A qustion about level of detail in a model
edited December 1969 in Hexagon Discussion
I am a new modeller, however I use blender to model my work, but feel my qustion is best answered here.
None of my current purchased model props use normal maps, is there any reason for this?
The image attached is a low poly model of a fire hydrant and sidewalk within daz studio with some lighting effects.
It seems to my untrained eye that you would not use the high poly version of this model within daz as it shows at around 8,596 tris.
Within the high poly version I used sub-surface which accounts for the large number of tris, I think this would be the same as using smoothing value of around two in hexagon.
What level of detail should I be working towards for use within daz studio?
«1
  • RoygeeRoygee Posts: 2,247
    Not too sure how this relates to Hexagon?
    When I do organic modelling for animation, I normally smooth to level two. The bulldog I did in another thread here is 18K quads. V4 is around 85K, which Studio doesn't have a problem with.
    Geometric models, such as your fire hydrant, shouldn't need more than one level of smoothing, but that is up to the maker.
    I'd say it is up to the vendor whether or not they include normal maps with their product - not sure whether Studio uses normal maps.
  • SzarkSzark Posts: 10,634
    Yes Daz Studio can use Normal maps.
    I often see this disscusion about normal maps and they always seem to be a common concensus that normal maps are good for games or animation but when it comes to quality rendering Bump and Displacement maps are far better at giving better results.
  • edited December 1969
    Thankyou for the reply, to me it seems the level of detail used is a midway between high poly and low poly with the use of bump and displacement maps.
    Both the props shown are for use within Unity 3D hence my use of the normal map.
    So if I were to increase my current level of detail and use bump and displacement maps would this then be the correct approach?
    I could also inclued the normal map within the texture map images, however you would not assign this map within daz studio.
    The product would then be marketed for use in unity, altough I do not think daz studio allows the use of the model mesh?
    ASFAIK you are only allowed to use the rendered images.
    Normal maps are specifically for giving detail to low-poly meshes - think of them as super-bump which reflects light in 3D as opposed to bump maps which only reflect in 2D. The original application was to use a method of transferring the surface detail from a very high poly mesh to a low poly copy. This method gives a lot more detail than a bump map can.
    Then came methods of converting 2D images to normal maps - results can be pretty iffy and on the whole I agree with Szark that in general you can get better results using bump maps - it really depends on how well the 2D image is converted.
    Displacement needs a pretty dense mesh to get good results and it does that by adding even more actual mesh, so no good if you are using the actual mesh in a game. If you are only using rendered images, then a good displacement map would give you the best results. From what I have read, but never tried, is that Daz Studio gives very good results using displacement - I've never had a decent result in Carrara.
    Something that I never see written about in the forum is Hex's ability to export a bump map of a high poly model for use on the low poly original. These can be used as displacement maps or converted to normal maps.
    Yeah the 3delight render engne is good at transforming a mesh into a higher resolution mesh at render time making good use of displacement maps but as far as I am aware Carrara doesn't. So in Carrara the mesh needs to be a high resolution to effectively use displacement maps. I think I heard on the Carrara grape vine that this was to change in Carrara.
    I use Bitmap2Material from Allegorithmic http://www.allegorithmic.com/ but would be intrested in learning more on Hex's ability to export a bump map of a high poly model for use on the low poly original. These can be used as displacement maps or converted to normal maps.
    Thankyou all for your time and help
    Here's a quick and nasty example to illustrate the steps - hopefully the pics are in the right order:)
    1. Put in a cube and tessellate three times to give it some polys to work on. UV map it - very important - so that none of the faces are overlapping.
    2. Took it up to level 2 smoothing, with DG active and gave it a good going-over with the displacement tool to get it really roughed up.
    3. Exported the bump map
    4. Dropped the smoothing to 0 and collapsed DG. Exported as .obj.
    5. The bumpmap it generates, with contrast and brightness enhanced in Gimp to over-exaggerate it for demo purposes.
    6. The render in Carrara - the same cube, one with bump applied - both have 96 polys.
    The bump map can be used in the displacement channel or converted to a normal map.
    800 x 600 - 20K
    1024 x 1024 - 29K
    800 x 600 - 72K
    800 x 600 - 72K
    800 x 461 - 25K
  • Joe.CotterJoe.Cotter Posts: 3,361
    Roygee said:
    ...The bump map can be used in the displacement channel or converted to a normal map.
    Converting a bump map to a normal map doesn't make sense to me. What purpose does it serve to convert a 2d map to a 3d map with no additional 3d dimension data (since the 'bump map' only has a 2d dataset.) It would seem that it only makes sense to use a normal map that was created from the original high detail 3d object.
    edited September 2012
    Exactly what we were saying above
    Converting to normal map, you can get some extra artificial detail. I'm thinking here of a brick wall. With a bump map, you get good detail on the face, but the corners show a sharp edge. With it converted to normal, you can get the effect of the bricks at the corner appear to be separated by mortar - not much of a difference, but maybe enough to be more believable.
