Garibaldi Express: Hair and Fur Plugin Beta [Commercial]
Adding to Cart…
3.Yes...I am getting older and not being able to make the plugin FULL screen kinda makes me feel even older when I have to put on my "Reading Glasses" on this 19" monitor...Ok just kidding I can read everything but the option to make full screen to take advantage of my 52" Sony would really be nice...
Back around beta version 3 or 4, I was able to use Garibaldi with Optitex dynamic cloth, but now I no longer can. Nothing shows up in the setup screen.... Any idea why?
Can I suggest setting up a beta forum outside of DAZ...?
For ParticleFX DS I did this...
Playing around with the latest beta. I haven't had as much time to try things out as I like, but this is my attempt at a mane for the new horse.
That looks like a great mane :-)
Thanks Shaaelia. Not exactly what I wanted but I'm getting there. :-)
Looks like you need more tweaking with the colors/shader than the hair itself...
I dont know what I'm doing wrong here... I'm getting a little frustrated, I've spent the last 3 hours trying to get it to look right...
How is every one getting the hair dark brown/black??? I've been setting the colour to its darkest possible setting yet up and down in saturation yet All I get is either Grey, grey/blond and blond :-S
Ignore the straight face/blank expression and no pose lol, Just trying to get the hair right first :-P (The render is just test renders)
With the hair selected in DS go to the surfaces tab. Among other things, you will find primary and secondary specular where you can adjust the colour.
I've used distant lights in most of the renders I posted so they work fine. I've also used Uberenvironment with the settings cranked up - but be prepared for a loooooong render time depending on what you've done with the hair.
Raytraced shadows also work. In short, you can use any lighting you want - its just a matter of how much time you want to spend on the render and what you want it to look like.
Gee, that sounds pretty much like all rendering. :-)
LMAO! At the time I looked at the surfaces tab and everything was named so different to the usual shaders lol, But I discovered if you open the sub menu it lists the categories haha Thanks man!
I'm no longer sure if the Gloss and Spec is my issue, which I thought at first.
I replaced my Zbrush fur on my New Santa character with Garibaldi Hair .. just a quick test
render so much faster with Uber
Other than my issue with getting the dark hair colours to work, - I have found a glitch with Garibaldi...
When Garibaldi hair is in the scene, if you try to change UV's, either on a newly added character to the scene, or the character that has the hair applied to, you will get multiple UV's on that character that dont match, and when you try to correct the UV issue, it changes the other UV's on other body parts.
I loaded Justin to the scene, after adding hair to another character, and his V4 Uv's didn't match up, when I tried to correct the UV, it swapped and mixed into different Uv's. I couldn't get Justin to have one single UV on the entire body. I closed the scene and and loaded Justin alone, with no Garibaldi hair in the scene, and he loaded perfectly no problems.
He is wonderful Cath. Like a 1950's Santa.
Cath...you watch Miracle on 34th street, much?
Looks like that Santa.
Looks great with Garibaldi fur.
Santa looks so cool! The galabaldi really helps bring it out to its fullest well done :)
Also love that horse mane looks great with the subtle curls and clumping.
I've attached my settings of my hair, which despite my efforts, I cant get it to go dark brown or even black for that matter. It all looks good in the Gala window, but it wont render dark at all. :(
Try reducing the Secondary specular intensity "TRT Intensity" also the Diffuse intensity "D Intensity".
More details are in this old post, the Garibaldi hair shading model is pretty much the standard for hair these days, but is a little confusing without any documentation as it varies quite a bit from a standard surface shading model:
http://www.daz3d.com/forums/discussion/9943/P120/#151488
(post 128)
Looks like I'll have to have another look into the my daz mesh analysing code. I changed the code a while back to fix issues people were having with Multiple UV sets, looks like there still some glitches. I imagine the changes might have broken support for the more unusual mesh setups as well.
For now I think its best to stick with the daz forum. But there might be a separate forum after the final release, I'm not fully decided on it yet.
(post 128)
Thankyou heaps!! I'm mid way through rendering and can see a definite improvement.
I don't suppose there's a way to add the specular / gloss value settings and the Diffuse strength to the Garibaldi window under the Distribute tab below the colour settings. I think that would be a very useful set of sliders and ease of modification.
I was a little baffled as to what to change and whether it should be modified in the surfaces tab in Daz, I'd assume customers might have that same thought lol, before I spoke to you and Gone that is.
But of course if it would be a ridiculous work load to add those sliders and colour selection panels then it wouldn't be necessary to do. :)
Yeah I was thinking it may have something to do with that feature... I think the fix to paint hair on multiple UV sets is Ideal, and I was one of those beta testers that requested that fix lol It was only by chance that I discovered the glitch when additional characters and texture sets are loaded into the same scene.
My first Garibaldi hairstyle. After much trial and error, and lots of surfacing dabbling I have a render :)
I modified the secondary specular, a little adjustment on the diffuse strength and assigned a respective colour to both specular channels, eventually everything started to blend the way I wanted. No crashes, and I will say it was to my surprise that the hair actually rendered 2/3 faster than Spartacus short trans-mapped hair (With NO Bump or displacement applied!) 15 mins it took to render.
Now I need to find a way to stop the hair sticking up at the crown (No node is sticking up btw so I cant cut it) And work out how to make his que.
very nice
Thanks Bigh! I just hope I can afford this plug-in once its released, I really want it :)
If you reduce the auto parting threshold in the styling workspace I think it will give you the effect you want easiest, a setting no lower than 100 degrees I imagine should work well for you.
The hair at the crown adds to the realism imo. I didn't realize the que wasn't part of the style and was wondering how you got Garibaldi to do that.
I've been wondering about mixing Garibaldi with modeled hair for any solid area that isn't individual fibers, i.e. a solid modeled base area covered in 'hair' rather then trying to do the whole style in Garibaldi. Take a Marie-Louise wig for example. It seems it would be much easier to model the base in a solid mesh then 'grow hair' combed flat against the mesh similar to a form used in wig making. Hair on top of the mesh would give the advantage realistic hair, and blended with hair nodes for the hairline or any free flowing hair would make for a quicker workflow with good results it seems.
Thanks FutureBiscuit! I'll have a play :) I'm really liking this beta!
@Gedd - Yeah, I was thinking I might try adding Garibaldi hair to the surface of the solid plat, just not sure yet my plan of attack. Thing is, I'll need the hair to line up pretty good, and end it at each joint running down it. The end where the hair is loose I'll need to wrap the hair around the models surface... Might be a piece of work, now that I think about it.... I wonder how it would go using a strong gravity setting?
For a braid, don't think of it as long hair running the length. Do short hair that goes one braid section each and trim/comb the hairs so they fit in. Add a node to the end for the loose hairs. Also, don't make the hairs totally flat, real braids have some loose hairs poking out here and there (like the crown,) except in styles that used some type of 'gel' to keep the hair flat, in which case one might want to adjust the shine.
That was what I was trying to say, but you totally said that much more understandably than I did lol. The good thing about doing it the way you explained is that all the bones are there, it's still fully possible and I wont need an excessive amount of hair strands to make it (Only enough to completely cover it) :)
EDIT: Yes of course, there must be some loose strands, realism is what Garibaldi is all about :)
Yes, I thought of the bones issue and potential reduced hair count also, just forgot to mention those ;)
It should definitely cut down on render time as there should be less calculations using a solid mesh in areas instead of fibers where they won't be seen.
I'm surprised with how fast the head hair rendered! Thanks for helping me nut out the plan of attack... I'll give it a go!
