Genesis Meets Poser - Introducing DSON Importer for Poser
Adding to Cart…
Am testing this... seems to load without error after updating. Thank you for the tip. Haven't yet tried the dson script, bu no error at load on a Win 7 64 bit machine after doing this... Thanks again :) Crosses fingers that the script works.
I just tried this...installing the vcredist_x86.exe fixed both the DSON and Aniblock importer! Thanks for quoting this here--I missed it trying to read everything else!
Ok. I was having the same problem. I have Windows 7, 64 bit. I used the 32 bit for Poser 9. I have it on an external hard drive. I have the Poser 9 folder. Then there is the Poser 9 Content folder. I put the DSON Importer for Poser in the Poser 9 folder. The others I put in the Poser 9 Content folder. Now it works.
For me I had to create an external Poser runtime for the Daz Studio Content. It wouldn't run in the shared content folder....
See if there are more files on the next page, or just "buy" it again here: http://www.daz3d.com/shop/daz-studio-4-pro
Re-"buying" got me the right version thx! Now off to work and see if it all goes smooth tonight (never will a Friday in the office go so slow :smirk: )
Will there be a list somewhere, that let's us know what items for Genesis, has been redone for Poser?
I'm looking forward to seeing how this works out (hopefully Daz won't have to call the Orkin Man) though after all the disappointments over the last year I'll take a wait and see position.
One question - forgive me if it's been asked (my eyes started to blur after the 9th page):
If I open a figure file in Studio and convert it for export would I then be able to open it in Poser? I ask this since I bought a figure that said it was compatible with poser (of course it wasn't) and isn't on the DSON list.
The simple answer is yes some of the other folders are essential to it working correctly in Poser. You'll find Genesis will not load if you remove the wrong folder, "data" being absolutely essential to be located next to Runtime.
What he said...the data folder especially since the genesis morph info is in that folder. _Removed because I was wrong_ the answer is you need them all....
Probably. I'd copy them to a new folder instead of move them just to be sure. As long as there aren't any .duf files it should be okay but I only see those for the actual poses.
Wish I could check for sure. Still fighting with this install.
Okay I won't have most of the rest of my genesis specific content until tomorrow or maybe even later, but here is genesis basic male in Poser.
I used the Angelo skin texture and eye color.
edit to add: That's an M4 Pose.
I have installed the plugin in PP2012 SR-3.1 x64, and the Python scripts work without errors, but Genesis and all contents loaded from that runtime leave me with an empty scene. Poser claims the figure has been loaded and the name shows at the top, but I see no figure. I have installed the "Genesis Starter Essential for Poser", adding it as an external runtime in Poser. I have also installed the DS package. I don't get any errors when I load Genesis (or anything else from that runtime), but there is nothing on the scene.
I have followed the tutorials by the book, but I suspect this has something to do with *where* I have to install the "starter essential" files. The Poser version was installed at an external runtime, and then linked to Poser.
I need some help here.
No time to go through 19 pages right now. Sorry...
I got M5 and V5 on a disc from 3D Artist magazine. Is there something that I need to do to get them updated? that's all I got on the disc I think. I bought the Evolution morphs bundle here, and other things.
Dana
Visit THIS category
You may need to send in an support ticket so they can put the pack in your account etc (may have to show proof of purchase of that magazine (though not positive what they will ask for exactly) but I am fairly certain in the past that support has managed it so you could get the updates etc if you contact them.
http://www.daz3d.com/shop/dson-all
Jay_NOLA's list of updated Genesis content (see my sig for the link) will be updated to indicate which products are Poser-compatible, but that'll take a few days.
Thanks for the render, Sunfire
You should -- what is it, and is it in .duf format?
What is the path to the external runtime?
Still waiting on an answer to that, too, Dana. I went and tracked down my disc so I was 100% sure, but I've got V4/M4 shapes for Genesis from an ImagineFX DVD. I'm wondering if anything was changed/updated, or if they're just in the category because they're something we can use with the Importer.
I just read this on page 19 Hope this helps a little :-)
Oooh. Awesomeness! (Sorry I missed that!!)
New resets/downloads for that product should be fixed now. You may still see two items titled "Benjamin for M5 - Poser Companion - Mac" but one of them should actually provide the PC (13885_BenjaminM5PoserCF_1.3_dpc.exe) version. I'll mention it to Web in the morning, to see what can be done to correct the mislabeled item.
-Rob
http://www.daz3d.com/shop/dson-all/ 58% off for Plat Club members if I am doing my math right...
Well, thanks for trying to help but its still coming up invisible.
It looks like all the structure is in there that is needed like the data folders and whatnot, it's just not connecting here. What's weird is that it is caching a DSON folder with generated geometry and pmd files and looking at the .obj it IS genesis. Just doesn't show up in Poser.
The plugin depends on the new Add-on framework that Smith Micro and I designed for Reality 3 for Poser. This framework was released in the SR3 of Poser 2012. Prior the introduction of the add-on framework there was no support for auto-loading of plugins and no support for many "hooks" in the Poser scene. For example, the new add-on framework notifies a registered plug-in when an object is added, renamed or removed. This is used by the DSON plugin to trigger the loader for the .duf files. So, there is really no way to make this happening for previous versions of Poser because the hookups are simply not there.
Hope this helps
So this is why all the stuff that had been 70% off and was supposed to be on sale until 12th has been taken off sale.
Hmm... some things that I'm already missing, Bad Guy for Genesis, David Elite for M5, M5 Elite Hair...
I really should find a better way keep track of all my genesis purchases.
Hope this helps
Nice, Paolo :-)
What department should I select for this? Sales?
Dana
Something else, as to why Poser 9 and Poser Pro 2012 is required. Previous versions of Poser do not support any kind of weight mapping. Genesis is weight mapped.