    800 x 600 - 85K
    Post edited by Roygee on
  • PendraiaPendraia Posts: 3,598
    edited October 2012
    Hi Roygee, how do you export the bump map? I can't see an option under file export...sorry just found it on the uv and paint tab.
    Post edited by Pendraia on
    Hi Pendraia
    This I've only mentioned as a curiosity - it really isn't much good and I've never found a useful application for it. Blender does this function far better and if you can understand the highly technical UI and poorly translated Spanish instructions, X-Normal is really good.:)
    Roygee said:
    Hi Pendraia
    Thanks Roygee...I have never been able to fathom out the UI on Blender. It makes my head hurt to look at it...
    I do have zbrush which you can do really good displacement maps with(at least thats what I've been told. I'm still working on learning how to use it. I was just really suprised as I hadn't noticed it in Hexagon before...
    Thank you for your time and tutorial on hex`s abilities.
    To be honest I found x-normal to hard to follow :(
    I will stick to my choice of B2m as it can quickly generate all the maps I need.
    I am currently working on the custom chopper and the modelling is complete, image attached.
    I find myself somewhat back at the start this model would be the high poly version, verts 159856, faces 157064.
    I have tested the model as is without textures in daz with no issues loading the model.
    If I wish to sell this model what level of detail should the finished model be?
    Are there any guidlines on levels of detail for submission as a new vendor?
    1600 x 900 - 413K
    If you have Z-Brush, that is all you need - wish I could afford it:)
    Blender - well...yeah. Whenever I'm feeling brave I dust it off and have a go. Slowly getting to grips with it - I can at least now do a reasonable retopo.
    What is this B2M of which you speak? Googled it and got nothing that had any connection to CG.
    Hopefully one of the PA's will help you out as to requirements for selling through Daz. May be better to ask Daz directly for guidance.
    BTW, I've just come across a tute at CGTextures on making normal maps from 2d images that proves a well-made normal map can be very effective.
    Roygee said:
    If you have Z-Brush, that is all you need - wish I could afford it:)I bought it through DAZ for about $150 or I would never have been able to afford it either ; ) I think it was either the same year or the year after they had hex for $6. I've had it for a while now. I just wish I had time to sit and learn all the programs I have properly...I'm hanging out until I can retire and play all day with them.
    You're braver than I am then and probably a lot smarter...; )
    The B2M details are found here below.
    I am only using blender now for about 5 months and have never modelled before so i am quite pleased with the custom chopper.
    Recently the penny dropped so to speak and I now understand the basics, hence the chopper model.
    Hopefully one of the PA's will help you out as to requirements for selling through Daz, maybe one might read this post and help me out ??
    altough i may have a long way to go before becoming a vendor, but it does not hurt to at least try.
    Thank you all for you help and support and time
    regards
    colpolstudios
    Aaah yes, their products are really good. Thanks for the link:)
    A update on the custom chopper can be found here http://www.daz3d.com/forums/discussion/10208/
    I wish to state sorry for my post here in the hexagon section, but there does not seem a better place to get the advice and help that I need.
    My biggest issue at present is currently when I export my model no matter were I place the point of origin, The point of origin always comes in at the daz scene origin.
    My issue is this, I want to rotate the front handle bars with the wheel to represent turning, but I need the wheel to rotate around to show it spinning.
    Advice and help needed to do this, correctly.
    most likely I will have the same issue with the rear wheel but without the need of the turn function.
    your time and help is most welcome.
    Firstly, any application will place the pivot point - or hot point - in the centre of the bounding box, regardless of where you may have changed it to in the modelling app - that is the nature of the beast.
    Daz Studio handles objects very simplistically - it reads it as a single entity. To get the handle bars, with wheels etc. turned, you'd have to do some pretty sophisticated rigging. I doubt very much that Studio has a spin function - although there may be a plugin I don't know about - there are so many:)
    Carrara, for instance, gives you the option when importing, to import as a single entity or as groups. You would then group the front wheel assembly, set the pivot point to where the forks meet the frame and pivot the handle bars- this is not possible in Studio. Carrara also has a spin modifier to get the wheels turning.
    If this is for a still shot, you should pose the handle gars turned in your modelling app - pretty simple to do in Hex. If it is for animation, you would need to rig it. About the only way to simulate wheels spinning in Studio would be to make a circular plane with a spin blur texture on it.
    Just curious - Blender has everything you need to do what you want - why not use it?
    Re: Just curious - Blender has everything you need to do what you want - why not use it?
    I wish to sell at some point my models created in blender, so I need to know how to set up the model correctly.
    I have succesfully grouped the model into frame, forks, rear wheel, font wheel.
