Adding to Cart…
I believe the reason they were asking about uninstalling the old version is if it causes any installation conflicts. So by this I assume you are saying that an old install of Headshop will not interfere?
Don't assume. Both HeadShop and OneClick locate in a folder that is called HeadShop plugin. If you want to keep HeadShop 10.2 AND OneClick, you need to temporary rename one before installing the other. For example: "10.2HeadsShop plugin". This way you will have two folders in your DAZ 3D folder: 10.2HeadShop plugin AND HeadShop plugin. If you want toswitch between the two, you need to quit DAZ Studio and rename the folders. Whichever is called HeadShop plugin will launch.
Question for HeadShop users:
How does HeadShop handle the eyes?
Does it deform the eyes to fit the face, or do the eyeballs retain their original shape?
(You can make the head part invisible to get a better look.)
Has anyone solved the vertex count mismatch thing? I get that there's a whole drama around directories, but even when i try and manually import the obj that headshop kicked out, i still get vertex count mismatch? I've exported at base rez and subD, to no avail. Anyone solved this riddle?
Edit: Cancel that, it looks like headshop is exporting just the head, and there is more trickery under the hood. Are people still getting mistmatch issues with default install directories? Is it alternate content directories that are the issue?
The default directory issue seems to be limited to the TEMP folder setting inside DAZ Studio. If that TEMP folder setting is anywhere else but the default, HS will not find the head it creates, as that is stored in the TEMP folder specified in the Studio parameter settings. Once reset the TEMP to default, HS will work without having to move around content and create empty folders.
How very strange. I have the default c drive temp folder (C:\Users\Andy\AppData\Roaming\DAZ 3D\Studio4\temp\FaceShop), and faceshop is actually outputting files to it. I still get the vertex mismatch for some reason though. In-fact, digging around the thread and looking at what faceshop is actually doing, i have all the folders it requires in the correct position, but still no dice.
Hello,
I had an error when work is finish and trying to transfer it in daz by closing headshop :
"HeadShop closed before it could create the necessary files .."
What can I do to solve this issue ?
Don't just close Headshop. In the upper left corner of Headshop click on file > export
Thank you. Sorry for that silly question.
Oh, sorry, that was a misunderstanding, then. I thought you were referring to the earlier error with the missing object, not the vertices one. That, I don't know anything about, sorry.
Yeah, its the vert mismatch that's my issue. It looks like headshop exports a head obj, not the full figure, which obviously means importing manually will mistmatch since nearly all of the body is missing. There must be something headshop is doing under the hood to facilitate this, but unfortunately the pipeline just isn't working for me. I'm normally quite good at working around these issues, even reverse engineering them, but this one has me stumped. Everything is installed correctly, all the folders are in the right place, but still Geo mistmatching no matter the res nor source. Hopefully op can drop in at some point and sherlock the problem.
Actually HeadShop exports the whole figure. However, it was not built to manually match and morph but as a plugin (you are right when assuming that we do stuff under the hood.).
My suggestion is to go with the flow and use OneClick as intended - as a plugin.
Well that's the problem, it's not working at all at the moment. Everything is installed correctly but i'm still getting vertex mismatch. I'm using the default install location, all of the user files (including temp folder) are in the right place and i'm still getting vert mistmatch. Headshop is even exporting to the correct directory (temp folder) but it's still not loading the morph. Any ideas?
Have you tried different figures, like Genesis 3, instead of 2? Please send me an email to [email protected] to set up a skype techsupport ASAP.
OK I've bought this product and installed it but it just will not show in DAZ 3D UI, I've checked and re-checked, I've uninstalled and re-installed and there is no way I can get 'OneClick' to appear anywhere in DAZ.
I've browsed to my programe folder and everything seems to be there that would suggest 'OneClick' has installed and I've also checked and re-checked that I am installing the correct (64bit) version for my DAZ Studio but still no way will this product show up in any of the menus.
Any ideas please ?
It should be under the edit tab (Edit > Start Headshop)
You may also start under Help/About Installed Plugins. If you see it there, it should also show up under the Edit/Start HeadShop
Question, slightly annoying problem.
OK I import image, on the left is a perfect head facing directly forward.
The model's head, however ( male and female ) is slightly tilted upward.
The dials enable you to rotate left and right , but as far as I can see not up and down to
directly face the camera.
Have to compensate with Zbrush and morph dials.
Any suggestions.
Thank you
example
I checked the installation as suggested earlier and the HeadShop OneClick files are in the places they belong
Still, after I select an image file I get a display with the points shown on the face but an error message "Daz model not found."
This happens whether I use Gen2 or Gen3.
DAZ Studio is installed and in working condition.
What is your problem and can you tell me how to get past it?
PS I obliterated some details in the attached image.
Please see some of the previous comments reagrding this issue. Basically HeadShop looks at files in locations on c: drive
That isn't going to work either I'm afraid because it's also not showing in Installed Plugins.
I surely DID accept the defaults for the DAZ library / runtime location when I installed, but the paths DO NOT match what you specified. [I checked a second machine where I know I did a "quick" install of DS and it is the same]: I have C:\Users\Public\Documents\My DAZ 3D Library and under that .\People with all the Genesis 2 Female etc; and also .\Runtime with Geometries, Textures etc. under it but your installer did not create any FaceShop directory.
Please review what you typed above and say if you may really mean paths like this C:\Users\Public\Documents\My DAZ 3D Library which is what my installations defaulted to, I am CERTAIN that *I* did not type in any extra "3D" in that path.
I had my DAZ temp directory reassigned to a different drive [not that there's anything wrong with that!] . The plugin was writing the model to that diretory [as it should] but the external program did not see it because you have hard coded the path.
Hard-coding reliance on defaults paths that are easily changed is fragile, and it is, in my expert opinion, unprofessional to ship a product in that condition. You need to clean this up or suffere endless [and well-deserved] complaints.
Sorry to be stubborn but.....in your clooney example, the problem of the head's angling upward is present.
In the oriental and child's head it is not.
So...there must be a way to angle the figure head to face directly forward and not upward.
Is it the set up of the figure in DAZ, or am I missing a dial?
Thank you for your patience
Current version of OneClick (or HeadShop) only rotates heads horizontally. This is why thenprogram asks for straight on photos and not photos that look down or to the side. The illustrations you are refering to were rendered in DAZ Studio, where heads rotate in all axes.
I think I may have to get a refund for this product I'm afraid, I've tried everything I can think of now and still I can not get it to show up in DAZ menus.... grrrrrrrr!
Check out if you have set a different TEMP Folder in DAZ Studio than he Default TEMP Folder. I've found that this causes the "missing model" error, as DS writes the object into the folder specified in Preferences, while Headshop looks under te default location. Perhaps that is what causes your problem, too?
Yes, thank you, I found that a bit later and reported it just above.
However, this condition is certainly his problem not my problem.
Is he having trouble figuring out to pass the temp path from the plugin to the exe? There are oh so many ways you could try to do this correctly, e,g.
There are SO MANY WAYS to do this right. As a retired sw dev executive with one-time responsibility for software engineering, software QA, and personally release go/no-go decisions on six and seven figure software deliverables, I personally would find it difficult to excuse myself if I released software in the condition this is now.
That said, the innovation of auto-locating the points seems to me to very useful and an impressive advance. Even if I discard the texture the process seems to yield an altered face that could pass as a sibling of the source and that can be different from the generic perfect Genesis faces in ways that may be interesting.
There seems to be quite a few people having trouble getting this to install, is there any way you can make it 'Daz Install Manger' compatable ? At least that way it will be correctly directed to where our other stuff is kept.
