mcjTransport, model/animate spline based tubes - Version 1 is out !!
13»
    Is the plugin coded so that an extension could be written to use SVG files for path input?
    Kendall
    Shhhh!!!!!!
    We want him to finish it up sometime in the near future (although that would be a great feature to have...)
  • mCasualmCasual Posts: 4,160
    Kendall
    it's a script, so someone could write a curve importer, though that someone would probably be me
    another solution is to write a script that converts svg to the text format i use (shown below )
    and have the ability to select one curve from the many in the svg file
    i didn't know about svg, but if i guess it would be a good choice ... someday someday :)
    type mcjLathe
    vrsn 2009.11.25
    twld false
    bwld false
    clsd false
    nsds 8
    nsgs 1
    v 0.5 0.5
    v -0.45 0.5
    v 0.27 0.508
    v 0.5 0.50
    v3d 0 0 45.59
    v3d -42.1 0 45.59
    v3d 0 0.00 -46.2
  • Kendall SearsKendall Sears Posts: 2,993
    edited September 2012
    Kendall
    type mcjLathe
    vrsn 2009.11.25
    twld false
    bwld false
    clsd false
    nsds 8
    nsgs 1
    v 0.5 0.5
    v -0.45 0.5
    v 0.27 0.508
    v 0.5 0.50
    v3d 0 0 45.59
    v3d -42.1 0 45.59
    v3d 0 0.00 -46.2
    I was just wondering if someone like me could write an import routine. Is there any docs on your import data? Is there a way to set the diameter of the line in the txt file? Can it handle complex paths? Multiple paths? If no on the multiple paths, is there a set reference point so that multiple runs could create colocated tubes?
    EDIT: There are *many* projects that I could use this for if only I could get a SVG file into it.
    Kendall
    Post edited by Kendall Sears on
    Kendall
    the format was established when i wrote mcjLathe
    a few named parameters, followed by a list of vertices, the x coordinates range from -0.5 to 0.5 the y coordinates range from 0 to 1
    if you run mcjLathe ( https://sites.google.com/site/mcasualsdazscripts/mcjlathe ) or mcjSuperLathe ( https://sites.google.com/site/mcasualsdazscripts/mcjlathe ) you can save the curves you create to disk and inspect them
    indeed there's only 1 curve per file
    i was thinking .... maybe i could write a dxf importer since eons ago i wrote one. and i would think there' svg-to-dxf converters floating around the internet
    the index for my web site is https://sites.google.com/site/mcasualsdazscripts2
    here is a complete 4-points curve from ncjSuperLathe
    type mcjLathe
    vrsn 2009.11.25
    twld false
    bwld false
    clsd false
    nsds 8
    nsgs 2
    note vertex coordinates: first column is x second is y
    note X must remain in the [-0.5,0.5] range
    note Y must remain in the [0.0,1.0] range
    v 0.5 0
    v 0.15 0.15
    v 0 0.5
    v 0.15 0.85
    v 0.5 1
    the new upcoming script, mcjTransport involves 3D curves,
    so i append the 3D coordinates using the new token "v3d"
    type mcjLathe
    vrsn 2009.11.25
    twld false
    bwld false
    clsd false
    nsds 8
    nsgs 2
    v 0.5 0
    v 0.15 0.15
    v 0 0.5
    v 0.15 0.85
    v 0.5 1
    v3d 0.5 0 0
    v3d 0.15 0 0.15
    v3d 0 0 0.5
    v3d 0.15 0 0.85
    v3d 0.5 0 1
    Post edited by mCasual on
    i'm giving it another go today, remember the 'monotone' feature, which removed "kinks" from the tube's path,
    well it's not an integral part of the mcjTransport yet.
    There's that and not much more left to do.
    So hopes are high ... as a kite.
