Adding to Cart…
Not quite.
They degrade with write options.
When the life or an SSD is considered, or an SSD becoming unusable, this tends to relate to write options; it is considered likely they would have decades of read only operations. Electrons are locked by the write operations; reading the status of the electrons does not change it, and so does not cause any wear and tear associated with write operations.
I keep reading Tree dripper, the typo without the H doesn't help
except to stop me seeing Threa dripper I suppose or Three dripper
...for myself, it is a relevant situation as the "Library drive" is also where I save my rendered images and tests to. All I have on the Boot frive is the OS, applications, and system utilities ti keep it as lean as possible. I never use the C:/Documents oe Pictures folder for anything.
SSDs are not nearly as fragile as they were years ago. Also Windows automatically detects them and optimizes for them too. They are so much faster I'll never buy or build a desktop or laptop without anymore. Yuge productivity boost.
https://www.howtogeek.com/256859/dont-waste-time-optimizing-your-ssd-windows-knows-what-its-doing/
I'm about ready to decide what to replace my trusty 500GB WD Velociraptor with... (5 year warranty is up in November...
) And they are no longer in production, otherwise I would snatch a new one up in a heartbeat.
I'm honestly looking at getting a M.2 PCIe card and a NVMe M.2 card for my OS drive. (already looked at the info on my workstation, it will not rob any of my video card PCIe lanes)
I'm probably in the same boat of many people thinking about upgrading my system, but power prices have recently skyrocketed where I live (Australia) and I'm wondering if anyone knows if power consumption becomes a significant issue with multi GPU rigs. I know the newer ones are supposed to be more enegry efficient.
That depends on what your current GPU is.
For example, let's look at the GTX xx80 cards
GTX 480 = 250w
GTX 580 = 244w
GTX 680 = 195w
GTX 780 = 250w
GTX 980 = 165w
GTX 1080 = 180w
GTX 780 ti = 250w
GTX 980 ti = 250w
GTX 1080 ti = 250w
On top of that, the question is how often will the GPUs be running full load vs. just being used as a web browser a GTX 1080 will probably sit under the 20w mark the whole time.
...GTX 1070 = 150 W.
I was just illustrating the power usage for similar level cards across the generations.
I get it is relevant, but even when a sectioin becomes non-writable, it can still be read from. This is presuming it's this issue and not another one that has damaged it in a way that stops any read or writes.
I only use SSDs (Documents etc are on a large capacity SSD.), but backup to mechanical drives that a re only plugged in during backup; I also pay Dropbox for more storage too. I have an SSD that is about five years old and still working fine; I retired it a few months ago, so it is now only for testing new Windows installs, but it still has no issues.
One of the benefits for me (and a big one) of SSDs - no noise. Once backups are done, my system is completely silent; sadly, when renders are running, the Strix cards make a little noise.
Modern SSDs will last longer than the rest of the components in your PC before they wear out, unless you're doing something ridiculous like downloading an entire drive's worth of...movies...every week, deleting everything and repeating. http://www.anandtech.com/show/8747/samsung-ssd-850-evo-review/4
....for now I'll stick to HDDs, the case I have is so well soundproofed I don't notice. I never ever store important data or work of mine in the cloud I'll get another backup HDD before that.
...on W10 (one more reason I will not "downgrade" to it). on older versions the reserved VRAM porion is almose negligible.
...until they come down in price I'll stick with HDDs.
I've ordered the parts that I needed to build as I already have 4 MSI GTX 1070 Aeros and some extra drives I'll be using them but here's whats coming this week
AMD Ryzen Threadripper 1950X (16-core/32-thread) Desktop Processor (YD195XA8AEWOF) and Corsair H115i Liquid Cooler Bundle
Thermaltake Core X9 case
Alphacool NexXxoS GPX GPU Waterblock with Backplate, Nvidia Geforce GTX 1080 / 1070, M01, Black 4
Thermaltake Pacific DIY LCS RL360 High Capacity D5 Res/Pump RGB Riing Fan Water Cooling Kit CL-W113-CA12SW-A
Thermaltake Pacific 1/2'' ID x 3/4'' OD Compression – Chrome - 6 Pack
The Pacific V-Tubler 4T 6.5Ft Id 1/2In (13 Mm) Od 3/4In (19 Mm) Provides Flexibl
BXQINLENX Silver Chrome G 1/4" Male to Female 90° Rotary Enhance Multi-Link Adapter(4 PCS) 3
Thermaltake Pacific DIY 1000cc Liquid Cooling System Coolant CL-W021-OS00BU-A Blue CORSAIR Dominator Platinum 128GB (8 x 16GB) 288-Pin DDR4 SDRAM DDR4 2800 (PC4 22400) Desktop Memory Model CMD128GX4M8B2800C14
EVGA SuperNOVA 1600 G2 120-G2-1600-X1 80+ GOLD 1600W Fully Modular
ASUS ROG ZENITH EXTREME sTR4 AMD X399 SATA 6Gb/s USB 3.1 Extended ATX AMD Motherboard
SAMSUNG 960 EVO M.2 500GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E500BW
W10 if you were asking me at least until I get through checking Linux distros
Robert I'm curious...your choice of the Threadripper...was that because you have some apps that can utilize the cores, or was it more of a "future-proof" to make your rig last longer?
A bit of both
Yeah which is one reason I'm checking Linux distros
I run Mint on my laptop and it's the only machine that I use on the web
Yes according to what I read in the Linux thread
Thanks, but I'm curious exactly what type of apps you have that might benefit from the many CPU cores of Threadripper. I keep seeing apps that seem to benefit much more from high power GPU's rather than CPU's, but companies keep coming out with multi-threaded CPU's.
Presumably DAZ Studio when using 3DL would benefit greatly.
And while Bryce I think is limited to 8 threads, the ability to be using both Bryce and DAZ studio at the same time would be fantastic. I could be working on two projects at once (actively working in one application while the other is rendering).
Well I was goung to comment about thread usage and dynamic cloth, but I was just suprised and dissapointed with Marvelous Designer...
Daz Studio's Optitex Dynamic Cloth will use every single thread that you can throw at it (it will max out my 24 threads)
Marvelous Designer on the other hand looks like it's locked down to 4 threads...
