Well. Poser render. But when I save and re-load a UV problem appears: Is the same problem I saw with the Poserfusion - LW plugin so I guess that narrows it down a bit :)
That was frustrating, giving up nao. Looks like you need to reset the genesis UV's after each reload :)
Yep, so the workaround I used with the Neanderthal is
Save Material Preset
Save Scene
Load Scene
Apply Sample Lana Materials
Apply Sample Jeremy Materials
Apply the saved Neanderthal Material.
Can't do that with Poserfusion, guess it is an issue which needs fixing :)
Thats a bit annoying the faulty uv i mean, so do you have to wait for a fix or something?
Don't know whether you could describe it as a fault, more unexpected behaviour maybe. There are intuitively traps in the kind of programming logic "load everything in this directory", as I understand the new format works, instead of "load this particular item I specified if this condition is met". I'm sure it will all evolve. Meanwhile, haz enough problems at work, at home I want stuff to just function, in some kind of relaxing therapeutic way if at all possible, is what I always liked about the Poserverse :)
I am thinking of asking the owner of the group home I live in if I could have a small fridge in my room so I can have milk and fruit. The milk is so that I can drink it before going to bed to help me sleep. The fruit is to help me get fresh fruit every day.
sounds like a good idea, and you could keep your bottled water chilled.
They may not want food kept in rooms, but if they don't object you don't need a fridge to keep fruit for a few days.
I just have to find a way to afford that and my new Tv.
I want it to have milk which needs to be stored in the fridge or it will go bad.
cogitates. how to make a horizon light in poser that will glow on to a sky dome rim and on the rim of a round ground plane?
first thought is to put point light under the ground aimed up, but the shadow going up, well, compensate with ibl light.
hmm
need a particle cloud to be a mist actor. a displacement map made with noise node, maybe? does displaced catch specular light?
found my wyvern 1, he was in my Fantastx folder. doh
i have to be strong willed and not rearrange library folders today, wastes whole weekends doing that.
Complaint: Why does this happen to me? I sit down with a simple idea for a render, I start setting up the set, then a little voice goes add this over there, so I do, then it's add that back here, so I do, before I know it it's three hours later, I've done 10 test renders, Saved the Scene File 4 or more times, and in all that time I've never even loaded a Figure. So much for the SIMPLE idea....
Some progress on me boots :cheese:
I getting there.
Now these are some awesome tests.
http://www.graphite9.com/theLab.html
The poseable cloth simulation and the second-to-last video (A Blender fluid simulation rendered in C4D) are so much fun to watch~
LW Adaptive Sampling (Render Settings)
http://www.youtube.com/watch?v=UgNB9tZWUmM&list=UUkf0GyZiUAj-az1iIeL0wdg&index=20&feature=plpp_video
Looking good :)
thank you :) thats the base boot, I'm adding the layers of detail now and one of those leather boot wraps that will go under the straps.
Yay! Well done :) And it's genesis too!
Yes, early days but the tech is getting close. Problem with plugins is nobody to bug report to with any confidence heh, SNAFU :)
Save Scene
Load Scene
Immortals is on TV. Huge sets and set pieces look kind of different on a (relatively) small screen :)
I am wishing that I could get a certain 42 inch TV. I wish I could wish on a star or something and get it.
pushes button on Peanut's hand. Peanut says: some of my best friends are on sticks
pushes button again. Peanut says: buck buck biggak
wish all your wishes come true :)
Peanut is a Rooster?
yayy page 42. there was something special about 42. meaning of life or something
render drop :smile: really long renders. min shade = 0.0, bounces = 8, irradiance cache = 100
i put the camera in her eye, the idea we could see through her eye.
it was a few false starts to position her to catch the mirror's reflection.
ohmigosh, rendo halloween contest deadline is tomorrow
Peanut is supposedly a wuesil , tee hee, spelling on that is a guess :)
he was making fun of Jef's name, making farm noises
wheww almost finished installs. just have Tyler to do. and a few updates.
didya know the rmp item list(hist) will sort on update date?
i missed an update to Malik.
Malik sits and fiddles all day :lol:
better, not to be living with bugs again.
:lol: :lol: it's a USB fridge
http://www.amazon.com/Dream-Cheeky-19-Electronic-Reference/dp/B000XYN5RS
Meh nearly 0200 and can't sleep, is really still in our garden, as if things are on pause. Haz yawns, gotta be a good sign :)
hmm
i wish poser had a taurus lightbulb/source.
Lightwave's Node-based material system seems interesting. I've only used layered/hierarchical material systems before~
(Like Carrara and C4D )
Free "Terror Bird" poser model: http://www.sixus1.com/freebies-3.html
And a free Ho-oh texture for her: http://www.sharecg.com/v/34418/view/11/Poser/ho-oh-for-terror-bird
X3
