is there a special trick to de-stubbling a skin?
MistaraMistara Posts: 38,675
is there a special trick to de-stubbling a face skin?
there's a couple g3m characters i'd be interested in , if i thought it was possible to get rid of the beard stubbles >.<
thanks smiley
  • Oso3DOso3D Posts: 15,114
    Pull it into photoshop and make liberal use of heal brush, maybe.
  • nonesuch00nonesuch00 Posts: 18,863
    The beardless/stubbleless options offered with DAZ Store products are likely as good as you will get as far as that goes without spending an excruciating amount of time pixel editing.
    You should look at some of the Fred Winkler male characters, the Guy 7 Pro Bundle, and Kenji 7 Pro Bundle if you are looking for different good mostly stubble free options to name three that come to mind.
    When I really want a smooth skinned guy, I often use female skins (though some male skins are fairly youthful/smooth)
  • TaozTaoz Posts: 10,326
    lol.  shaving kit always handy.
    smudge tool makes awful mess.
    tempted by the new Toby.  reminds me of smallville
  • FistyFisty Posts: 3,416
    Yeah, check out Fred Winkler's store, I've never seen (well, noticed) him make a male character that didn't include a nicely shaved option.
    Not smudge, heal brush. Better than smudge (though not perfect)
  • CybersoxCybersox Posts: 9,745
    edited July 2017
    Actually, I've had pretty good luck simply lifting sections of another character's texture set in Photoshop and color matching/blending it in to cover up parts of a texture that I don't like.  That's been to replace things like baked in body hair and eyebrows but my most recent application replaced a female character's entire lower torso starting just below the navel and stopping just south of the buttocks.  As long as you're not crossing over seams and the skin pattern on the borrowed section is reasonably close, it works surprisingly well, especially if you're using NGS Anagenesis 2, which uses the diffuse maps rather than the bump maps to generate most of the added skin textures and helps blend everything together.
    Post edited by Cybersox on
