If you had $1,600 for a new build today
13»
  • kyoto kidkyoto kid Posts: 42,457
    edited July 2017
    kyoto kid said:
    ...there is a reason. If running W10 using the CPU graphics for the displays and dedicating your GPU card to just rendering will allow you to use the card's total VRAM for rendering. Otherwise W10 will "reserve" (lock out) a noticable anount of the card's memory (about 24 - 28%).
    As I understand it, W10 will still reserve RAM even if you aren't using that card to drive your monitor -- it's reserving RAM based on the number of monitors it could be driving.
    ...I read (I belive here) that of you use onboard graphics or a secondary GPU card to run the displays you could skirt this issue.  If that is not the case, then W10 will never ever be on any machine I work on.  Not about to pay a small fortune for a GPU card to have it hamstrung by a bad OS.
    Post edited by kyoto kid on
  • retiretomauiretiretomaui Posts: 392
    I might consider waiting until AMD releases Vega. Even if you plan on staying with Nvidia for Iray rendering, they'll more than likely be forced to lower their prices to compete with Vega. It might save you a few quatloons on a graphics card.
    edited July 2017
    I know nothing about Vega, other than Newegg has one listed for about $1,000. And I just saw some news that it's not aimed at gamers, which has everyone all upset. And the Newegg reviews says something about no drivers available.
    Yeah, I'm in wait mode to possibly get a second NVIDIA GTX card, hoping prices will drop due to that and the bitcoin nonsense and whatever else.
    Post edited by ebergerly on
    edited July 2017
    ...yeah, Vega is actually aimed at the workstations instead of gaming rigs in spite of it's much lower price than Nvidia's Quadro series.
    The Frontier Edition effectively competes with the Quadro P5000 in memory (16 GB) however the Vega uses faster HBM2 instead of GDDR5X memory  has has far more stream processors, 4096 vs. 2560 for the P5000, and costs about 1,500$ less.(1,000$ less for the hybrid liquid cooled version).
    However yes, it is useless for Iray as it is OpenCL based..  Not really sure if Nvidia will have an answer for it even in the Titan-Xp line as a 16 GB enthusiast card would directly compete with their Quadro P5000, and if they also moved to HBM2, their 6,500$  - 7,000$ Quadro GP100.