    I used daz exporter to export the moel to the correct scale for use in poser.
    I have brought these sections of the bike into poser 8 and checked the groups with the group tool and everything so far looks good.
    I have been scanning through the poser ref and tutorial manual,but find it hard to follow as they only speak of characters.
    I will set up the frame as the root within the Hierarchy and parent everything to this.
    I am thinking It may be better or easier to use PhiBuild to set up the Hierarchy, advice please.
    To be honest all I really want to start with is for the wheels to rotate using a slider and for to be able to turn the handle bars with the front wheel.
    Questions:
    I am thinking I will need a bone between the frame and the forks running down, like a pin so to speak in order to keep the handlebars located in postion but still to be able to rotate them?
    I will also need a bone going through the forks and the front wheel, I think?
    The wheels should not really need to be rigged as long as the point of origin is centered i can use the param for this?
    Any and all help much needed.
    with kind thanks for your help and patience with me up to this point.
    Sorry - I know nothing of Poser, so must wait for someone else to jump in. What I do know is that Poser and Studio use pretty much the same rigging system and what you are proposing sounds about right for Studio, so should work. The only problem I foresee is to get the pivot point of the forks in the correct place for the rotation of the handle bars to turn the wheel. Possibly Poser has a method of moving the pivot point - Studio 3 has a plugin that can do this, but I don't know if this was updated for 4.5.
    Maybe you would get more satisfaction by asking in the Poser forum?
    Good luck with the project:)
    You can use the Joint Editor tool built in to DS4/4.5 Pro to move the Pivot Point.
  • edited October 2012
    I think you may be making things a LOT more difficult than you have to, Col.
    Putting bones on an item in poser requires turning it into a figure, and there's all kinds of crap you have to adjust once you do that.
    But a bike is a mechanical device that doesn't need "zones" or anything else to make it work.
    A bike is made up of 4 things: 2 wheels, a fork and a frame.
    The little section where the fork shaft passes through on the frame is called a "head tube", and is angled around 30 degrees or so.
    When you make the fork in hexagon, make it so that the shaft that passes through the head tube is vertical, and aligned at "0" X and "0" Z cordinates. This is VERY important because when you export it as an OBJ and then import it into Poser, the "yRotate" dial will cause the fork to rotate around that point. When you xRotate the fork in Poser so that it aligns with the head tube, the fork's Y-axis will rotate with it, and the fork will rotate (turn) properly in the head tube.
    So make your fork as outlined above and export it as an OBJ.
    Now make a wheel making sure its center hub is aligned at "0" X and "0" Z, and export it as an OBJ too.
    And of course, make your frame, making sure it's aligned at "0" Z (the other axes are irrelevant since the frame will be the main body around which everything else works).
    In poser, import your fork.
    Now import a wheel.
    Align the wheel to the fork, and then parent the wheel to the fork.
    This way, the wheel will turn in the fork using the zRotate dial. When you turn the fork using the yRotate dial, the wheel will turn with it.
    Now import your frame and the wheel again as the rear wheel.
    Align the wheel to the rear fork of the frame and parent the rear wheel to the frame.
    Now align the fork to the head tube using your xTran, yTran and zRotate dials. The front wheel will follow the fork.
    Once the fork is aligned to the head tube, parent the fork to the frame.
    When I say "parent to", that's technically backwards, but I think you know what I mean. In the end you should have the frame as the parent to the rear wheel and also the parent to the fork. The fork should be the parent to the front wheel.
    Now when you move the frame, the whole bike goes with it. Turning the fork left or right using the yRotate dial turns the front wheel with it, and each wheel can be rotated using the zRotate dial.
    Now you can save the entire bike as a prop and you don't have to worry about bones or anything.
    Post edited by emfederin_9bc0c524c8 on
    hi, thankyou for your time and help.
    Ok first off heres what I did.
    Poser 8
    I imported the model frame first then the forks then the front wheel and last the rear wheel.
    I selected the forks and parented them to the frame, then selected the front wheel and parented it to the forks.
    I then selected the rear tyre and parented it to the frame.
    I can now move the forks with the tyre and i can rotate the tyre.
    I opened the props section and selecting the little pluss icon and I added the bike, i checked all the boxes for the subsets.
    rear wheel,front wheel,forks and the last was the frame.
    I opened daz and loaded this model into daz, the origin for the wheels is set correctly ie in the middle of each wheel.
    Also in the correct place for the frame.
    However the origin for the forks I think is not correct.
    When i move the forks using the y rotate it rotates but away from the bike frame. The front wheel moves as well so I am getting somewhere.
    I have been re-reading your help and think now I know were I am going wrong.
    I do not have a shaft on my forks, I just have a top and bottom, but I have blender, daz and poser open at the moment and just checked.
