JACK TOMALIN APPRECIATION SOCIETY [JAS IV]
191012141550
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,978
    That is pretty curious - and I'd hazard it's something in your render settings.
    The promos didn't take that long to render, I can't recall specifically, but certainly not much longer than usual... and especially not 'hours'.. :)
  • KickAir 8PKickAir 8P Posts: 1,865
    Just wondering, what sort of render times are people getting with Classic Deco? I've tried two different setups, the supplied lighting, and applying Uber AreaLight to the light surfaces. Straightforward scene, looking straight in at the room with all furniture loaded and nothing else added. So far I've always had to quit the render after a couple of hours with under 10% (sometimes well under) completed. This is using the current version of D|S4.5 and my system is powerful enough I usually get moderately complex scenes completely rendered in under half an hour. Is there anything fancy in Reflection or something that would cause these long render times?
    Actually you do make an interesting point. The one thing that was immediately apparent when I did my first render with the Classic Deco was how much longer it took to do a render. The odd thing is that I couldn't see a reason for it. I've had the entire Sacrament set loaded in and rendered it relatively fast and easily, even with material tweaks to add reflections and the like, but the Classic Deco certainly clocked in at a lot longer render time.
    The render above was done with Lux, but even then it required a good 400+ samples, still has fireflies and took over 9 hours to render. It's strange indeed.
    One of the renders I did for Goddess of Time had two spots using raytraced shadows, shadows turned off on every transparent thing I could reach, and raytrace depth at 2 -- it took over 24 hours! :gulp: But, after I clicked "restore defaults" in the advanced render settings everything went much faster. Maybe something in the duf file?
    Don't read into it too much. Whenever I use multiple light sources with Lux, I'm always left rendering for hours just to get something resembling a clean image. That said, there were certainly some slowdowns with using UE2, even when rendering the scene as a standalone. I'm just as stumped as you as to why though. I've looked thoroughly and don't see anything which should cause the trouble. Even my high raytrace settings shouldn't have as much of an impact as they seem to.
    Tis curious indeed, but it's still a great set.
    I took a look -- when you double-click on Upper East Side for Classic Deco's !_Pre_All ( DAZ 3D\Studio\My Library\Environments\Architecture\Classic_Deco\UpperEastSide\!_Pre_All.duf ) in either the Smart Content tab or the Content Library tab, in the Advanced Render Settings the Shading Rate changes to 0.010 (the default is 1.00).
    According to the documentation Shading Rate "determines the quality of and speed control during the render process. The lower the value, the higher the quality and the slower the render." Sounds like our culprit, yes?
    That could well be it, well spotted. :)
    I personally use 0.1 - so not even 0.01, so not sure how that would get int here from here.. hmm!
    You nailed it, I think. I took the shading rate up to 0.1 (what I usually use as well), applied the arealights like last time, upped the sampling rate enough to get rid of the fuzzies, and I'm now getting something pretty close to the quality of the pic Akhbour posted a few pages back — except this time it's only taken quarter of an hour to reach 20% done.
    Looking good so far.
    Great! Glad I could help. :coolsmile:
  • SzarkSzark Posts: 10,634
    See told you it had to be something like that. :)
    10 points to Gryffindor!
    Only 10 points :P
    Szark said:
    Only 10 points :P
    Yea, haven't you heard.. there's a recession on! :lol:
    That old chestnut...good excuse for being tight then, I see. ;)
    Used Jack's Curator Aquarum wearing the new Folly texture. (If Folly's just a texture set, how do the flowers work?) DS4.5Pro render, postwork in GIMP. Larger version in my deviantART gallery here.
    Flowers in the Aftermath
    1600 x 2000 - 2M
    I think we need a Valentine type image in here
    "Yes dear, you're still the one I love...................but.............umm, why are you wearing your grandaughter's dress?"
    674 x 900 - 368K
    ROFLOL chohole, very funny
    edited February 2013
    Thanks Pete. May look better in Monochrome
    724 x 950 - 379K
    Post edited by Chohole on
    For me I think it does
  • Miss BMiss B Posts: 3,071
    As much as I like the color version, I think I agree with Pete. I like the monochrome version better too.
    Somehow it's befitting the age of the characters. ;-)
  • Norse GraphicsNorse Graphics Posts: 0
    Szark said:
    Only 10 points :P
    Would be bad to get inflation of points, Jack... :lol:
  • kyoto kidkyoto kid Posts: 42,368
    Szark said:
    Only 10 points :P
    ...based on the current exchange rate, that would be 15.5 points here in the colonies.
    Is it crude or refined points, Kyoto? :)
  • TotteTotte Posts: 15,084
    ROFL!! That one has some distinct "kimreb55th" humor over it ;-)
    Heard today Hogwarts might introduce some quantitative easing to help with the inflation... so.. 800 billion points to Gryffindor!
    No, it's all my own sense of humour, honest. lol. Maybe we just have similar senses of humour as we are both Brits, and both involved in American Civil War reenactment at one stage, both as rebels.
    LOL !
    You make it sound like Germany in 1930. I heard a story from a friend to my father who said that when you got money, you rushed and bought just about anything, a shovel, a kilogram of butter, anything that would not loose its value over the day.
    Totte said:
    LOL !
    I guess if you'd bought a kilo of butter the shovel comes in handy too ;)
    Jack - reports says you got great weather btw. Neither rain nor fog, weird.
  • AkhbourAkhbour Posts: 0
    And still playing arround, first the 3D version and then the "flat" version:
    "Ghost train"
    1280 x 1024 - 156K
    1280 x 1024 - 180K
    Yea, it's quite cold - but I guess for them it's 'normal' lol..
    "Ghost train"
    Nice render :)
