can I put a Victoria 7 on Genisis 8 female?
since she is made for genisis 3 and they say all g3 work on G8, why is this not possible?
the G8 has so many more facial controls.
sad
  • BeeMKayBeeMKay Posts: 7,019
    The skin works on G8, but the morphs, they would need to be converted to G8. There is a thread somewhere in the commons section about this, but not sure were.
  • I'm trying to find the same information. Search results aren't producing many results. I'd like to transfer my G3 figures to G8. I can do it manually in zbrush, but I'd like to know if there's a utility for DS or some other method that will make it more automated.
  • MelanieLMelanieL Posts: 7,867
    edited January 2018
    There is a whole thread (very long!) about this here: https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8/p1
    A forumite called Singular Blues has written a script that will transfer morphs from G3F to G8F (or G3M to G8M) - you can find the post inside that long thread with a link to that script here: https://www.daz3d.com/forums/discussion/comment/2707576/#Comment_2707576
    ETA: Note there are some problems/limitation with using this script if you installed morphs via DAZ Connect. Take care about that.
    Post edited by MelanieL on
    well of course THAT is how I had to install may materials since the DIM kept freezing and wouldn't install.
    gees
    Thanks for the links MelanieL, much appreciated. I'll read through them and see how it goes.
