Olympia 8
15678911»
  • Calliope23Calliope23 Posts: 546
    edited August 2017
    Is DAZ picky about having everything in the cart in the same time to get the promotion?  I put in a support ticket because I neglected to put in the Olympia 6 and 7 Pro Bundles and the Add-On bundle in with the Olympia 8 Pro Bundle in the same order.
    Post edited by Calliope23 on
  • IldanachIldanach Posts: 217
    Yes. Usually everything has to be in the cart at the same time and processed as one order for you to get the offers.
    i can't open the make up pngs in my PhotoShopElements, says color depth not supported.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    MBusch said:
    @Decoyboy
    The thing is that the Translucency is to high for a caucasian skin, and the values are totally non-sense in the Volume section. Lowering the Translucency to something lke 0.50 helps a lot. Rising the Transmitted Measurement Distance to something like 2 and the Scattering Measurement Distance to 0.75 or 1 will give a more acceptable effect.  I learned that a negative number in the SSS direction, so I use something like -0.65. A Bump value of 15 is very exagerated and doesn't solve the real problem.
    Below is the result, but still a little waxy for my taste. Work in progress.
    This render is very beautiful. It looks like a magazine ad for makeup or some skin beauty product, I don't think it looks waxy at all
  • vwranglervwrangler Posts: 4,989
    Olympia 8 got an update today. The eyebrow problem has been (mostly) corrected. The file is no longer calling the Victoria 8 Eyebrows UV set. It still has the ID for Victoria 8 Eyebrows, but I don't think the ID matters. Someone who doesn't have Victoria 8 will need to check to see if there's any remaining problem.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,612
    edited August 2017
    the olympia bar
    Olympia 6 serving drinks, Olympia 7 with gun, Olympia 8 laying on bar and the Olympia 8 Pro girls Rebekah (lingerie holding tankard)) and Daphne (black lingerie)
    just used the camera headlamp for lighting gave the ladies bit of a tanned look had to do some touchups via paintshop pro x9 mostly noise ans some collision though Olympia 8's face was darker than rest of her so lightened that up
    https://www.daz3d.com/gallery/#images/410891
    Post edited by Chohole on
    I just installed the update and correct, it's been fixed. I don't have Victoria 8, and I no longer receive the call out for V8's eyebrow UV set..the mats apply as normal now.
    On the other hand....is there some trick to her eyebrow prop that I am missing? Cos I think the eyebrow looks awful. Looks like two slugs above her eyes.
    800 x 1200 - 2M
  • Jeanne MJeanne M Posts: 652
    edited August 2017
    vwrangler said:
    Olympia 8 got an update today. The eyebrow problem has been (mostly) corrected. .......
    Exactly what I think. I really don't like her eyebrows, l bought Phoebe (used my coupon on that) and keep using her Mats. I love Phoebe's eyebrows, actually, I just love her!  yes
    Love, Jeanne smiley
    Post edited by Jeanne M on
    Does Phoebe have mats for Olympia's eyebrows, or are Phoebe's eyebrows all on the makeup?
    Love, Jeanne smiley
    Love, Jeanne smiley
    She doesn' t but there's a MATpose called: No Brow LIE preset.
  • FlortaleFlortale Posts: 611
    edited July 2018
    Ophelia 7 HD Add-on has a lot more detail than Olympia 8 HD Add-on.
    Why is Olympia 8 HD Add-on a downgrade in detail from Ophelia 7 HD Add-on?
    Is there anyway to use Ophelia 7 HD Add-On on Genesis 8?
    edited July 2018
    Is there anyway to use Ophelia 7 HD Add-On on Genesits 8?
    No
    edited July 2018
    I don't see the difference between the Olympia 7 and the Olympia 8 HD Add-On, according to the store promos  tbh,   You can't really compare HD  details for two different characters, Ophelia was sold as an older character.
  • nicsttnicstt Posts: 11,715
    MBusch said:
    @Decoyboy
    It's a good render; but like many, it looks like what you see in real photo's; all the blemishes have been photoshopped out to produce perfect uniform skin.
    Seems to me that there is convergence on real and 3D both trying to look like each other. :)
    Check the Sub d settings; maybe try dialling in Olympia's more.
  • Richard HaseltineRichard Haseltine Posts: 109,262
    Ophelia (7) and Olympia (7 or 8) are very different styles of character, Ophelia is a more muscled, warrior type. You can use Genes 7 HD with Genesis 8 as the geometry has changed, normal maps should be usable but the results - as has been found when using normals on a different shape - can have shading artefacts
