Adding to Cart…
It's very self explanatory IF you use the content library. See atached. Can't help with Connect.
NM. double post
I bought this, but sadly it doesn't work in Studio 4.8, which I still prefer to use at the moment because everything still works, (or did up until now), and I'm of the opinion that if it ain't broke, don't try fixing it....
I initially got the script fail to load error, and updated when Zev0 released an update, but guess it's written for 4.9 specifically.
I now have further concerns after reading in the other thread that the new Fit Control products will be script based.
Genesis 8 is designed for 4.9. Fit Control is designed for Genesis 8. So yes, 4.9 will be a requirement.
At least you now have a reason to upgrade. I have been using 4.9 for a long time now, and everything works fine for me, as well as faster render times over 4.8.
@fastbike1
Unfortunately, on my end it looks quite differently, as I have installed everything through Connect. I wish my folders were named like that, but they´re not.
Looks like I´ll have to return this thing. Very disappointed with the lack of proper documentation and support.
Thanks for trying to help out.
Sorry for late reply. Been busy. You use smart content. You cannot convert entire folders like content library users via smart content. You have to use content library for that with metadata support then they will appear in smart content. But since you use smart content, drag whatever poses you see in smart content and convert that way. Set the path you want to save them in and then drag the poses into the script as shown in promo.
@Zev0
After all that whining and frustration, it's all the more annoying to suddenly realize that the answer was right there the whole time. Dang it! Yes, that worked out perfectly, just like you've clearly explained in the promo.
Thank you very much! Now if you'll excuse me, I have some extensive facepalming to do. ;)
Hi Havos,
Spurred on by your encouraging reply, I safely backed up my 4.8 installation files and then went for a clean 4.9 install. It went without a hitch, and works perfectly. Now wondering why I worried about doing this. I must admit that initial tests haven't shown me any difference from 4.8
except everything now works!
It will be interesting to see if my render times improve.
Kind regards,
Hi Zev0,
Thanks for your reply, I have finally 'bitten the bullet', and upgraded to Studio 4.9 and your pose converter script works just great. Looking forward now to more of your Genesis 8 essential tools.
Kind regards,
@Illtm
Glad you've got it sorted. It's a great utility
Question: I picked up the product and pretty satisfied but I am running into a few poses that have issues with the hands in particular the fingers sort of thrusting backwards at an unnatural angle.
That shouldn't happen if you are converting native Genesis 3 poses. If some sets source from Genesis 2 to Genesis 3 via a previous conversion, make sure you have Handy Dandy from slosh, that fixes the hand poses on those sets.
I have just bought the three sets to convert V4 - Genesis 2, Genesis 2 - Genesis 3 and Genesis 3 - Genesis 8. I installed them, pointed the first script at a V4 pose folder in my Poser runtime, set the output folder name and let it run, then tested a couple of the poses. I then ran the Gen 2 - Gen 3 script and unfortunately had some problems with the resulting poses - apparently because I had set the input and output folders the same, so my fault. I deleted the folder and started again:
First script to V4 poser folder, output to a folder in DS content. Repeated this with the other two scripts (sending the output to a new folder each time) and I have now got a folder of V4 poses for Genesis 3 and another folder of V4 poses for Genesis 8.
I've got to say that I am really pleased for two reasons - 1) The products work exactly as stated - no fuss, no messing around. 2) The batch converter works perfectly and much faster than I would have expected.
Thank you for making such a useful and easy to use set of products.
Thanks for answering my question. I didn't realize an answer had been given. I didn't get any email about a response. Finally, I checked back and found the answer. Yes, I agree, this is a very fine product.
Tick the star on the thread you are in, then you get notified:) It is how I keep track of thread responses.
Thank you for this. Is is extremely useful.
It seems that the PostgreSQL CMS shouldn't have to play interference in simply running a script to convert poses. Can't the script be written without it having to play nice? In the alternative--if this what the problem is about--can't there be an option not not create metadata so avoid complications?
OK ... here is the answer. Need to read the thread to the end.
Hi
I just tried to converted 2 directories G8 poses to G3 poses and it worked great, but in smart library all the poses show up directly under local user poses and it will be a pain to go through all the poses in local user if they do not show up in their assigned folder. In content library everythings fine and they show up under 2 different directories: "C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 3 Female\Poses\Genesis 8 Converted Poses\Z Fearless Archer\Genesis 8 Female" and "C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 3 Female\Poses\Genesis 8 Converted Poses\Z Warrior Princess\Genesis 8 Female".
Is there a way to get them to show up in their assigned folders under poses in smart library?
And is there a way to have them directly under poses instead of under local user folder?
last question, I promise: the only way I can se the program in smart library is when genisis figure is selected if no figure is selected it wont show up under utilities, is that the way it is supposed to be or something I messed up?
Thank you in advance
Just FYI, I've run into a pose set that's giving the converter fits: i13 Essential Sports Poses https://www.daz3d.com/i13-50-essential-sports-poses
I'm on Win 7 64-bit, 32GB RAM, current Studio 4.9 build.
Weird thing is, It took forever to even get started converting the pose directory, about 20 minutes. The only reasons I let it keep going were that (1) I looked at Task Manager, and even though Studio said "not responding", Task Manager was showing both CPU and increasing RAM use, and (2) I had to deal with something else that came up unexpectedly and just left it running.
