Realistic Renders... NOT!! 12 "And we're back in the room!"
RogerbeeRogerbee Posts: 4,460
edited November 2013 in The Commons
Hello, 'RR..Not' people!!
Whether or not there is still a 100 page limit wasn't ascertained in the last thread, however, as that one was getting close to that limit, I thought it wise to start a new thread just in case.
For any newbies, the purpose of this thread is for us to showcase our renders and to discuss what it took to make them. That's why you may see a page or two with few renders. All platforms are catered for be it DS, Poser, Bryce, Vue or whatever you happen to be using.
Due to my involvement with other projects I don't actually have a render of my own with which to get the ball rolling, so, if anyone else wants to do the honours then they are more than welcome to do so...
Have fun, and I'm looking forward to seeing what you come up with
CHEERS!
Thread number 11 here
Post edited by Chohole on
«13456750
  • RarethRareth Posts: 1,462
    currently playing around with the Luxus plugin and LuxRender, looks like I'll need to rethink lighting when using this.. going to give the currently render some time to run.
  • RogerbeeRogerbee Posts: 4,460
    Cool, looking forward to seeing what it can do.
    CHEERS!
    ok I got this after a hour and a half, around 700 samples per pixel..
    am now in the process of updating graphics drivers so I can use Hybrid mode.
    simple scene, with backdrop, and Luxus lights (sky and area light)
    1024 x 768 - 651K
    Pretty nice,
    Still a bit grainy though. It might need a few more hours before that clears.
    CHEERS!
    yeah looks like an old grainy photo atm.
    anyway got the hybrid mode working, and its about 2x faster, but after an hour the results didn't look as good.. still playing with settings.
    Bob should be able to tell us what's what, the way he cranks out Lux renders...
    CHEERS!
    If you're using a sky and an area light, you may have too much light. Remove one of them (most likely the sky light.) Sky is really for outdoor scenes, though it still my be too bright and harsh.
    hmm used one of the luxus light sets that came with it....
  • BobvanBobvan Posts: 2,653
    edited March 2013
    I will prolly get this plug in since its cheap and since I am used to Reality I can ease my way into it.. The way to get rid of graininess is material adjustments and patience by letting it render. I sure grew lots using Lux but as you all know I can still crank out moocho renders
    Rareth welcome to the great world of Lux rendering
    Post edited by Bobvan on
    Now to add renders here indoors
    800 x 426 - 217K
    800 x 426 - 201K
    edited March 2013
    One from a while back WERTS Lynda Carter morph Lynda
    800 x 426 - 151K
    You certainly seem to get the most out of it, that's for sure!
    CHEERS!
    Often your lighting rig will heavily contribute to the amount of noise in the final image as well. Patience is a virtue, but there's no sense in creating a scene which will take 5 days to render when you can reduce the number of lights and get it done in one. This goes double for any scene which uses volumes such as fog, since Lux is trying to calculate how two sets of light passes through the same materials.
    Been hard at work trying to get realistic subsurface scatter for skin in Luxrender lately, and my results have been very mixed. Hopefully I'll hear back from one of the boffins of the Lux community to figure out the minor issues which currently plague me, but until then I'll just keep experimenting. It's the one linchpin which prevents me using Lux for anything besides scenery, since the people in the image look almost like plastic action figures compared to the scenery they're placed in. It's very distracting for me.
    Here's my latest attempt, but the SSS effect seems too subtle, so I might need to make some alterations. In an ideal world I'd have a muscle map texture I could place under the skin. The idea being that if the skin is translucent and the muscles underneath are accurately simulated, the result would be close to real life.
    1000 x 1000 - 404K
  • kyryiakyryia Posts: 47
    edited March 2013
    Here are my 2 contributions. Both done with reailty/luxrender. SSS handcoded in the .lxo
    1024 x 1170 - 1M
    1396 x 1600 - 3M
    Post edited by kyryia on
    Out of interest, what were your settings for SSS?
    edited March 2013
    You have to add the following line to your .lxo file
    MakeNamedVolume "SSS"
      "homogeneous"
      "texture fresnel" ["RealityWorldFresnel"]
      "color sigma_a" [0.948, 0.03, 0.015]
      "color sigma_s" [1.0, 0.251, 0.12]
      "color g" [0 0 0]
    For the Skin surfaces, assuming you've set them to glossytranslucent in Reality, you'd add a line
    Interior "SSS"
    after the NamedMaterial line in each Skin attribute block. In order to set the material to glossytranslucent you will need to check "translucency" and move the slider all the way to zero.