    nah hopes are up in a lemon tree
    and today's song is http://www.youtube.com/watch?v=IsP8r3X_VfY
    ( the original being http://www.youtube.com/watch?v=phEnpdDusss )
    1280 x 720 - 114K
    news
    Catmull-Rom splines ( http://en.wikipedia.org/wiki/Cubic_Hermite_spline ) will be used instead of Studio's animation curves
    this, to make neat looking loops ( closed paths )
    shown below: a 30 frames long, 4-keyframes closed path
    other news is, the path monotonizer function is now part of mcjTransport
    800 x 800 - 90K
    news from the coding front
    the part of the script that ensures clean looping paths was tested some more and corrected
    and i'm thinking about adding SecondLife Sculpties export
    here you see a 4-keyframes path ( the tube on the ground ) using the Catmull-Rom spline
    ( the head of Disney/Pixar http://en.wikipedia.org/wiki/Edwin_Catmull
    is a computer scientist/mathematician and he developped that spline,
    which is a variant of Hermite Splines )
    800 x 800 - 61K
    800 x 800 - 203K
    that's the test scene for
    - the functions that let mcjTransport export animated-marker-paths as 2D and 3D curves
    those 2d curves can then be re-used by mcjTransport, mcjLathe and mcjSuperlathe
    - the functions that let mcjTranslate use 2D curves created by mcjTransport, mcjLathe and mcjSuperlathe
    not sure when it will all be ready, so i wont give deadlines :)
    1280 x 720 - 62K
    1280 x 720 - 123K
    1280 x 720 - 154K
    that's a 368-segments path, created with the help of the mcjCollider plugin ( for DS3 only )
    the collider was colliding against the torso nodes of the mcjA3Maillot figure
    the collider was parented to a camera which was parented to a null, which was going up down up while rotating 4320 degrees
    the null's animation was linearized using my setInterpolation script
    i selected the collider node and ran this script shown below
    for each frame, the script moves the collider back to the camera and points it straight ahead at the figure
    then it fires the collider which moves to the surface of the figure
    one could use this method and mcjRibbons, mcjTracePath ( or soon mcjTransport ) as a base for creating clothes
    or to lay roads on an uneven terrain
    note that since her movements are not hindered this does not count as bondage, so there
    the second image, the animated gif, was done by animating the "vertical tile offset" parameter of the surface material. using the matAnim script
    // DAZ Studio version 3.1  filetype DAZ Script
    var tick = Scene.getTimeStep();
    var node = Scene.getPrimarySelection()
    var range = Scene.getPlayRange()
    var startFr = range.start / tick;
    var endFr = range.end / tick;
    var zeropos = DzVec3( 0, 0, 0 );
    var xr = node.getXRotControl()
    var yr = node.getYRotControl()
    var zr = node.getZRotControl()
    for( var i = startFr; i <= endFr; i++ )
     Scene.setFrame( i );
     processEvents();
     node.setLocalPos( zeropos );
     xr.setValue(-90)
     yr.setValue(0)
     zr.setValue(0)
     node.activated();
    364 x 599 - 630K
    1280 x 720 - 262K
    If you animated the Ambient, you could make it look like she's wearing blinking lights...
    with randomized tiling offsets and noise we get glitter
    ( this post's music background is http://www.youtube.com/watch?v=dCIMqI39DCI )
    364 x 600 - 585K
    Looks like a fun way to do a Christmas tree...
    Extrude a tube around the tree...use matAnim to animate a color pattern...make an animated gif...presto, blinking lights on the tree!
    ~ breaking mcjTransport news ~ ~ breaking mcjTransport news ~ ~ breaking mcjTransport news ~
    i will be posting the first version of mcjTransport this evening ( it's now 6:32 pm )
    and i'll complete the user manual
    so, you'll have to keep an eye on this thread to get the finished manual and possibly re-download the script
    600 x 800 - 103K
    - Release -- Release -- Release -- Release -- Release -- Release -
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport
    Here's version 1 of mcjTransport
    it was developed on Daz Studio 3.1 advanced, so that's where it was the most tested
    i did some tests on Daz Studio 4.5 and will do more tonight.
    i included a version for Daz Studio 1 and 2 but did not test it at all yet
    so, stay tuned to this thread for new versions of the script and the manual
    fig. 1 : a 7-keygrame path, with a 10-turn twist added
    600 x 600 - 48K
    ~ update ~~ update ~~ update ~~ update ~
    the version for Daz Studio 1 and 2 now works
    the version for DS3, 4, 4.5 had a tiny change to prevent accidental creation of monster tubes encompassing the known universe
    the manual was improved
    __________________________________
    version history
    sept 24 9 pm Version for DS1 and DS2
    sept 24 early morn. Version 3 limited the maximum segments to 4096 to prevent accidents
    sept 23 9:15pm Version 2
    sept 23 9pm Version 1
  • Silas3DSilas3D Posts: 167
    This looks fantastic! Am I right that the item created is physical geometry, and would therefore be renderable (is that even a word?) in Lux through Reality?
    edited October 2012
    it creates and loads an obj file, which is like a prop, with a morph channel,
    so, renderable using any renderer inclusing Reality
    ( the renders in this forum thread were done using Blender Cycles via mcjTeleblender )
    1280 x 480 - 101K
    edited October 2015
    upcoming update
    very soon i'll post an update for mcjTransport
    it will fix  z-steering, which may be broken in the current version
    it will have normals inversion, so, for example the interior of a tube is deemed the "outside"
    this has serious implications, with some shaders where the "inside" surface of an object is rendered all black, or in the case of Poser, it's invisible in the preview window
    you'll also get a MirrorUVs and FlipUVs option, which was used here to get non-inverted text inside a tube
    ( maybe i'll add a swapUVs which is like a portrait/Landscape option )
    note that mcjTransport was recently used to make shoe straps shown here
    1920 x 1080 - 416K
    1920 x 1080 - 1M
    edited October 2015
    in green you can see a shaped tube created using an animated null and mcjTransport
    it was saved as a shape file
    which was then used to create the S-shaped road - the blue rectangle is the animated object that gives us the S-Path
    and mcjTransport builds the road around that
    the old version of mcjTransport for Daz Studio is on my web site (since 2012 ) it does work but has some features that dont
    so i'm in the process of fixing bugs
    once that's done i'll modify this post you read
    then i'll work on the final version of the free high heel sandals for Aiko3
    1920 x 1080 - 451K
    mcjTransport news : still working on it AND in the future there will be a script named mcjEdgeWalker
    which will help you create path/animations that follow the edges of objects ( the edges you see when your preview is in Wireframe mode )
    and since mcjTransport can build tubes along paths, you get this :
  • Oso3DOso3D Posts: 13,667
    What's the current state of this?
