The I Wanted Mousse But Got A Moose Instead Complaint Thread.
18687899192100
  • PetercatPetercat Posts: 2,321
    'Nother complaint:  I've decided to take my Vista machine and convert it to a Win7 machine.  But I don't want to lose my Vista configuration.  So I completely removed my Vista hard drive temporarily and replaced it with a brand new 1TB empty hard drive and used my remaining unactivated Windows7 OEM installation disk to install Win7-SP1.  Worked great, installed quickly without problems except it doesn't yet recognize my video board and has defaulted to a basic video setup but I can get 1440x900 resolution so it's workable for now.  HOWEVER, after checking that it had access to the internet I told it to start performing Windows updates and it just sits there saying it's checking for updates.  the performance meter shows one processor 95-100% busy and the other processor about 5-10% busy.  I've left the machine on hoping that it will eventually do some downloading but now it just sits there being quietly busy without any visible results.  Is this normal?
    PS: after virgin installation of Win7 it had InternetExplorer8 installed.  I couldn't get WindowsUpdate to work so I manually went to the Microsoft site and downloaded InternetExplorer11 which installed along with a bunch of needed updates and is working fine but I still can't seem to get a reasonable behavior out of WindowsUpdate..  I checked on the Internet and there are reports of similar behavior and some things to try but nothing definitive and the one patch that was suggested refused to run on my machine (says: "not for my machine").  Some people said they just waited it out.  So that's what I'm going to do.
    Whatever you do, don't ask Microsoft tech support for help. They're idiots. When I was having problems downgrading from 8.0 to 7, the conversation was:
    Them: "Well, you need to reinstall Windows 8. Your machine wasn't designed for Windows 7."
    Me "Really? Which part? The motherboard is rated for everything from Vista up, as is the processor. I don't think the memory cares, nor do the hard drives! So it must be the case that's giving me problems?"
    It got worse until I gave up on Microsoft Support. Forever..
    edited June 2016
    MistyMist said:
    ps1borg said:
    MistyMist said:
    ps1borg said:
    DanaTA said:
    MistyMist said:
    ps1borg said:
    MistyMist said:
    what is the sound of attenuation?
    Diminishing retunes?
    Victor Borge would have asked "What is the sound of aelevenuation?"
    Is that like the number 11 on Marshall Amp dials?
    sound of attenuation not louder than the sound of a generator test run?
    Attenuation is the act of reducing sound.  In other words, turning down the volume!!!  Attenuation in itself makes no sound at all, it has an effect on the sound coming from something.  The term is usually used in electronics, namely amplifiers and mixers.  Sound technicians use the word attenuator where everyday people would say volume control.
    Dana
    Wouldn't that technically be the inverse of a volume control?
    Depends on where your "normal" is.  If the signal being controlled is normally permitted through at functional levels, then you might design your equipment to "attenuate" the signal to achieve a desired effect or to match the levels of other less powerful inputs.  I've seen "Attenuation" in powers of 10 or in decibels implemented as discrete switches.  However, there's nothing to prevent it being a continuous control instead of discrete.
    One could argue that volume/amplification/attenuation are matters of semantics but I'm sure there are experts out there who know the accepted lingo better than I.
    However if you look at the basic concept of a signal it has three primary controllable aspects; Amplitude, Frequency, and Phase.  Each aspect can be modified separately.  The terms "Attenuation" and "Amplification" would seem to be applicable to the Amplitude but not the Frequency or Phase.  Whereas the Phase is "shifted" and the Frequency is "Increased/Decreased???"
    My understanding is attenuation always applies to amplitude, for example when daylight is attenuated by dust it gets darker, when clouds clear it gets lighter, irrespective of any phase or frequency shift   :) So a poesis of amplitude would be dawn, or dusk.
    the day analog public   broadcast signal died
    If you think about it attenuation might sound like a skateboard moving on a concrete slope, doppler and all ?
    tee hee
    so if the train leaves its station and the other train leaves its station
    and the trains meet,
    then how fast were they moving?
    Too fast. It was a terrible wreck, and the death toll was horrifying.
    Too many victims to render without quad Titan X'x, at least.
    Post edited by Petercat on
  • LeatherGryphonLeatherGryphon Posts: 12,137
    edited June 2016
    kyoto kid said:
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    ..if they were Amtrak Trains in Ohio, at best 10 - 12 mph.
    I hear that. sad  When I was a kid here in the '50s in western NY state, big long freight trains and passenger trains would whiz by here at 45-50 miles an hour (they had to slow down for the big curve on the west of town), many each day.  Sometimes in both directions simultaneously on the two tracks.  We even had a major accident in the middle of town once when it hit a truck on the crossing surprise  Nowdays when a train does come through (about 4 or 5 a week) it's a short freight and moving about 5 or 10 miles an hour on the single track left.  And passenger service in this area is completely gone.  The USA may have a wonderful road system but the trains completely suck.   Although I admit that when I lived in Washington DC during the '90s it was wonderful to be able to hop on the subway (Metro) system in the suburbs, travel to Union Station in Washington, take the train to Grand Central Station in New York City all in just three or so hours.  But the view along the tracks from the trains through the cities was really crappy most of the time, like I'd stepped back in time a hundred years to tar shacks and junk yard landscaping.  The trains should not have windows.
