to help.
    529 x 718 - 64K
    511 x 724 - 86K
    525 x 760 - 70K
    1141 x 780 - 118K
    1138 x 752 - 119K
    1064 x 815 - 118K
    edited March 2021
    Selina said:
    0oseven,
    I presume you have installed Carrara into a different folder than normal, namely Programs 3D ?
    If so, try this:
    1. Type cmd in the run box or find comand prompt in your windows program menu; right click it and run as Administrator
    2. When cmd opens type the following: regsvr32 C:\Programs 3D\DAZ 3D\Carrara8.5\Extensions\fluidsim.dll press return
    This will register the dll with Windows, then you can try Fuidos again.   Hope that helps,  ​Selina
    Thanks for repone Salina - unfortunately didn't work as per attached images of respsonses.
    First I accessed cmd from desktop which opens with Path prefix Users/mike.
    Then I dived into windows system and ran it from there path C:   ........ with similar result.
    Did I paste in the correct path detail ?  Do the screen shots give any clues ?
    906 x 628 - 81K
    851 x 565 - 71K
    0oseven said:
    Alberto -
    The enabled or disabled checbox in the no OpenCL version doesn't matter, it is ignored.
    Then the problem is other dependency, no OpenCL itself.
    Did you use the Dependency walker at http://www.dependencywalker.com/?, it can say why your computer can load the dll. It seems it's missed other .dll that is needed for fluidsim.dll.
    This is the screen of dependency walker for the fluidsim.dll with no OpenCL
    This is with the OpenCL fluidsim.dll
    It is marking errors for the OpenCL.dll (although in this case, it's an exaggeration of the Dependency Walker, because OpenCL is working well in this machine).
    Maybe we can find the problem.
    1323 x 760 - 104K
    1323 x 760 - 101K
    Thank you Alberto I will try 'dependency walker ' and persue this as long as you have time to support my attempts. One day this might all be very useful to someone else !
    edited March 2021
    FLUIDOS - Now with Viscosity...
    What follows is a series of tests to show the values involved in getting good results with Fluidos - Thanks to Alberto for all his hard work!
    Key to general info:
    1. CS: - Cell Size
    2. LS: - Level of Subdivision
    3. FC: - Force
    4. VT: - Viscosity
    5. HP: - Higher Precision
    CS: 0.500
    LS: 2
    FC: -32z
    VT: 0.00
    HP: No
    CS: 0.500
    LS: 2
    FC: -32z
    VT: 0.10
    HP: Yes
    CS: 0.500
    LS: 2
    FC: -32z
    VT: 0.50
    HP: Yes
    CS: 0.500
    LS: 2
    FC: -32z
    VT: 0.50 animated to 1.00
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -32z
    VT: 0.01
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -32z
    VT: 0.10
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -32z
    VT: 1.00
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -32z
    VT: 2.00
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -64z
    VT: 2.00
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -64z
    VT: 4.00
    HP: Yes
    CS: 0.250
    LS: 2
    FC: -64z
    VT: 25.00
    HP: No
    CS: 0.250
    LS: 2
    FC: -64z
    VT: 100.00
    HP: No
    Also, you may or may not realise the potential but here's a short video where I exported the fluidos shape and created a new show for the camera to pan around it - great for modelling liquids don't you think?
    Happy Fluidosing!
    Selina
  • CelluloCellulo Posts: 64
    edited May 2018
    Thanks Selina for the tests and settings values, this give a good idea before made something in Fluidos and thanks to Alberto for the update.
    Post edited by Cellulo on
  • PhilWPhilW Posts: 5,162
    Selina - that video is so cool! I love the freezing time element!
    Very nice, Selina! laugh
    You put the Cell Size... What about the Domain size? Which Magnitude you used on them? I want to reproduce them in my Carrara!
  • DiomedeDiomede Posts: 15,401
    @Selina - thank you so much for posing these tests and results.
  • mindsongmindsong Posts: 1,745
    way cool!
    both the tool and the test-runs! brilliant presentation, thanks!
    --ms
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Selina, maybe I am easily blown away by geek magic, but your computer presentation skills are just amazing.
    You're hired!
    Amazing, Selina!
    What a beautiful and precise presentation !
    edited March 2021
    edited March 2021
    edited March 2021
    Selina said:
    @Imago
    Here's the missing parameters for you to emulate my experiments below. Sorry for the earlier omission:
    Fluid Source:
    • Activate: Yes
    • Velocity: 10.00x
    • Expand: 100%
    • Size: 6.00cm³
    • Cuboid: Yes
    Fluid Domain:
    • Size: 50.00cm³
    Selina
    Thanks, Selina! wink
