can I put a Victoria 7 on Genisis 8 female?
in New Users
since she is made for genisis 3 and they say all g3 work on G8, why is this not possible?
the G8 has so many more facial controls.
sad
The skin works on G8, but the morphs, they would need to be converted to G8. There is a thread somewhere in the commons section about this, but not sure were.
I'm trying to find the same information. Search results aren't producing many results. I'd like to transfer my G3 figures to G8. I can do it manually in zbrush, but I'd like to know if there's a utility for DS or some other method that will make it more automated.
There is a whole thread (very long!) about this here: https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8/p1
A forumite called Singular Blues has written a script that will transfer morphs from G3F to G8F (or G3M to G8M) - you can find the post inside that long thread with a link to that script here: https://www.daz3d.com/forums/discussion/comment/2707576/#Comment_2707576
ETA: Note there are some problems/limitation with using this script if you installed morphs via DAZ Connect. Take care about that.
well of course THAT is how I had to install may materials since the DIM kept freezing and wouldn't install.
gees
Thanks for the links MelanieL, much appreciated. I'll read through them and see how it goes.
