Post Your Renders - #4: A New Hope
1394042444550
  • GarstorGarstor Posts: 1,411
    -_Milo_- said:
    Thank you for those that looked. I said it was probably something I was doing. I have been plunking at that since 7 and that simple step was what I was missing. I even turned on full indirect lighting and I didn't get it.
    7 years old or 7am? ;-)
    That's one of the great things about this forum - plenty of knowledgeable people who are happy to help out and explain a few things.
  • scottidog2scottidog2 Posts: 319
    edited March 2013
    WIP - CLOUDS
    Suggestions and constructive criticism to improve the image most welcome.
    Post edited by scottidog2 on
  • HeadwaxHeadwax Posts: 10,433
    WIP - CLOUDS
    wonderful work. ! Clouds look amazing. Care to share your secret.!?
    My only suggestion would be to blur the horison line to suggest distance - you could do it with a 3d cloud or in post
    Cool! I wish my WIPs looked half as good.
  • FractalDimensiaFractalDimensia Posts: 0
    Awesome detail!
    The blotchiness is sometimes called ashing and it's an artifact from using GI. There may be some things you can do to correct for it. Might help if you could post a screen shot of your render settings for the GI stuff like the photon count, accuracy, etc.
    Also, for the fire, try using a lighter color for the base- A nearly yellow/white and a slightly less saturated orange for the tips. If the tube light is causing problems for you, like banding artifacts, replace it with a bulb light or two.
    Thanks, Evil, for the suggestions. I had already started a render replacing the tube with a bulb light. I also cranked the GI to max (see screenshot below), but as you can see in the attached image, it's still there. I had no photon or caustics settings. I think I'll take a break from the scene for a few days. Maybe fresh eyes will give fresh ideas.
    I was also thinking it would be nice to have an option to add objects to a scene by reference or link instead of having to embed objects into the scene file. You could then work on each object in a separate scene setting and not worry about messing up it's position, size, rotation, etc. in the main scene file. It would also reduce file space. Also, updates to objects in one file would automatically get revised in others where the object is referenced/linked.
    Also, thanks Garstor, Wendy, and Holly for your feedback. =)
    BTW, I lied. I forgot to mention the corbels were from a 3D site. ;)
    960 x 540 - 382K
    242 x 846 - 73K
    WIP - CLOUDS
    The background behind the clouds is a nice contrast, like a foreboding storm on the horizon, and she seems quite unconcerned! Also excellent shading of the column and the vines are a nice touch.
    Only one thing - I would expect there would be more clouds being reflected off the surface of the water, or a hint of the dark clouds to the left on the surface of the distant waters.
    And BTW, ALL of my work is WIP. ;)
    Phenomenal work!
    JimDHart said:
    Awesome detail!
    Hi Jim, to reduce ashing, you could try lowering the the lighting quality (near the photon count) to good instead of best and try and increase the number of photons from 5000, maybe try 20000 to see how it works. You could also try and increase the photon map accuracy from the default 10%. I know sometimes people have luck with turning the interpolation off and others swear by it. To be honest, I rarely use GI so your mileage may vary. I do know that for me at least, increasing the photon count didn't seem to hurt the render times.
    Another trick I learned is to enable the Save Photon Map option, render a low res version of the scene and then when you wish to render the full res version, un-check the Save Photon Map option and enable the Use Saved Photon map option, then load the low res map you had saved previously. You will notice a significant reduction in light calculation time! I learned this from somebody on the old forums and it has helped immensely!
    edited March 2013
    Many thanks, Evil. I'll give those ideas a go in the next 1-2 days and post my results here for feedback. I've been elbow deep in this scene for a full month and need a short hiatus! :)
    Post edited by FractalDimensia on
    I hear you! A hiatus can be a good thing!
  • RoguePilotRoguePilot Posts: 239
    You sort of can get that type of functionality by dragging each item to the browser as you build it. Any changes you want to make to a prop; simply load it into an empty scene and work on it in there (or double click it in the browser which does that automatically). Transfer it back to your original scene via the browser again.
    If you drag and drop to and from the scene list, instead of the scene window, the location of any props will be preserved.
    Did you really model all of those items one after another in the same scene?
