Adding to Cart…
I can't afford those $10 cans of compressed air.
With Neat Video I can use 3DL, too, for animations, and spend less on render time as well. Glad Octane has it now, but that's a big purchase for me these days. When I was younger and had more money coming in I could have done it.
You clean them with a toothbrush and turn them on their side and just blow them out. I did it all the time before I got a air blower that plugs into the wall and blows the whole thing clean. Was the best $60 purchase I made. You will keep your computer. keyboard, and mouse clean at all times. If you can spare it at some point I suggest you get it. It cleans the radiator out for my liquid cooling great. It comes with a brush attachment that you can do deep cleaning.
Blower
Um. No. That's just patently false.There is a paid for newer version of UberSurface, but that's all. UberSurface is free. UE2 is free. AoA Subsurface Shader is free.
I'm not trying to score points, just make a point.
Now that's much more practical. Thanks.
I am sort of in the same boat as you when it comes to getting a better PC than what I have, which is the one in my siggy.. The main reason I shied away from Iray and went back to 3Delight was that I had cooked my 570GTX while doing a series of Iray renders, and if not for the generosity of a friend I would still be stuck with the onboard intel video.. :) And well for me and the stuff that I do 3DDelight suits me as well, and I have learnt a lot on how to get the best out of it..
Yeah that is the problem with UE it does a great job but, I would probably be pushing up daisies by the time the render finsihed.. lol :)
...and notebooks don't have anywhere near enough adequate cooling compared to desktops. I pretty much killed the keyboard on my old Toshiba becuase of the heat generated by rendering. Also notebooks have very limited expandability save for memory and drives.
...+1
...I just wish the 4.7 update didn't break the flagging for SSS. Yeah there is a workaround, but it is extremely tedious, especially in a large scene.
I still think I got pretty darn close to a decent realism with the AoA lights. Have to fake GI and bounce, but that is fairly simple. Yeah you don't have the emissive shader so no way to turn a surface into a light source (unless you use the Uber Area Light which can be a pain to get right), however I've spent years having to position lights where I needed them long before Iray.
I was very pleased when the preliminary version of my bus stop scene took only 14 min in 3DL compared to over two hours in Iray (the final version took nearly 4 hours, and I didn't like the shadows, textures, or the lighting as much).
Here is another 3DL scene I thought came out very well. Uses only the AoA lights, no UE. Rendered pretty quickly as well.
I just recieved my system from System76. They make Linux machines but I put Windows 10 Pro on it. I only got one Graphics board. I may have to get another if DAZ will use a second one for rendering only. I think my processor is an i7-6900, 128 GB RAM, 32 TB hard drive with a RAID board in a RAID 10 configureation, so only 16 TB storage. Right now I'm trying to figure out the right way to copy my library from my laptop to the new monster machine. I don't want anotherTitan-Hydro because the heat coming off this machine is a lot right now. I have to figure out how to move the heat out of the cabinet I've put it in (right now I just keep the doors open). On the other hand, there is already heat coming out of it, so I could run it all the time in the winter and heat my RV! I'm thinking of cutting holes in the cabinet and putting some fans there.
I like it: recursive cooling.
The cost for my new machine was just a little bit more than your's ($7,000 or so). It was originally meant for artificial intelligence research for robotics. Now I'll use it for 3d graphics.
Now I have to figure out how to install a second graphics board so that DAZ will use it for rendering and which board to get.
