Why Is My Pie Crust Still Frozen Complaint Thread
1…1819212324…50
  • SpyroRueSpyroRue Posts: 5,020
    Some progress on me boots :cheese:
    I getting there.
    613 x 767 - 83K
    541 x 749 - 373K
  • RezcaRezca Posts: 3,393
    Now these are some awesome tests.
    http://www.graphite9.com/theLab.html
    The poseable cloth simulation and the second-to-last video (A Blender fluid simulation rendered in C4D) are so much fun to watch~
  • ps1borgps1borg Posts: 12,776
    I getting there.
    Looking good :)
    thank you :) thats the base boot, I'm adding the layers of detail now and one of those leather boot wraps that will go under the straps.
    edited October 2012
    Well. Poser render. But when I save and re-load a UV problem appears: Is the same problem I saw with the Poserfusion - LW plugin so I guess that narrows it down a bit :)
    392 x 813 - 269K
    1210 x 806 - 232K
    Post edited by ps1borg on
    ps1borg said:
    Well. Poser render.
    Yay! Well done :) And it's genesis too!
    Spyro said:
    ps1borg said:
    Well. Poser render.
    Yes, early days but the tech is getting close. Problem with plugins is nobody to bug report to with any confidence heh, SNAFU :)
    edited October 2012
    That was frustrating, giving up nao. Looks like you need to reset the genesis UV's after each reload :)
    Yep, so the workaround I used with the Neanderthal is
    Save Material Preset
    Save Scene
    Load Scene
    Apply Sample Lana Materials
    Apply Sample Jeremy Materials
    Apply the saved Neanderthal Material.
    Can't do that with Poserfusion, guess it is an issue which needs fixing :)
    Immortals is on TV. Huge sets and set pieces look kind of different on a (relatively) small screen :)
  • XyetztXyetzt Posts: 27,559
    I am wishing that I could get a certain 42 inch TV. I wish I could wish on a star or something and get it.
    Save Scene
    Load Scene
    Thats a bit annoying the faulty uv i mean, so do you have to wait for a fix or something?
    Save Scene
    Load Scene
    Don't know whether you could describe it as a fault, more unexpected behaviour maybe. There are intuitively traps in the kind of programming logic "load everything in this directory", as I understand the new format works, instead of "load this particular item I specified if this condition is met". I'm sure it will all evolve. Meanwhile, haz enough problems at work, at home I want stuff to just function, in some kind of relaxing therapeutic way if at all possible, is what I always liked about the Poserverse :)
    I am thinking of asking the owner of the group home I live in if I could have a small fridge in my room so I can have milk and fruit. The milk is so that I can drink it before going to bed to help me sleep. The fruit is to help me get fresh fruit every day.
    sounds like a good idea, and you could keep your bottled water chilled.
    Jaderail said:
    Here ya go. watta and peanut. Snuggle good, nite.
    pushes button on Peanut's hand. Peanut says: some of my best friends are on sticks
    pushes button again. Peanut says: buck buck biggak
    wish all your wishes come true :)
    Peanut is a Rooster?
    yayy page 42. there was something special about 42. meaning of life or something
    render drop :smile: really long renders. min shade = 0.0, bounces = 8, irradiance cache = 100
    i put the camera in her eye, the idea we could see through her eye.
    it was a few false starts to position her to catch the mirror's reflection.
    ohmigosh, rendo halloween contest deadline is tomorrow
    1500 x 850 - 1M
    748 x 850 - 570K
    Peanut is supposedly a wuesil , tee hee, spelling on that is a guess :)
    he was making fun of Jef's name, making farm noises
  • Richard HaseltineRichard Haseltine Posts: 111,697
    They may not want food kept in rooms, but if they don't object you don't need a fridge to keep fruit for a few days.
    I just have to find a way to afford that and my new Tv.
    I want it to have milk which needs to be stored in the fridge or it will go bad.
    wheww almost finished installs. just have Tyler to do. and a few updates.
    didya know the rmp item list(hist) will sort on update date?
    i missed an update to Malik.
    Malik sits and fiddles all day :lol:
    800 x 800 - 984K
    better, not to be living with bugs again.
    :lol: :lol: it's a USB fridge
    http://www.amazon.com/Dream-Cheeky-19-Electronic-Reference/dp/B000XYN5RS
    Meh nearly 0200 and can't sleep, is really still in our garden, as if things are on pause. Haz yawns, gotta be a good sign :)
    cogitates. how to make a horizon light in poser that will glow on to a sky dome rim and on the rim of a round ground plane?
    first thought is to put point light under the ground aimed up, but the shadow going up, well, compensate with ibl light.
    hmm
    need a particle cloud to be a mist actor. a displacement map made with noise node, maybe? does displaced catch specular light?
    found my wyvern 1, he was in my Fantastx folder. doh
    i have to be strong willed and not rearrange library folders today, wastes whole weekends doing that.
    i wish poser had a taurus lightbulb/source.
    Lightwave's Node-based material system seems interesting. I've only used layered/hierarchical material systems before~
    (Like Carrara and C4D )
    Free "Terror Bird" poser model: http://www.sixus1.com/freebies-3.html
    And a free Ho-oh texture for her: http://www.sharecg.com/v/34418/view/11/Poser/ho-oh-for-terror-bird
    X3
  • JaderailJaderail Posts: 0
    Complaint: Why does this happen to me? I sit down with a simple idea for a render, I start setting up the set, then a little voice goes add this over there, so I do, then it's add that back here, so I do, before I know it it's three hours later, I've done 10 test renders, Saved the Scene File 4 or more times, and in all that time I've never even loaded a Figure. So much for the SIMPLE idea....
