Luxus discussion
1141517192050
  • MattymanxMattymanx Posts: 7,000
    MarcCCTx said:
    Mattymanx said:
    Use the gui, turn the tonemapping to Linear, and adjust the light groups while it renders.
    One of the Lux developers commented on the Light groups in Lux and basically stated that they are there for two main reasons
    1. So you can see how much you need to increase or decrease the gain on your lights in your exporter. The Increasing or decreasing their values in the Lux GUI does not make them cast more or less light.
    2. Once you have done the step above and made your changes in the exporter, you can group ALL your lights together and it will use less memeory in LuxRender that way.
    Well, it seems to be working. I'll let it go while I'm at work. This is very cool, I don't understand how it can make such drastic changes on the fly, but it does!
    Does it matter how far along the render is, if I want to tweak the light groups some more?
    Does not matter how far along it is. The Lux GUI will let you make the adjustments on the fly.
  • ArtiniArtini Posts: 10,552
    edited March 2013
    It looks like Luxus or LuxRender does not support double sided materials or am I missing something?
    Below is a render of Victoria 5 wearing coat from Dragon Queen for Genesis Female - DrQueenCape
    http://www.daz3d.com/dragon-queen-for-genesis-female
    with materials from
    Dragon Witches for Dragon Queen - 04_Cape
    http://www.daz3d.com/dragon-witches-for-dragon-queen
    The second image show a fragment of the cape rendered in Daz Studio 4.5 Pro.
    410 x 327 - 63K
    750 x 970 - 282K
    Post edited by Artini on
  • BlackFeather1973BlackFeather1973 Posts: 739
    If you save the flm file, you can still make adjustments after rendering. Just reload your flm and adjust to your liking. Love that :)
  • RAMWolffRAMWolff Posts: 10,369
    The update to Luxus, version 1.0.0.3 is available for download in your accounts.
    The following fixes made it into this release.
    * tiling is fixed. Just use the tiling in the studio parameters.
    * one light group per material. For when a single object has 2 light emitting materials.
    * default sampler is now metropolis
    * write flm option added and defaults to on
    * premultiply alpha added for alpha backgrounds and defaults to off.
    * gonomtric (IES) file, save file dialog as changed to open fiele dialog
    * SurfaceIntegrator “sppm” otion added
    * mitchell filter B and C are now written out
    Not showing up in DIM for me yet. BUT if I go to My Downloadable Products and click on the main installer it's showing at 1003 but the content is still showing at 1002. Is that right? If so I'll just get the main update and install it myself. Thanks
  • RarethRareth Posts: 1,462
    DIM won't install plugins, the content is not up to 1003.
    you have to do manual download and install.
    The DIM won't install applications or plugins so you have to update those manually.
  • willowfanwillowfan Posts: 241
    edited March 2013
    Only the plugin has changed, the content is still the same.
    You will have to download and install the plugin ye olde way, DIM doesn't do plugins, only content.
    PS D'Ya think after 3 replies RAM will get the message? :)
    Post edited by willowfan on
    IIRC Lux was included in the initial DIM download and installation of the product. Oh, I see now.... it downloaded just the Luxus Content after doing a quick search in the DIM download folder. Okey dokey!
    Re: the whole Gamma Correction discussion..
    this is after 30 minutes or so (still noisy)
    texture gamma 2.2
    Auto-Linear Gamma and Film response, Gamma 2.2
    it looks a bit washed out. probably from the white walls and floor
    1024 x 768 - 36K
  • MarieahMarieah Posts: 518
    edited March 2013
    I did a transparency test using four or five different LaceMaker laces, all with transparency maps. As you can see, all of them worked well. These are all default DS shaders. My guess is that any transparency issues might arise with non default DS shaders/surfaces such as Uber Surface and HSS.
    600 x 780 - 139K
    Post edited by Marieah on
  • JabbaJabba Posts: 1,461
    edited March 2013
    I used the "Sun and Sky2 - Dusk" light, and added slight colour adjustment and some bloom on-the-fly while it was rendering...
    1600 x 900 - 625K
    Post edited by Jabba on
  • SphericLabsSphericLabs Posts: 598
    Very cool people.
    The Gamma things has me a little confused, but I will get to the bottom of it.
    Not that I can control this nor would I want to. I know this may come across as a strange request, but I am a big fan of credit where credit is due. Luxus really does not deserve the credit for your renders. LuxRender does. Maybe watermark them with LuxRender instead?
    with materials from
    I am thinking more accurate lighting? Looks like it is in shadow.
    As best as I know how to explain it. The film, like the film to take a photograph at the back of the camera collects all the photons. This is how you get what color each pixel is. Well, LuxRender will use one film per light group. Then LuxRender will combine all of them together at the end. If you add all the photons on one film or combine multiple films later, it gives the same exact result. With combining them later, you can control during render how much each light group factors in.
    There the memory requirements for the extra films, but this is insignificant compared to the size of the models and textures we are dealing with here.
    Very cool people.
    Is a luxrender watermark available somewhere? I did a quick search and couldn't find anything.
    Very cool people.
    Perhaps the logo on their website?
    -> http://www.luxrender.net/en_GB/index
    ok I think I am getting a handle on this gamma thing.
    1024 x 768 - 33K
    Very cool people.
    Smart butt. ;)
    I looked there; nothing popped out.
    try this...
    500 x 111 - 11K
  • ketthroveketthrove Posts: 63
    Very cool people.
    Smart butt. ;)
    The wiki has the Luxrenderer logo source:
    Luxrenderer Logo Links
    Looking good, Rareth.
    Regarding the crashes in hybrid mode we discussed earlier, i've been experiencing them as well.
    With the help of JimmyC_2009 i was able to narrow it down to a combination of using area lights and the sampler used. Setting the sampler to 'random' instead of 'metropolis' (or the other ones available) solved that for me.
    Not sure if that'll work for you as well, but it might be worth trying.
    Had some fun with the logo in XaraX ....
    445 x 110 - 25K
    I'll give that a try thanks.
  • SilverhurstSilverhurst Posts: 182
    Here is my go at a couple of watermarks for you:
    347 x 92 - 5K
    347 x 92 - 6K
    I like them all. Out of respect for DAZ, I think DazStudio should be DAZ Studio
  • NeilrNeilr Posts: 69
    Not sure what I am not doing right, but "out of the box" I set up an outdoor scene and when sent to luxus it renders blue, this is with all default settings. I tried changing many of the setting with no real change other than being able to change the hue in the luxrender rendering window. The lighting I used was the blue sky and distant light.
    if you put a sphere in the scene, do you see that?
  • FusionLAFusionLA Posts: 249
    Marieah, good render.
    Once I get past trying to learn the technical stuff, I can start posting renders.
    During March Madness pretty much bough all of your products! (wallet hurting now:))
    Very cool people.
    Yes this has me confused also,
    I see multiple gamma setting in Luxus and don't know which ones suppose to be changed from 1 to 2.2.
    So far just comparing renders from Luxus and Reality:
    I like that with Luxus even when you don't add a light to the scene it creates one in LuxRender (guessing a distant light).
    Luxus does better and not seem to make the eyes hazy/white like some of the character tests I have done with Reality (sure its a material setting).
    Thanks so much. I really appreciate it. I hope you enjoy the products.
    My last render is a materials test rather than an attempt to produce anything decent. Don't let the tech stuff slow you down. Just jump straight in and make a break for it. Anything you really need to know will trip you over. :-)