    Altough I do not have, The little section where the fork shaft passes through on the frame is called a “head tube”, my forks are aligned at “0” X and “0” Z cordinates.
    This leads me to think. I need to adjust the point of origin on the forks, before I parent the wheel.
    I am really sorry for all the mistakes I am making.
    But ith your help I feel I am getting closer.
    Just to keep things straight in my own head, by "daz", do you mean daz studio or daz hexagon? When working with multiple daz apps, it's best to signify "DS4" or "hex", etc.
    However the origin for the forks I think is not correct. When i move the forks using the y rotate it rotates but away from the bike frame
    It's not the origin of the forks that's important here, it's the origin of the axis around which the fork rotates, and I have a feeling this is where you're going astray, which I'll address in the following paragraph.
    I do not have a shaft on my forks, I just have a top and bottom...I do not have, The little section where the fork shaft passes through on the frame is called a “head tube”, my forks are aligned at “0” X and “0” Z cordinates. This leads me to think. I need to adjust the point of origin on the forks, before I parent the wheel.
    Okay, even though you have no shaft per se, there's still a virtual axis that runs between the handlebars and the wheel fork where the shaft would be if you had one. And this axis is CRITICAL: it MUST be VERTICAL before saving as an OBJ file, AND it must be positioned at 0 X and 0 Z. Remember we're talking about the position of the AXIS, not the entire fork object. This is where Poser gets the Y-axis of the OBJ from when you import it. Once imported, you can rotate the fork section along the Z axis to form the proper angle to the frame, and Poser will automatically maintain the Y-axis along the fork.
    No apologies necessary - that's what the forums are for, and we love trying to figure this stuff out!! :)
    Just did a quick check in DS4.5 - you don't even need to use the joint editor to move the pivot point. Simply select the pivot point and move it to where you want it - even off the model altogether. This opens up a whole new way of doing some things - I'm impressed!
    Sorry for the confusion I mean DAZ studio and not hexagon.
    Ok, i think
    I understand, unfortunate, I have the forks saved with and angle and rotation applied with (the file I am working with).
    The brackets indicate I can change this in my blender file.
    I believe I can set up the forks as you suggest without any rotation.
    But to be honest I still cant get my head around this.
    What if, you PM me and I send you the model.
    I wish to learn and you seem to have the answers.
    Thankyou for your time and kind help with me so far.
    afreaginname, I have sent you the bike download details by pm.
    Thank you so much for this very kind offer of help
    JEEEZZZ!!!! SEVENTEEN FREAGING MEGS??????????
    Your "level of detail" is INSANE!!!! It crashed my Poser Pro!!!
    BTW and FWIW, it may be of use to know that OBJ files are text files. What that means is that you can ZIP/RAR them and make files MUCH smaller than the actual OBJ files are. You'll see what I mean when I return them to you as RAR files.
    Okay, now that I've got that off my chest, we can move forward. :)
    There's a few problems I've encountered with your model with respect to certain elements not being zero'd with the Z-axis.
    For instance, your bike frame is zeroed, but the head tube was not, and neither was the bar the head tube is attached to. These 2 items are shown in my first image. I zeroed them both for you.
    Also, from the standpoint of physics, there was another "problem" on the head tube. As shown in my second pic, the ends of the tube were not square-cut to the head tube. In the "real world", this would cause problems with shaft rotation, so I realigned the ends for you as well.
    These 2 problems were the only 2 on the frame, but there are many more I found on the fork and that will take me awhile to adjust and document for you. But the good news is that I've already made some cursory checks, and I can tell you that the problem is 100% soluble.
    When I'm finished, will I be able to upload my RAR file to you on that website?
    562 x 433 - 41K
    481 x 390 - 53K
    In post #25 I made the following claim:
    ...there's still a virtual axis that runs between the handlebars and the wheel fork where the shaft would be if you had one. And this axis is CRITICAL: it MUST be VERTICAL before saving as an OBJ file, AND it must be positioned at 0 X and 0 Z. Remember we're talking about the position of the AXIS, not the entire fork object. This is where Poser gets the Y-axis of the OBJ from when you import it
    I've discovered this is only half right. I'm right that the head tube axis (regardless of its being real or virtual) must be vertical prior to saving the fork.
    However, I'm dead wrong "about the position of the AXIS, not the entire fork object". Poser doesn't give a damn where the Y axis was located in the source program. Instead, Poser insists on centering the fork around its "center of mass". The equivalent term in hexagon is "bounding box" which does in fact mean "the entire fork object". This means that Poser's center of mass is located slightly forward of the head tube axis, and when you yRotate the fork, the head tube revolves around the errant Y axis.
    So I've managed to come up with a way of "tricking" Poser into seeing the center of mass as being down through the center of the head tube instead of down the center of the main fork body. It's a kludge, but it works quite well and the fork now rotates around the head tube.
