Realistic Renders... NOT!! 12 "And we're back in the room!"
Adding to Cart…
http://bobvan.deviantart.com/art/453-359594166
*Nudity* http://fav.me/d5y3cmf
Excellent advice. I've noted that the default in Studio 4.5 for maximum trace distance has been lowered to 150. Perhaps for this reason...but it also makes rendering a little faster.
For people who aren't as wedded to 3D renders looking, well, real, there is the matter of the building walls and roof. You can set them to not cast shadows and that lets the light flow in unimpeded. Often model makers make walls and the roof 'removable' for camera angles. If you utilize that, it also causes the sunlight, from whatever source, to enter the space.
just playing around with the materials for the Luxus plugin.
Looking good,
There's hardly any grain there at all, how long did it take?
CHEERS!
oh I let it run over night so 9 hours or so
Pretty decent for that amount of time. How does it compare to a Reality render left for that long?
CHEERS!
I just want to thank Bobvan for the tip about Callad of Reality.
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=callad
There are some nice goodies there.
I have also found Jaderail's free Golden Rules Camera Prop v1
http://www.sharecg.com/v/67783/related/21/DAZ-Studio/Golden-Rules-Camera-Prop-v1
No problem I will no longer be offering advice and posting or dealing getting / Luxus. I think then Vendor needs to have thicker skin.. It's a long story & I don't want to get into it but will gladly offer Luxrender advice / tips.
I dunno, I don't have the reality plugin, besides they both use the same renderer Lux..
as for using the 3delight, didn't try it, because there is alot more fiddling to try and get the same result.
Glass can take a while to clear up but if one uses the refine brush it can speed up the process quite a bit. I use it for other areas as well along with some minor PS postwork
I haven't played with that yet, still reprograming brain back to photographic lighting mode for use with Luxrender.
also playing with textures available to see how they affect the scene as a whole.
the scene was also rendered inside a box but it was a 20m box so no light relfection off the sides that I could tell..
doing a new scene with a smaller box (room) and texture that should relfect more light into the scene from the lone spotlight.
Thats one of the things I like about Lux is the lighting once you get used to it you will see how much better it works adjusting it as you render film response is another thing you want to get to know.
well I know ISO, F-Stop, Shutter Speed etc.. been a photobug for decades now, only went DSLR in the past 5 years so that stuff is familiar to me..
the whole gamma correction thing discussed in the luxus thread I need to play with...
Dont use Luxus so i would not know seems to be getting a good fan base. I am used to my work flow so I am staying with what works for me sides R3 will be here soon..
well do you tweak the gamma when using the Linear tone mapping?
Not really just the linear settings sometimes 99% I just adjust lights and film response
ok this is after 30 minutes. I paused it to export the image to a file, then resumed the render going to let it run for another hour or so while I go do some errands..
Not bad I would tweak the settings on your character. The ones I have been posting I let run 2 to 3 hours on average. But then again I queue render quite often as per Roger do you do anything else. Plenty! Thats the great thing. As you most likely noticed you can see if your scene will or will not work within a few minutes so I fire up 5 or 6 then let it rip...
Auto Linear just has the film response + Gamma settings... Linear has the iso, shutter and f-stop AND a gamma setting along with the film response + gamma settings (two gamma settings.. although the film response does say gamma correction.. seems confusing)..
anyway.. with more settings tweaked.
Here is a screenshot of one of my current renders running
ah ok, makes a bit more sense now..
Kodak Gold 200 wow that brings back memories.. LOL.
LOL I like it for indoor scenes
ok.. since this is an indoor scene.. I went back to my photog days..
ISO 400 film speed (kodak gold 200 to warm it up some)
shutter speed 1/60 ( to simulate flash shutter speeds)
F-stop 2.8
gamma 1.0
film response
gamma correction 2.2
film Kodak Gold 200
30 minutes forget the s/p at that time frame..
Like I said I would tweak the character . Other great thing I find about Lux is it will sometime bring life to some older hair here in a 4 year old evo hair for V3 freebie check out how real it looks http://fav.me/d5o3d2r http://fav.me/d5olclo I have produced well over a thousand renders in my 1st year so render times are not that bad
eh, not sure what to tweak, the character shaders are the ones translated from Studio (Lana skin shader) with specular 2 turned off..
as for the hair.. I have the LAMH plugin, might try that with the hair .obj exported in studio, with a tweaked glossy lux material applied..
Ok I dont work with the same settings
yeah I kinda figured you had your own skin setup for Reality.. I haven't even started attempting to take HSS through the plugin (or down the rabbit hole as it were..)
LOL it'l come. As I said we do what works for us glad to see you & Artini join us luxers! Roger one of these days?
I really hate that Lux noise I am OCD about it. which is why I let them run until they look presentable mind you many of my past renders have more noise then I would of liked
hmm well ok LAMH when sent to DAZ as an object file fails to parse to luxrender..
need to play with it more... later.. I think.
NVM found the answer in another thread.. giving it a go now
I read on our forum at Rendo http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2849428&page=170#message_4004796 that these hair systems a bit tricky I still recommend the forum since alot of the tips do apply to Lux.