    Update on my Windows7 install/update problem.  I let my Win7 system just sit overnight saying it was checking for updates.  This morning it was waiting for me to approve an installation.  (Yea!).  According to the log it had found the updates by 2:50 in the morning.  It found 221 updates and is now currently installing them.  Yea! smiley
    edited June 2016
    DanaTA said:
    Complaint:  I had ordered a new 2TB hard drive to replace a 1TB drive in one of my external enclosures.  Everything was hunky-dory until I plugged the new drive into my 7-port USB hub.  It should have worked.  But didn't.  Then I discovered that none of the 6 (yes, six) drives plugged into that USB hub were now working.  After crawling under the desk, checking cables, and power I started methodical diagnosis.  I determined that if each of the six drives were one-by-one plugged into one of the front panel USB ports the drives each worked OK.  (whew !!) So it had to be either the USB hub or the up-connection cable. or the backside USB port on my computer, which meant more crawling under the desk.  I was almost about to brave the dust and spiders again but decided to test the hub itself a little more carefully.  I eventually determined that I could get three drives and the up-connection to work and then reasoned that inside the USB hub there must be two chips each driving four ports (7-downports and 1 up-port) and sure enough the four ports that are functional are all grouped together at one end of the hub.  So I guess I blew a chip.  I suppose that's OK, the hub is about 8 years old.  However, I'd have expected Belkin products to be a little hardier based on the price I had to pay for it.  Then I had to explain why, at one point, none of the drives were working.  I suspect that if a drive is plugged into one of the bad ports, it boogers up and jams the data bus in the hub.  But if those ports are empty then the other four work?.  Good enough explanation.  But I'm happy because I can continue my work because I don't need all 6 external drives active at one time much anymore, it just saves playing musical cables,  but I really should start looking for another 7-port hub.
    Do you have USB 3.0?  New stuff is usually built on the USB 3.0 spec, these days.  I think I still have USB 2.0 in my box.  3 is supposed to be much faster, something you'd want especially with a hard drive.
    Dana
    Currently I don't have any USB3.0 equipment.   I have several newer hard drives but my external drive enclosures that they are in are all many years old and USB2.0 only.  Also, none of my computers currently have any USB3.0 ports.  Once in a while I get in a mood where I start thinking I should get a new computer with the latest, greatest, fastest stuff but then I look at the four Win7 or Win10 computers that I do have that are working perfectly well for what I do, then I look at my bank account, and the mood quickly passes.  Computers were my life for 4 decades.  I'm over it.  Now they're just appliances.  I'm perfectly happy driving a Buick instead of Porche.  Although I do also have a couple of Model-Ts (WinXP)  in my garage. wink
    edited June 2016
    kyoto kid said:
    Why is it that are people who are supposed to be so smart act so stupid?
    At least two possibilities:
    1) The've been drinking the water.
    2) It's short-term profitable.
  • RezcaRezca Posts: 3,393
    @ the WIn7 updates:   When I was putting a dual-boot installation of it on my Win10 laptop, it took ages to find them as well. At first I thought something was broken XD
    One of the later updates though simply installs a "Don't forget that Windows 10 is here~!"  reminder that never goes away and you cant remove unless you uninstall the update (Which is okay, since it ONLY adds that one bit of nagging app).
  • TJohnTJohn Posts: 11,342
    Practicing for when I get a cell phone.
    That one true friend at work...
  • EtriganEtrigan Posts: 603
    DanaTA said:
    Tjohn said:
    DanaTA said:
    ps1borg said:
    DanaTA said:
    MistyMist said:
    watching witcher playthrough here.  running around a swamp, silver sword out, killing kikimoors
    run into bandits, switch to steel sword,
    Bandits aren't worth the fine dinnerware?   laugh
    Dana
    silver swords are more of an undead thing, you wouldn't expect the. to work on the living :)
    I don't know...being pierced with a sharp sword would hurt no matter what it's made of.  You mean if a silver sword pierced your heart or lung, it wouldn't kill you because it's silver?
    Dana
    Yeah. but bandits would want to steal the silver swords but they wouldn't steal the steel swords.  By the seashore.
    I wonder if that hurt when he did that?  laugh
    Dana
    It doesn't hurt. I suffer a similar condition (without the popping part). However, it doesn't get you many dates :/
    edited June 2016
    ps1borg said:
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    Was that a scene in The Matrix ?
    is a vague memory from an algebra exam.
    SATs woes  scored higher on the english part, not so much the math.
    can i blame the gluten?  cant imagine how much gluten they fed us kiddies back then.
