Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
It's always a pleasure to see such lovely renders rolling in, great work guys!
I really love this one. He's so cute!
I would love to see how long the render times are for the images posted.
I tried doing some of them, and render is taking forever.. (had to re-install my software, since my laptop crashed) but things seems to be a lot slower to render for Iray.
GPU is on for rendering, but missing the speed somehow.
This one was about 28 minutes. Most of the portraits I post are 25- 32 minutes. They usually have three ghost lights. The Film ISO is about 135 and Exposure Value anywhere from 13.20 to 13.60 I scale up the fluorescent ceiling light to about 120-140% of it's size, so it gives good light. Hope that helps.
Thanks for the update.
Guess I got use to the 1st ghost light set, which brought scenes down from 30-90 minutes to 5-15 minutes.. But even that doesn't seem to work for me anymore lol.
I must have had a default setting changed somewhere, and who knows what it was.. :(
Did you lower the resolution of your textures?
Not at all. Wish I knew what I had changed. :( Looked at all my other topics where I asked questions, and couldn't find anything specifc.
This can speed up your render - thread with freebie script to reduce texture size/resolution:
https://www.daz3d.com/forums/discussion/137161/reduce-texture-sizes-easily-with-this-script/p1
And this does even more. It's worth every penny, imo: the IRAY scene optimizer
https://www.daz3d.com/scene-optimizer
Has anything changed with your scenes? SSS and translucency on character skins can really affect render times. Do you have an old scene that was working great before? If you could open that back up and render again, that would help identify the problem.
Nope nothing.
I can't open up my scenes, since the DUF files I created to save them are all corrupt :( due to my crash.
Tried opening with a Text Editor but can't read it
This is what I get in those files.. Guess there is nothing I can do for that
lost all my scenes, Movie timelines etc..
2017-05-22 22:00:33.661 *** Scene Cleared ***
2017-05-22 22:00:33.818 Json Parser (23447,17): Syntax Error - expected ',' or '}'
2017-05-22 22:00:33.818 Error reading file, see log for more details.
Are you using a Nvidia card? If so, it might be worth checking if it's enabled in the render tab. A fresh re-install might have defaulted you back to CPU.
Yep. GPU is checked.
I did find an old thread from someone with the Same problem, and it might not have saved it correctly.. but I know it did
NOW... the thing is that was with the prev. version of Daz. and Now I am using the latest version, so wondering if that has anything to do with it.
Going through all my scene files, and some of them are opening, but missing files.. I know that has to do, that it create some files once you open up a new scene. depending on the item.
luckily I already rendered 60.000 images last year lol.. so I can work on the movie parts.. but those are all 3Delight.
Guess it is what it is.. Need to file my scenes with the Ghost lights in it, (going though tons of scene files :( If not, I will re-create some.. have to dig through the thread from the original Ghost light kit.. Maybe I had posted there something.. that's the only thread I didn't look at.
So much to do, and no time.to play with all those darn sales lol
You posted a render on page 11 of the original thread if that helps at all?
I will take a look
these things are driving me insane.. I loaded a plain Park Point items I have, hoping it would create the files.
But seems like I need to install all my poser files too, even though I am not using Poser atm. (was avoiding that cause it messes up my Daz Smart library with all those empty icons)
2017-05-22 22:40:59.825 Loaded file: stairtower.duf
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_stcase.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_rubble_3.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_rubble_1.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_wl_lights.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_con_2.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_con_1.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_ladder.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_str_light.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_walls.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_wire_shlf.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_l_switch.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_rubble_2.obj"
2017-05-22 22:41:01.044 Could not resolve : "/Runtime/Geometries/Park_Point_Int/ppi_supp.obj"
yeah, back in the old days, there'd be two files - a poser one and a DS one. The poser one generally had all the files you needed, and the DS just contained ds mats. If the poser file size is much bigger than the ds one, that's the case.
Thanks.. I had no idea
I do have a lot of files that are about the same filesize for both of them, guess it's time to install all those big suckers then.
ps. think I kinde derailed this thread... Sorry about that... Let's back on track :)
This is from the pdf:
"Since ghost lights are diffuse lights, they do not have any specular feedback, nor any specular effect on your scene. This can make your scene look flat and matte. Using one of the optimized IGLK props in this package will not only provide ghost lighting, but also emit Gloss from a logical light source."
I'm a bit confused. IF we want specular feedback, do we use the rigged props, the ultility props, or will both work?
