The Out Of Work & Burnin’ Down The House Complaint Thread.
1235750
  • kyoto kidkyoto kid Posts: 41,943
    edited March 2013
    ..OK hit my first little snag in the Big Install of 2013. Apparently all my Gen3/Gen4 figure, hair, character and older clothing installers are on DVD rather than the HDD or a USB stick.
    So now sitting and waiting while copying all the installer folders over from the DVDs to the desktop so i can install them. Maybe I didn't need that big 32G stick that i got after all.
    Norton on the new system really doesn't like the Base V4 installers because they are so old they have no user history since I copied them from a DVD rather than DL'd them through Norton.
    Also the DIM is totally useless. Seems for it to install any files you first had to use it to DL them. Not going back and DL-ing everything all over again. That would mean drinking waaaaay too much cawfeeee.
    Post edited by kyoto kid on
  • DanaTADanaTA Posts: 13,345
    Or drive you to drink something a bit stronger! :-P
    Dana
    Non-Complaint:
    I got the checkout wizard working! Yay! (only for freebies at the moment, I still have work to do on the PayPal side of things). And...
    the order history and download pages are working, too!
    Dana
    ...when life gives you lemons, throw them back and demand Chocolate!
    [a sig file I saw on another forum site]
    I like it.
    Well, as food I like lemons. As far back as I can remember, I like lemons. When dining out with the big family (not often, but memorable) when I was young, I'd take the lemon wedge they put with drinks (iced tea and such) or with seafood meals, and bite and suck the juice. The adults around the table would make that sour face. It was funny. :-P
    Of course, life lemons are not so much fun or tasty.
    Dana
    DanaTA said:
    Non-Complaint:
    Dana
    ...conga rats.
    Wow really interesting, didn't realize just how much and what I all have until I embarked on this whole thing. Some of the content still has the old "Digital Art Zone labelled installers.
    Just finished installing all the base Gen3/4 models.though can't find the M4 stuff so the H4 base character will not install.
    If they only left the Itemised Order History alone instead of screw it up like they did it would be easy to just reset the DL for the Starter Bundle and re-download it all. With the site set up to work with the DIM the Order History utility no longer works for resetting downloads so I don't even have that back door to use.
    Multi tasking seems to be failing me. Just typed a folder name on the notebook on which I am viewing the forums. Had to find out where it ended up in this post to delete it.
    Kyoto Kid said:
    DanaTA said:
    Non-Complaint:
    Dana
    ...conga rats.
    Thanks!
    Dana
    KK, I just downloaded the newest version of Taosoft's DHM and logged in and selected an item in my history and clicked on the View Order Page button, and it brought the order up in the built-in browser. I searched for an item, clicked the Reset Checked Items button, and then looked in my downloads, and there it was at the top of the list!
    Dana
    (...bugger, mouse is hooked up to the workstation, need to get a second one.)
    That is good to know. When the DIM first surfaced people were having all sorts of trouble with the History Manager.
    Have to DL & Install.
    Doing a test pic just to make sure the paths and my Scenes/Scene Elements folders work.
    So far one casualty, can't find Lantios Lights I or II where they should be.
  • ps1borgps1borg Posts: 12,776
    Rareth said:
    9 hour 4.86 kS/p Luxrender drop
    Awesome, I see the camo as well :)
    Rezca said:
    This started out as a sketch with no real goal in mind at all, and then I started painting and stuff...
    This was the result XD
    Spent about an hour and thirty minutes on the picture, and tried some things I've never tried before ^_^
    Hey great, lovely delicate colours :)
    Kyoto Kid said:
    ps1borg said:
    DanaTA said:
    Kyoto Kid said:
    ...not sure if Studio supports a "swap drive". I know Carrara does. Also again to use a Swap drive you need XP Pro, My old system only has XP Media Edition (which is basically XP Home with a few extras for media apps like Windows Media Player) so it does not support swap drives at all.
    My notebook has 4G of DDR2 PC 667 in Dual channel mode so it's even slower. In comparison my workstation is DDR3 PC 1333 configured in Tri Channel mode
    Anyway while a swap drive will give you more memory "overhead" against crashes, it is even slower than your on board RAM because of the port speed.
    As your XP Pro is 32 bit, the most memory it can support for any single application is 3G with the "3GB switch" (that needs to be set in your INI). Any additional memory whether on a card or USB stick will offer no additional benefit.
