Creating a grid of Cubes
Analog-X64Analog-X64 Posts: 110
edited December 1969 in Bryce Discussion
Hi Everyone,
I want to create a grid of cubes lets say 10 cubes x 10 cubes. I could do it by hand, but I'd like to make it perfect and symmetrical.
I did some searching and didn't find anything specific.
I did find instancing lab tutorials, but that didn't work well.
Anyone know the best way to do this?
Thanks.
  • Dave SavageDave Savage Posts: 2,436
    edited February 2013
    Use the 'Multi-Replicate' function.
    Create your first block (eg: 10x10x10) and place it top left of where your grid will be created.
    Go to Multi-Replicate (Under the 'Edit' menu)
    Set quantity to 9 and Offset on Z axis to 15 (this will leave 5 units between each block)
    Click the tick.
    A row of block will be created evenly spaced out. Select the row (it's handy to group them too)
    Go back to Multi-Replicate.
    Quantity should still say 9, if not, re-type 9 in that box.
    Set offset on X axis to 15.
    Click the tick.
    You've now got a grid of 10x10 blocks with a space of 5 between them.
    Hope this helps.
    800 x 500 - 63K
    Post edited by Dave Savage on
  • Analog-X64Analog-X64 Posts: 110
    Thank you very much. That helps a lot !!! :)
    The answer was right in front of me and I didn't realize it was so easy to do.
    I'll post my final render so you can see what I have in mind. :)
    Thanks again.
    Here is the first result of what I've learned from creating grids from this thread thanks to TheSavage64's assistance.
    1920 x 1080 - 497K
  • GussNemoGussNemo Posts: 1,855
    @Analog: That's a real interesting image.
    I do have other images that I post on various gallery's. I'll post some on the sticky renders thread.
    Post edited by Analog-X64 on
  • Miss BMiss B Posts: 3,071
    Now that's an abstract if I ever saw one. ;-)
  • IanTPIanTP Posts: 1,329
    Click the tick.
    Click the tick.
    Hope this helps.
    It does indeed, thank you :)
    Rendered with TA lighting at 64RPP.
    757 x 422 - 488K