If only the rigged props provide specular effects, how do they accomplish it? It still looks like the light comes from the ghost light plane.
It might make more sense if i change the word "specular" to "reflection", because in physically based renderers, they are pretty much the same thing. Because ghost lights are invisible, they give items in the scene no reflective source, which can make things look dry and matte. This isn't much of an issue if you have an HDRI blaring through windows, because that is reflective. If you're doing an enclosed evening scene with nothing but ghost lights however, you're not giving the scene much to work with in terms of reflection. The rigged props in IGLK2 all ship with emissive surfaces, which are visible and highly reflective, so they do warrant a specular (reflective) response from all of the surfaces in your scene.
The utility props are just extended ghost lights, they will cause very little reflective response. They are meant to be ambient light fill lights to "boost" light levels rather than replace lights completely (Just like the first ghost light set). Of course, i'm not going to dictate how people compose their scenes, i've seen people use ghost lights on their own and are quite happy. I'm just offering a more well-rounded lighting approach that's all. Hopefully i've explained myself well here, le me know if there's anything else i can clear up.
Lack of reflections is a feature or a bug, depending. :)
Thanks, that makes sense. I like to know which props can offer more reflectivity.
Also, it gives me an idea about performance. I suspect the renders will be faster with less reflectivity response and with simpler geometry, i.e., IGLK1 kit...which was just a simple square. So I'll probably stick with IGLK1 when doing animations just to make things go faster (or perhaps the utility props in IGLK2 since they won't have reflective calcs to burden performance). Then I'll use the reflective rigged props for still shots which need more 'realism'.
Very true..
There's always a bit of a slowdown when you add emissive elements to the scene, but if you keep the emission values under control, you shouldn't get fireflies. The props i've provided use quite low emission and rely on the ghost light to do the actual lighting grunt work. The original ghosts are probably better for animations though, agreed.
Loved the first set, love the second set. I use these lights all the time now, my renders are much improved. Thank you!
Thanks Spuffy! Really glad you like them. Great username by the way
Just picked this up the other day, I can't wait for the weekend to really dig into it. I did load up the scene that has "challenged" me for a bit (I'm still learning), and used it as a test. All I can say is Thank You!!!
Lighting is two small light ball's for the sconce's, a mod box at the ceiling, and a light ball at the top of the stairwell.
Total Rendering Time: 1 minutes 23.23 seconds
I''m thrilled!
I've been using this for a while, and I have to say this is awesome! :) I'm using it whenever I need a little extra light. It's super easy, super fast.
Thanks Lars, very glad you like it. Good luck and be sure to drop back into the thread if you have any issues.
I finally bought the first Ghost Light Kit, and I like it a lot. They are great for animation and though I was making my own ghost lights manually before, the presets save a lot of time and are well worth it.
Now, I'm wondering though about this second set. I'm on the fence on whether it would benefit me. I already have several iray light light shader sets for quickly turning existing light bulbs, lamps, etc into emissives. And those seem to work really well. Is this set essentially another variation on that but with some included props? Or are there some tricks involved that make these render faster than the traditional way of turning existing bulb/prop etc into emissive? (Sorry i haven't read all the pages if this has been asked already)
I mostly use the dome and sphere props from Ghost light 2, for lighting a central figure in a scene or throwing more light into dimly lit parts of mid-sized sets.
IGLK 2 comes with some extra primitives and tools that the first set doesn't contain, but the main focus is on the light props. I tried to make the props as optimized as i possibly could but using as few polygons as possible on the bulbs (each poly is counted as a light source), and the shades are emissives rather than translucent. What bothered me about the first set is that there wasn't any sources for reflection on the lights, they were purely diffuse, and i wanted to correct that in the most optimized way possible, because that's the whole point of the set.
However! I would not want to sell you something you didn't need. If you're happy setting up your own fixtures with your favorite props, and they perform well enough, you're not missing out. If you don't really need an extended range of primitives, you're not missing out. My light sets go on sale a lot so there's no hurry if you're not sure.
One of the first things I learned about using emissives in Iray is the software must calculate the light rays for each and every surface. A light bulb that looks smooth is going to have a lot of surfaces, one for each polygon. The fewer polys, the faster Iray will calculate the light. That's why single poly planes make such great emissive light sources. I have both Iray Ghost Light Kits, and this one brings a lot to the runtime, even though it's not as fast as the single poly planes of the original. I still wouldn't be without it. When it comes to creating ambient light in tough to light situations, the ghost light kits and KA's latest "Light Probes" are my go to products.
