DAZ Studio 6 and Plugins
With the release of DAZ Studio 6 will the Animate 2 and Anilip 2-3 Plugins be updated to use in this program? Cheers
«1
  • jmucchiellojmucchiello Posts: 2,531
    Your guess is as good as anyone's. No one was aware ds6 was coming out today.
  • mikael-aronssonmikael-aronsson Posts: 607
    Well, Tafi owns Anitmate2 now so anything is possible, but as far as I understand the idea is to integrate everything into the DAZ timeline so I don't think Animate2 itself will be updated, but that is a wild guess
  • Yeah the shadow drop of Daz Studio 6 was quite the surprise! I would like to know that as well. One can only hope!
  • RandWulfRandWulf Posts: 239
    Spent a great deal on plug-ins ovr the years -- would be quite a blow if they don't update them tp work in Studio 6...
  • Ghosty12Ghosty12 Posts: 2,093
    edited June 4
    Well I do know that BJ Camera Manager does not work. While it shows in the menu click on the tab / button does nothing and copying the .dll file into the Studio 6 plugins folder does not work. Also Ultrascenery XT and Ultrascenery 2 don't work, and DiM needs to be updated to take into account Studio 6's install location.
    Post edited by Ghosty12 on
  • bluejauntebluejaunte Posts: 2,293
    Ghosty12 said:
    Well I do know that BJ Camera Manager does not work. While it shows in the menu click on the tab / button does nothing and copying the .dll file into the Studio 6 plugins folder does not work. The bookmark manager works as does the EJ Camera addon as does a couple of others but in all so far only one plugin is problematic.
    I submitted DS6 versions of all my plugins today. Will appear in DIM at some point. Suspect it could be a while, probably a flood of plugins for QA to go through now.
  • LeanaLeana Posts: 13,630
    A plugin made for DS4 will not work with DS6, it needs to at least be recompiled with the DS6 SDK. Copying the DLL won't help.
    Scripts may or may not work as is depending on what they do.
  • LaPartitaLaPartita Posts: 418
    @bluejaunte - Thank you so much! It's good to know the updates are coming :-)
    ZERO Daz 4 plugins work in Daz 6 aside from the ones shipped with Daz. Every plugin maker has to release an update.
  • kprkpr Posts: 496
    Good on you smileyyes
  • Just a question. I've read that Gescon II works in DS 6, but it's not working. I assume like other plugins I'll just have to wait until it's updated? And I also assume that's true for all plugins except for the ones that came out yesterday and today. If that's true, then I'll just be patient and wait.
  • Ron KnightsRon Knights Posts: 2,791
    Will we be able to change the font size in the new DAZ Studio 6?!
    I thought I heard the new version of their "author" software would allow that change?
    Switching to a newer version of Qt was a requirement, but just the framework change is not enough to have that feature. It will likely be implemented in a future version.
    Yes, AFAIK only the Daz Original plugins already have a DS6 version released, we will need to wait for the others.
    Thanks! Oh well. :)
  • Richard HaseltineRichard Haseltine Posts: 111,922
    Daz bought KeyMate and GraphMate, as far as I know AniMate is still owned by the original developers.
  • brainmuffinbrainmuffin Posts: 1,332
    Your Camera Manager looks quite interesting.
    Ahh no worries thank you for the info. smiley
  • PadonePadone Posts: 4,369
    edited June 5
    So far it seems nobody cares about the bridges for DS6 ? Not a single user asked. Probably because people using the bridges don't care too much of DS being 4 or 6.
    Post edited by Padone on
  • jgeoffreyjgeoffrey Posts: 0
    Animate 2 is not available in Daz 6. Victoria on AI chat told me. Too bad I kind of liked Daz 6.
    Animte is not currently available, we don't know if it will be updated now that the SDK is available. Victoria is an AI chatbot, it isn't guaranteed to be right - and certainly isn't able to foretell the future.
    Well, that is a major flaw in Studio 6 -- I use Animate 2 quite often.  Will any of the other animation plugins, like Anilip 3, also be Studio 4 only for the foreseeable future?
    There are no PA made plugins available until the PAs rebuild them. Most will also require coding changes. So it will not happen quickly.
  • sidcarton1587sidcarton1587 Posts: 118
    Is the DAZ 6 SDK available yet? Wasn't showing up in Store or DIM for me.
    It is, and I have it in DIM. I am not sure why some people are not seeing it, assuming you can see the DS 4 SDK.
  • DallasRTDallasRT Posts: 20
    edited June 6
     I spent a lot of money on the daz products and I presume, hopefully it will update a lot of the scripts. None of the elf ears load plus many others. I refuse to spend more to be able to use this product. [My goodness] with the way a lot of us are having to manage our bottom line is going to effect DAZ. Money all ways talks.
  • barbultbarbult Posts: 27,652
    edited June 6
    A lot of plugins and scripts are made by PAs, not DAZ. The PAs, not DAZ, would have to update plugins and scripts for DS6. Some PAs are no longer in the 3D business. Some PAs have died. Remaining PAs may, or may not, be willing to do that work for free, to save your bottom line at the expense of their own. Unless you have purchased an NVIDIA 5000 series GPU, you have no need to abandon DS4 for DS6.
  • alan bard newcomeralan bard newcomer Posts: 2,431
    Is there any reason why DAZ does not recompile the scripts or do the fixes or hire someone to do it.
  • felisfelis Posts: 6,614
    Scripts and pluging made by PAs (and not sold to Daz) are the property of the PA. Daz is not allowed to change them.
    Besides it is often also needed to make changes in the code, to make it work under the new framework.
    Elf ears are unlikely to be scripts, let a lone plug-ins. Which elf ears, are they from a Daz  or other product, how were they installed and are they in the same content directory as your other, I assume working, content?