Now that it's started, it's still having issues, compared to other times I've run it. It's translating about one pose every 15-30 seconds. (Studio says its been running for 43 minutes, and it's 46% complete.)
"Create Metadata" is unchecked -- I don't use Smart Content much -- so that's not an issue.
There are about 100 poses. This promises to take a while.
There are a fair number of poses, but there aren't any partials.
It's just odd.
EDIT: And add the Aeon Soul G3F pose sets to the list of ones that take ages (two hours and counting at this point). They do have a lot of partials (a LOT of partials), but it's still taking 15-30 seconds per pose (or partial). It didn't take as long to get started, though.
Odd thing is that it sprinted through their G3M pose set.
@vwrangler "EDIT: And add the Aeon Soul G3F pose sets to the list of ones that take ages (two hours and counting at this point)."
I think you have issues w/ your PC or other settings.
I just converted the following Aeon Soul Pose sets in 1 minute 30 secs total.
Dyna Energy, dYnamo 2, Every Day Walking, Powerstance, and Whymsy.
I have no idea what was going on last night with the Aeon Soul poses. I just did DynaEnergy again to see if I could replicate it, and the entire directory took about 20 seconds.
However, I tried 50 Essential Sports poses again, and a slightly higher-speed version of the same thing started to happen. Studio went off into the mists to think about things at the beginning, but only for about five minutes this time. Individual pose conversion is still taking about 20 seconds per pose. Since I didn't need the poses again -- the ones that it took forever to process do actually work -- I wound up killing Studio in Task Manager, because there's no other way to stop the conversion process. (Not sure if it would actually work or if its even possible, but if another version of this gets made for the Genesis 8/9 transition, a robust ABORT button to try to kill things like this that take forever would be lovely.)
This pose corrector does not take into account that the required adjustment is different when the legs are bent. See Barbult's first comment here, for example. (Link removed by Mod)
This means that "corrected" sitting poses are all borked. I would like to see some kind of fix for this.
Hi,
I am having a problem with the Genesis 3 to Genesis 8 Pose Converter. It used to work rigjht after I purchased and installed it from Daz Install Manager, but it stopped working when I aborted a long conversion queue, and hasn't worked again since. I removed and reinstalled it, but no luck. Version is 1.2.
According to the log file:
2017-10-18 15:43:44.433 DEBUG: D:/ToConvert/Z Alfa Female Daz/01 FullBody/Z_Full_01.duf
2017-10-18 15:43:45.824 DEBUG: Count = 1
2017-10-18 15:43:45.851 DEBUG: Relative Path = D:/ToConvert/Z Alfa Female Daz/01 FullBody/Z_Full_01.duf
2017-10-18 15:43:45.851 DEBUG: bHasDatabase = true
2017-10-18 15:43:45.856 DEBUG: Getting Asset
2017-10-18 15:43:45.858 DEBUG: 0 products found with current asset
2017-10-18 15:43:45.858 DEBUG: Asset Not Found
2017-10-18 15:43:45.858 DEBUG: sFilePath = D:/ToConvert/Z Alfa Female Daz/01 FullBody/Z_Full_01.duf
2017-10-18 15:43:45.859 DEBUG: Path D:/G8FConvertedD:/ToConvert/Z Alfa Female Daz/01 FullBody
2017-10-18 15:43:45.860 DEBUG: Reading D:/ToConvert/Z Alfa Female Daz/01 FullBody/Z_Full_01.duf
2017-10-18 15:43:45.909 Converting Z_Full_01
2017-10-18 15:43:45.909 DEBUG: bIsHierarchical = false
It looks like the Path is now getting mangled when being concatinated:
Any ideas how this can be resolved? I have a ton of poses I wanted to convert from Zeddicus (which I had to convert into the friendlier JSON format without Carriage Returns) and finally got those files converted.
Is there anything special to use Genesis 3 to Genesis 8 Pose Converter on DAZ STUDIO for Mac.
The script creates folders, but there is nothing in it.
The script can run hours without doing anything.
I also have the script Genesis 2 to Genesis 3 Pose Converter, which it does not remain blocked, but it does not convert anything either.
Daz Sudio 4.9.4.122 Pro Edition (64bit)
Mac Pro 3.5 GHz 6-Core Intel Xeon E5, Mac OS Sierra 10.12.06
I bought this product today. Works great! For the most part.
I seem to be having issue converting a spesific creator's Poses (bought at a differnet 3D model online retailer). These poses seem typical G3 Poses, but after converted I get an error when I try to apply the output poses to my G8 Female.
This problem seems spessific to this one creator's product. Is there some scenerio where a creator can prevent conversion programs from working? Or some compatability issue I'm unaware of? It's very strange.
EDIT: Although. I just tested and learned I can apply the problematic G3 Poses to my G8 character, and then use the Pose Corrector, and get good results that way.
the batch convert does not work it only work as on the fly after a batch conversion the poses still had to be adjust on the fly becaus the arms were not properly posed :(
I agree something is wrong with it. I got the Genesis 8 to Genesis 3 Pose converter is busted. It does not create any new genesis 3 poses in the Converted folder. I will try to convert Genesis 3 to Genesis 8 tommorow to see what happens. Is this a script issue? I tried converting it pose by pose and folder conversion. Any help would be appreciated.
Batch convert worked like a dream on everything but one pose pack: Iray Photo Shoot from Draagonstorm. Not looking for a fix, since I can convert them on the fly, but just wanted to put in a heads up. (although, TDLR, so som