    edited October 2015
    Tonight ( next hours ) i'll post the update
    the most important repair was the "z-Steer" option
    by default the script builds tubes that have as little twist as mathematically possible
    but , to make shoe straps and belts you need control over the twist/roll/banking so this will be fixed
    and there will be normal-flipping and UV map options
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport )
    t
    UPDATE V2.0 UPDATE V2.0 UPDATE V2.0
    mcjTransport v2 Free Script for Daz Studio ready !
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport?pli=1
    Thank you! It looks really intriguing, if I can figure it out. ;)
    edited October 2015
    here's a quick basic test to do
    create a null
    at frame 15 of the timeline, move the null to x,y,z = 0, 0, 100
    go back to frame 0, move the null back to 0,0,0
    go to frame 30, move the null to 100,100,100
    go back to frame 15, set it back to 0,0,100
    keep the null selected
    run mcjTransport
    if it's not already there, set "segments" to 30, since you have 30 frames
    press the "build" button
    nothing moved ! because all you did was to create an zero-sized tube, but that tube has 30 rings and is ready for the next step
    press the "update tube" button
    you created a tube !
    personally i use scripts like mcjDecimate to help me create the animation paths
    for our example, i would have used mcjDecimate to "pin down" the positions of the null, every 15 frames
    which would have saved me that little timeline back and forth game we had to play
    i also use
    mcjParent mcjCycleFilterSetInterpolation
    with more keyframes and subD
    800 x 443 - 82K
    edited October 2015
    Update v2.1 Better Bends Update v2.1 Better Bends Update v2.1 Better Bends
    whether you have mcjTransport 1.0 or yesterday's v2.0, you want v2.1 because it has better bends
    you're kind'of lets say nerdy or curious
    and want details about that "better bend" statement?
    well glad you asked
    you created an animated path
    lets call the animated object "the marker"
    At the start of your path, at frame 0,
    mcjTransport positions a ring of vertices in world space
    they form a disk that faces the next position of your marker at frame 1
    lets call the orientation of the disk (normal) n0
    at frame 1 mcjtransport remembers your heading at frame 0
    and computes the heading from the position of your maker
    at frame 1 to the position of your marker at frame 2
    we will call this orientation n1
    mcjTransport copies the ring of vertices from frame 0
    it moves them to the position of the marker at frame 1
    it rotates them according to the angle between n0 and n1
    so it's like the vertices are displaced and rotated along your path .... transported
    mcjTransport v2.1 uses a better method to orient the rings of vertices
    v2.0 was doing it wrong
    as long as the  lengths of the tube sections was not changing abruptly, it didnt make much difference
    more details!? you want more details ?!?
    say we have p0, p1 and p2, the positions of the markers at frames 0,1,2
    say it's a hard-right turn
    n0 = p1-p0 = [0,0,2]
    n1 = p2-p1 = [1,0,0]
    in version 2.0 i was doing
    heading at p1 = (p2-p0).normalize = [1,0,2].normalize
    but in version 2.1 i do
    heading at p1 = (n0.normalize+n1.normalize).normalize = [1,0,1].normalize
    so at p1 the tube ring will be Y-rotated with an angle of 45 degrees which is nice ... no kinks in our garden hoses
    1920 x 1080 - 427K
    edited October 2015
    Update v2.2 Because v2.1 has a bug!!!!
    sorry about this !
    if you downloaded version 2.1, it's probably unusable !
    explanation:
    when i did the changes from version 2.0 to version 2.1
    mcjTransport worked fine on my Daz Studio .... but only because Daz Studio was remembering things i has done earlier that day
    edited September 2016
    WARNING
    the zero-tube creation phase crashes Daz Studio if it's in iRay-Preview mode
    because probably it can't handle zero-volume objects
    i'll try to have an update soon
    800 x 600 - 10K
    UPDATE UPDATE UPDATE
    The Fantabulously powerful mcjTransport script was updated
    If you try creating a tube using mcjTransport while the Daz Studio preview mode is iRay, the program will very likely freeze
    so now when mcjTransport sees that your 3DViewport is in drawStyle 6, it snaps it to style 0, then style 8, so it's not in iRay mode anymore
    1080 x 1080 - 1M