    You will also have to edit the .lxs file and the line
    VolumeIntegrator "multi"
    before the WorldBegin line.
    edited March 2013
    Intertesting that you're using sigma_s values of lower than 1. In the Luxrender documentation it states that this represents the interior density and that values higher than 1 are recommended for interior volumes for subsurface scatter. As a result, I've been using quite high values (in the region of 100+), so perhaps that's part of my problem.
    Time to retreat to the drawing board and see if I can't remedy this unique problem.
    Edit: One thing I couldn't help noticing is you have comma's in your sigma values. I too have a habit of adding them, but Lux doesn't seem to like them and throws up an error if I use them. Every other source file I've seen simply uses a single space between values instead.
    Post edited by Herald of Fire on
  • madisonx_c5746f56a5madisonx_c5746f56a5 Posts: 224
    First question of the new thread....
    I'm having lots of luck now using UE and HSS, thanks to the help I have gotten here. (Thanks!)
    However, I'm having trouble applying my UE lights to things like interior scenes, especially ones lit by 'natural' sun light. l typically end up with really crummy lighting compared to what I am used to, either too dark or washed out or otherwise rather ugly. I've been trying to setup lights to represent the light streaming through windows, but this rarely has the effect I am going for. In these cases, the UE actually somehow seems to make things look worse!
    Do you guys have any general tips for using UE in a situation like this?
    Are you using directional lighting? If so, try using soft shadows only and relying on your 'sun' to provide the major shadows in the scene.
    second test with the Luxus plugin, (well third, second got posted in the luxus discussion forum)
    1024 x 768 - 30K
    edited March 2013
    I'd use area lights (if you have them) then position them outside the windows. Then you would assign a light color to correspond to the time of day or type of light. This chart was posted a in the old forum..
    EDIT: Got my wires crossed, but you can assign these colors to get the type of lighting you want.
    704 x 800 - 138K
    Post edited by Male-M3dia on
    edited March 2013
    The composition is nice, but, I can't help feeling that there's a light missing. It looks somewhat dull.
    CHEERS!
    Post edited by Rogerbee on
    The top one seems to suffer from the same lack of light as Herald's does. It probably cuts down render times, but, if you're left with a dull looking render then whatever time it did take seems a little wasted. I do like the character though, she reminds me of the actress Dakota Blue Richards.
    Your second render is much better as there is light and life in there and it makes for a very eyecatching scene.
    CHEERS!
    Rogerbee said:
    The composition is nice, bur, I can't help feeling that there's a light missing. It looks somewhat dull.
    CHEERS!
    That's largely a result of the materials being used. I can adjust the tone mapping to make it brighter, but it ends up looking washed out and faded. Like I said, I'm experimenting mostly, trying to find the best settings for decent SSS effects using Luxrender.
    Looking good,
    I would change her hair though, too much of her face is hidden and the dark hair is disappearing into the background.
    CHEERS!
    No problem,
    All the renders I seem to do are tests, so much so sometimes that I forget what it is I'm testing. I want to buy up a few more Lantios sets and maybe get into Lux when I'm more comfortable with everything else.
    I'll get there in the end, thing is, I have to concentrate on one project at one time or I lose focus, and that project isn't 3D at the moment
    CHEERS!
    No problem,
    CHEERS!
    I'm having to completly rethink lights for working with Lux, more is definitely not better.
    edited March 2013
    Quite the opposite in fact. You want as few lights as possible when working with any Lux scene. Since Lux simulates light accurately, it's doing billions of calculations per light source. Too many lights and you get a mass of noise which can take thousands of samples to clear up. Some of my early works are still dotted with noise even after 3000+ samples per pixel and over 100 render hours. In fact, it's so bad that all of the works I've posted both in these forums and on my DA account use a maximum of two lights. I have at least 15 different works which I'll probably never post because they're noise-ridden messes.
    My current render, albeit using SSS, is clocking in at 516 samples and has been running for the last five hours and 37 minutes! It only uses a single light source, but has an efficiency rating of nearly 3000% and still looks as noisy as a test render.
    For simple scenes, Lux can render pretty fast, but the more advanced stuff really does take incredible amounts of time to wash out all the noise. It's one of the major reasons I'm far from abandoning 3Delight just yet. That and easier to use SSS :p
    actually I think I got it right.. more is NOT better... 3Delight you need a bunch of lights (3 minimum to get decent lighting or use UE) with Lux one or two seems to work the best.