    Post edited by Mistara on
    edited June 2016
    baking pron  lol  http://zsuzsaisinthekitchen.blogspot.com/
    finally, marzipan recipe no corn syrup
    iso, Book of ceremonies of the Byzantine Emperor Constantine VII Porphyrogennetos
    translated hopefully
  • TSasha SmithTSasha Smith Posts: 27,313
    Tjohn said:
    I feel like a fool.  I was waitng for the picture to finish loading but then realized it had finished loading.
  • kyoto kidkyoto kid Posts: 41,960
    ...not looking forward to the W7 pro upgrade I need to make so I can upgrade my memory just because of that (and a number will be those W10 "nag" updates).
    internet explorer now refuses to open.   I can open firefox fine but not internet explorer.
    kyoto kid said:
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    ..yeah my old neighbourhood on the south side of Milwaukee hd two sets of double tracks running north and south. One, which was only for freights, was about a block away. the other set was primarily for Chicago and Northwestern's  "400" streamliners that travelled between Milwaukee and Chicago and to points north (like Green Bay and the UP).
    Today the freight right of way is an expressway extension from downtown that ends just east of the airport and the passenger one has only one track with usually slow short freights like you mention.
    Interestingly besides the Union Pacific (which took over Chicago & Northwestern operations, Canadian National is the other major rail line in the state having taken over several small and medium Wisconsin based freight lines.
    edited June 2016
    ...97 Fs in the hood right now with the hottest part of the day yet to come (about 3 - 3.5 hours from now).
    Post edited by kyoto kid on
    edited June 2016
    Might not be such a long wait if you're upgrading from an existing Win7 Home installation.  The long wait seems to come when you install a fresh copy of Win7 from an old installation disk (mine was Win7-SP1 but it was over two years old).  It apparently has to examine your installation in great detail and then get you in the download queue for over 200 updates, and Win7 stuff is probably low priority now because they're trying satisfy the demand for Win10 downloads.  I just wish that the download tool gave more of an indication that it was actually succeeding and doing things.  A progress bar of some sort.  You tell WindowsUpdate to check and it says:  "OK I'm checking..." and that's the last you hear from it for hours and hours.
    I've gone back and gotten several more rounds of updates for my machine today and the wait isn't more than a few minutes.
  • ps1borgps1borg Posts: 12,776
    Morning. River fog laying like a fallen sky on treetops and towers and red tiled roofs a little after dawn :)
    Looked into Octane but found out it is (a) too expensive and (b) will not work with my current video card which makes it (c) too expensive
    MistyMist said:
    Providing that c is the Hippotenuse
    I just remembered to destroy the checks I desposited with my bank's app, but I am missing one or two.  I am afraid my old roommate stole them, but I have no proof.  I am afraid that my old roommate might try to forge my signature or something to cash it and then I get into trouble for double cashing a check.
  • atticanneatticanne Posts: 3,009
    DanaTA said:
    kyoto kid said:
    MistyMist said:
    ...looks like everyone else is gettng the rain we usually do.  Hoping Annie and Ed are OK.
    She was on Facebook early this morning.  I haven'g been on, but got a notice she shared something that I posted.  This was around 8:45 this am...probably my time, so maybe an hour earlier in Texas.  Strangely they are one hour behind us in time zone somehow.
    Dana
    Texas has 2 time zones, Central and Mountain.  Austin is in Central; El Paso is in Mountain.  We haven't had any flooding near our 'hood.  Awesome lightning shows have occurred though.  The creek half a block from the house isn't out of its banks.  The tower I use for Net access went down about 2 pm yesterday and wasn't back until around 10 this morning.
    I had a General Motors district manager tell me the cigarette lighter in my car broke because I had 21,000 miles on the car.
    MistyMist said:
    ps1borg said:
    MistyMist said:
    ps1borg said:
    MistyMist said:
    ps1borg said:
    DanaTA said:
    MistyMist said:
    tee hee
    I still think if you are asked for the cube root of a number, just divide the number by 3 and tick "none of the above."
  • DanaTADanaTA Posts: 13,348
    kyoto kid said:
    ps1borg said:
    Tjohn said:
    got rid of that awful roommate and now I got a new roommate but I do not know her yet.   Hopefully the new one will be better.
    Having difficulty signing into Word so I can go back to writing my book.  I am either thinking of calling it "new face" or "Zombie lifes matter"
    Edit Guess Zombie lives matter already became a meme.  Oh well.
    A little worried that you started with "got rid of that awful roommate" and ended up with zombies.
    Oh guess I rather deal with a zombie apocalypse than that girl.  At least the zombies won't lie that they want to play with your head or eat your brains.
    is easier when all you need iz a few silver bullets and a clove or two of garlic :)
    That was a great movie!
    Dana
    No more duckface!!!!   laugh
    Dana
    MistyMist said:
    ps1borg said:
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    And yet we survived and (mostly) turned out just fine!  And we rode bikes without helmets, climbed trees (well, my sister did, I didn't), played in the dirt, didn't come home until the street lights turned on, shared candy, shared drinks - out of the same straw!!!  Eeek!  How did we manage to live this long?    laugh
    Dana