    I meant for the OS, not for DS or other appliations. And I never thought of it for XP, I know the limit is 3Gigs. I thought that having the extra RAM, even if it is external, would be better than not having it. And better than virtual memory on a hard drive. Surely USB3 is faster than that. And some of the newer SD memory cards are high capacity and high speed. I was only curious, as I have no money for upgrading to Windows 7 anyway.
    Carrara Pro 7 at least can also use multiple PCs as a render farm. I forget how many it can be without getting an add-on (I think it's called The Grid). My desktop computer is the fastest in the house anyway, including a gigabit ethernet. But of course, I've never done anything with Carrara yet.
    Dana
    Did some of my best work on 32 bit platforms :)
    ...same here until the apps and content became too robust to support anymore. This is still is my all time fave.
    Yes it looks great :)
    Talk softly and carry a big gun drop :lol:
    1500 x 628 - 80K
    edited March 2013
    ..OK found another issue. For some reason it keeps trying to save scenes to the Root (Computer) instead of the Scenes/Scene Subsets folder even though I manually direct the file there on saving.
    Also found that Lantios Lights ended up in the "Other Import Formats" path in the content library tab and nothing shows in the icon pane below. That is a bit odd as I used the same installation path I have been using for all the older content that goes into the 3Advanced content runtime.
    Looks like I'll be on the N & B forums for a while tomorrow.
    Well late and getting tired, tomorrow's another day.
    BTW nice pic there.
    Very nice!
    Dana
  • TJohnTJohn Posts: 11,340
    Standoff! Nice scene, :)
    OK now all I can think about is a big gumdrop. And a plethora of gumdrops. :lol:
    550 x 365 - 52K
    554 x 552 - 160K
  • SkirikiSkiriki Posts: 4,976
    NON-COMPLAINT!
    I AM NOW MARRIED! WOO!
  • RezcaRezca Posts: 3,393
    Crawly critters from Finland Winterland?
    http://eurwentala.deviantart.com/art/Winter-Critters-360538230
    600 x 1873 - 253K
  • WoolyloachWoolyloach Posts: 0
    Skiriki said:
    NON-COMPLAINT!
    CCCCCCCOOOOOOOOONNGGGGGGRRRRAAAAAAATTSSSSSSSS!!!! :coolsmile: :coolsmile:
    Skiriki said:
    NON-COMPLAINT!
    494 x 329 - 71K
    Blech, it HAILED last night! :ahhh: :ahhh: Woke me up at 2:30aM and kept me up for a few hours, hoping that the window woulodn['t break. :gulp: :bug:
    Sleepy now, coffee being consumed.. likely won't help much. :down: Early to bed tonight.
    Meh. :blank:
  • ledheadledhead Posts: 1,586
    Skiriki said:
    NON-COMPLAINT!
    Congratulations Skiriki! The wife and I just had our 15th anniversary. We only knew each other for 3 weeks and 2 dates before getting married. Forgive and forget is the key and the realization that it will kill you financially if you part ways. :-) I hope you have as successful of a marriage as we have.
  • Richard HaseltineRichard Haseltine Posts: 108,453
    Skiriki said:
    NON-COMPLAINT!
    Congratulations to you and to Mr Skiriki
    Dana
    Remember that , since it's downloading installers rather than zips, DHM will use more bandwidth and will probably be slower than DIM.
    Yep, we have some critters who looooooooove winter and frolic on snowbanks. And astonishingly, refuse to die.
    Thanks!
    chohole said:
    OMG BLING
    Thanks!
    Hehehe :) Thanks, we had 18 years of life together prior to this, soooo... I guess we can manage! :)
    Thanks!
  • atticanneatticanne Posts: 3,009
    Skiriki said:
    NON-COMPLAINT!
    Congratulations and best wishes, Skiriki. May you have many many more happy years together.
    Meh. :blank:
    Is that what time it was? I got up, looked out, confirmed all the racket was hail, and went back to bed and sleep. Now it's sunny with a clear blue sky. Texas weather--might as well love it.
    AtticAnne said:
    Skiriki said:
    NON-COMPLAINT!
    Thanks!
    Meh. :blank:
    Yeah, noisy stuff, and out where I'm staying (Braker/IH 35) strong winds as well.
    After 5 years I'm kind of getting used to the weather here... :blank:
