The best way to clear up problems with the CMS is usually to uninstall it from the Start menu in Windows, then reinstall DS4.5 which will install the latest version of CMS as well, and that should cure any problems.
It shouldn't, but I always back them up, just in case. If you're using DS4.5, go to the Content Library, options menu (the rectangle with horizontal lines in the upper corner) > Content DB Maintenance > Export User Data.
You can't, it installs as part of the main application, but, if it is there, the main installer wont replace it, that is why you need to uninstall it first, then when the main DS installer runs, it will install the latest copy of the CMS for you.
What version are you running now? Help > About DAZ Studio.
Are you running AntiVirus software as well? You may need to list CMS as a trusted application or similar. You could try stopping the AV, and seeing if that is the problem, if so, you may be able to sort it out?
Most likely the culprit is a corrupt index. This is fixable without a lot of fuss.
Do do so:
Close DAZ Studio.
Stop the CMS service.
Go to the CMS databases folder.
Rename "ContentDB.ind" to "ContentDB.ind.bak"
Restart the CMS service.
Wait 30 seconds.
Start DAZ Studio. Be *patient*. The index will be rebuilt when DS is launched and will delay the "apparent" startup of DS.
Once DS has finished starting, check things out and make sure things are stable.
By default it is in the ProgramData folder. Go to your "Run line" and enter %ProgramData%. Then look in the DAZ 3D\Content Management Service\databases\ folder.
Okay, about our only hope here is to trace the actual CMS service. Please be very careful.
Go to start > run and enter "services.msc"
In the resultant window find the "DAZ Content Management Service" listing.
Right click and select "Properties"
On the general tab, there should be a listing for "path to executable"
Find that path in Windows Explorer.
In that path is a file named "ContentManagementServer.ini"
Open this file in Notepad.
Look for the line that says "SystemCatalog=" and note the path to the right of the "=" sign. This is where your database resides.
Please post the results of that path here and we can continue.
Not talking about installed, was talking about up and running. Thats' OK though. Just close all copies that are running. Wait 1 minute. Launch DS again (1 copy). Does everything look OK?
That wont erase my categories right?
how do i reinstall CMS service. I just uninstalled it but cant find installer
It's installed when you install DS4.
how do i seperately install it
reinstalled same problem?
What is the exact version of DS4.5 you are using, what OS and version as well please.
Can you also give some info on your machine specs please?
4.5.0.114 OS windows 7 64bit
i5 2500k @3.30ghz
8gb ram
This problem just started recently. Earlier it was working ok
That is a fairly old version by now, the last stable version was 4.5.1.56, and you should try downloading and installing that one.
Make sure that you uninstall the CMS again before installing the main application.
lol how the heck do i download this. When i check out it doesnt give me any download link at all.
Edit: Nevermind got it
Reinstalled it but still same problem
I really need help. Now it stops immediately after few mins i start daz
Its 4.5.1.56
I tried after stopping antivirus but same problem
Do do so:
Close DAZ Studio.
Wait 30 seconds.
Were to find database folder. I searched in program files - daz- content management service
But there doesnt seem to be any databse folder
well i restarted daz but there is no rebuilt.
It would've rebuilt it before the DS interface even appeared.
Let me think for a moment as to how we'll find your database.
Actually it has already created a contentDB.ind after i renamed first one
SystemCatalog=C:\ProgramData\DAZ 3D\Content Management Service\databases
Oh! Okay, that's good.
That means it *IS* in the default location. Did you end up with two copies of DS running?
well in installed programs i only see one daz studio installed
No there is nothing in categoreis and products
Is the service still up and running?
no it doesnt say as started in services
