Render problem
Super cheese sandwich
in New Users
Hi! I have recently downloaded this: http://www.daz3d.com/fantasy-and-sci-fi-effects
Whatever color I choose It's always grey when I render it. How I can fix this?
Thanks!
500 x 650 - 18K
1366 x 728 - 210K
This is a Poser product, and it says on the product page "This product does not work in Daz Studio without manually adjusting the material settings.".
Also, you are probably trying to render in Iray, which might botch up things additionally.
EDIT:
Product that work well are Jepe's Z series: http://www.daz3d.com/catalogsearch/result/?q=jepe
Examples (they include Iray settings):
Also, you can use these (3DL version, but can be easily converted to Iray):
This could work? http://www.daz3d.com/jepe-s-elementz
I don't know how to adjust it manually. Please help
Thanks!
I have almost all of Jepe's stuff, and it is very easy to use. They come with shape morphs, and brightness adjustments. You can scale them up or down to your needs. If you run into a problem using them, just let me know. I am currently running a render, otherwise I would give you an example of usage.
Here's an character test render example of my character Theodoar Aidan using the Flames from http://www.daz3d.com/jepe-s-flamez-iii-df used to enhance a crystal sword.
Thanks BeeMKay! I just want to replicate the shot effect in the image attached
Do you think that this is the right one? http://www.daz3d.com/jepe-s-elementz
Yes, that one should work nicely.
You'll have to be careful with the angle. You are working with a plane, so if it's not placed precisely in relation to the camera, the look will be off.
Thanks BeeMKay!
Hello everyone,
I recently bought HeroFX Alchemy and MagicFX and Hero FX Expansion Comp2 and can't make them work. It is not actually a problem with rendering, I can't even get them in the scene. I started with DS three months ago so until recently I had DS version 4.15 and got 4.16 when it was relised. I tried these 2 products only in 4.15 only. I am wondering are they too old for newer Daz updates, do I need some other product in order to get these work or is there something I should know about how to make them work and load in the scene.
I like these products and would like to use them, but if I can't use them I would gladly return them because I don't need yet another item that doesn't work.
Thanks, any help is welcome!
