How to find out the height of my character
I need to figure out my character's height.  Is there a way to pull the real-world equivalent height from inside DS 6 ?
  • crosswindcrosswind Posts: 10,318
    If without using Measure Metrics plugin ? You can use a primitive plane + Align plugin, i.e. stack the plane onto your character, then check Y Translate of the pane... as shown in the attached screenshot
    There'll be a tiny variance comparing to using Measure Metrics... but the measured value can be still usable.
    2016 x 1294 - 261K
    Thank you.
  • jmucchiellojmucchiello Posts: 2,307
    edited August 26
    • T pose (or A pose) the figure. (No shoes)
    • Ctrl-D the figure, just in case
    • child a horizontal plane at y=0 to the figure
    • Set figure's x (or z) rotate to 180
    • Ctrl-D the figure
    • unparent the plane
    • y of plane is height of the figure.
    Post edited by jmucchiello on
    • Ctrl-D the figure
    OK, Thank you. Makes sense
  • make a cube 1 foot x 1 x 1
    next to character scale on Y until cube and character same height read the num the number 500 is 5 ft /550 is 5-6 /525 is 5-3 /575 is 5-9 /600 is 6 ft tall.
  • jmtbankjmtbank Posts: 189
    I haven't tried this prop. Looks free. I was searching for the one I use when I found it instead. There should be quite a few similar ones out there:
    https://www.daz3d.com/forums/discussion/28637/mwall-prop-for-daz-studio-measuring-tool-and-mwall-2-0
    Heres another one.
    https://www.renderosity.com/freestuff/items/78860/measurement-bar
  • @jmtbank - thank you for those links
  • kyoto kidkyoto kid Posts: 42,443
    edited September 5
    ..there is also this
    https://www.deviantart.com/heryun/art/Daz-Freebie-Stadiometer-923869898
    I tested it with several base Daz G8 characters  and it is very accurate (note for G8 ad 9 characters the legs must be together - this can be done in Pose Controls/Legs)
    The height readings on the scale are in metric so you have to convert from/to English measure. It doesn't require using Iray view mode to read so it's easy to easier make height adjustments to the character.
    Here is a link to a thread post that has a list of female character heights  This is what I used for the tests.
    https://www.daz3d.com/forums/discussion/comment/4914946/#Comment_4914946
    I've been using it ever since I learned about it.
    Post edited by kyoto kid on
     Thanks for this as well.  I'm mainly doing male characters, so I'll have to check heights.