    Thank you so much for your suggestions and observations.
    Head wax, the clouds are volumetric Clouds with an orange distance light hitting it from behind.
    Each Cloud is actually a cluster of clouds to give it volume and depth.
    This is a straight up render with only contrast added so far in Post.
    Yes you are spot on with the Horizon line being too clean and sharp. Will fix it in Post.
    FractalDimensia, thanks for your tip about cloud shadows and reflections. Will definitely fix that.
    thanks for explaining about the clouds, I've never played with them much as clouds because of render times - guess I'll go and havenother play courtesy of your superb render
    cheers :)
    Thanks, Rogue. I'm still rather new to Carrara and still haven't learned all the nice tricks. This trick may do just fine! And I did not know locations/etc were preserved. That's good news.
    And no, I built each object in separate scenes and then imported them into the main scene. But, of course, that was followed by 1-2 weeks of refinements, which WERE done in the main scene.
    The primary reason was that I encountered a problem when I attempted to import some objects into the scene, like the clock. (Again, here goes my noobness...) Some objects did not import correctly. The position/size/rotations of some components of some objects did not transfer, and I had to reposition/size/rotate them individually all over again. I tried saving the objects (exporting) and then importing it into the scene, I tried dragging the object into "My Objects" and then dragging back, and I tried copying and pasting. I got the same results each time. I finally resorted to copying and pasting each sub-object one at a time. Of course, that left me with a ton of shaders and other problems....
    Like I said, I learned a LOT making this scene. And DEFINITELY due for a hiatus! :)
    edited March 2013
    <<duplicate>>
    FractalDimensia
    Have you played with grouping?
    Something tells me that might help.
    If nothing else, if you double click a group it will take you into a mini assembly room where only the elements of the group exist
    head wax said:
    FractalDimensia
    Head, I grouped all my objects (in some cases 3-4 levels). The techniques I tried to move the objects into the scene were on the grouped items. I actually think I "infected" my scene early when I imported the carbels, which were originally DAE files. When I imported them in, they went crazy. I finally had to do DAE -> OBJ -> CAR to get them to import properly. It could be that was the source (but as a software engineer, that doesn't seem likely). Anyway, I learned early not to touch a burning stove. ;)
    And I remember now reading about the mini-assembly room. Thanks for the reminder. I'll try that next time. :P
  • edited December 1969
    I don't always use V4... but when I do, nine times out of ten I'm playing with this freaky character, lol :gulp:
    639 x 1024 - 477K
  • DartanbeckDartanbeck Posts: 21,981
    Very cool! I just love your renders. Your lighting, shaders, framing, backgrounds, shadows... not to mention the thoughts that inspire them.
    Said it before... Sayin' it summore.... Koukotsu, you freakin' R O C K ! ! !
    WIP - CLOUDS
    Not feeling a bit critical right now. But I must say that I like this render. Keep that up!
    FractalDimensia,
    Really like yours too.
    Great stuff everyone. It's really neat to just stroll through these pages looking at all of the cool and inspiring things that peeps use Carrara for. Thanks for sharing!
  • bighbigh Posts: 8,147
    then you all ways say that :-)
    Yeah... I guess you're right, bigh :ahhh:
  • GipsGips Posts: 44
    1200 x 600 - 406K
    Very cool! I like how that one guy is totally checking out the car! :) Great shader on the car paint, btw. The rest of your shaders look good too. Some may say that the yellow bench is really bright... I'm not from the big city, but I just saw some city decor just like that! Nice shadowing without getting too sharp. Looks great.
    head wax said:
    FractalDimensia
    pleasure to be of assistance
    Bot inok said:
    love those colours and how sureal the scene is
    Heh, your characters always engage the viewer, love that, and the way she has something ghidden behind her back - probably a maneaterraygun...
    Dartanbeck and head wax, thanks.
    no prob, always a pleasure to give feedback, post some more don't be shy :)
  • DustRiderDustRider Posts: 2,895
    Koukotsu ..... ummm .. WOW!! :bug:
    (forum version of being speechless)
    Bot inok said:
    Got to agree with Dart - the car shaders are perfect. A lot going on in this image, well done.
