How do you make Daz select objects
My Daz prgram has stopped manipulating items I click directly on, forcing me to use the  scene option which I find to be slow and inconvenient (complex scenes mean long and tedious searches to find the right item I can see right in front of me). I don't know why the program stopped allowing me to select items I click on directly anymore after all these years (I asssume I accidentally clicked on something I did not notice), and I have evidently long since forgotten how to fix this little problem. I know it is something minor but for the life of dopey me I cannot figure out what it is. sad
  • felisfelis Posts: 6,622
    If you look in the scene tab, in the S column, is there then a checkmark or an x? Must be checkmark for selectable.
    Which tool are you using?
  • Spacewarper7Spacewarper7 Posts: 198
    edited April 28
    Yes, I know what you are talking about; I have run i to that problem before too but immediately figured out the problem then and could fix it. But that is unfortunately not the problem I am having now, as nothing will select upon direct clicking (except thru the Sene tab, which is annoyiong) even though everything in my scene tab is checkmarked.
    I am afraid I I do not understand your question about tools. I am using Studo version 4.24 if that is what you mean. Thanks for the help.
  • LeanaLeana Posts: 13,631
    There's a toolbar above the viewport in DS where you can select various tools, like node selection, universal tool, surface selection, spot render...
    edited April 28
    The scene navigator icon is showing green unlike the others listed, so I am assuming that is the one I am on now. So which one *should* I be on? Dopey me hasn't got a clue. If I had to guess, it would the one it's already at, tbh.
    You want Node Selection or Universal Tool.
    edited April 28
    Silly me. Once I actually finished waking up, I realized I can just test each one out for myself until I hit the right one. Doing that isn't going to hurt anything, yes?
    Succeeded on the very first try, with node selecxion. What the heck is a node? Who cares? It worked, so thank you for giving me something to aim at! angel
    Post edited by Spacewarper7 on
    edited April 28
    Yes. Hehe. I found that out a bit later once I woke up enough again to actually think for myself. I made a later comment to follow up but I guess you missed seeing it when you posted this. Anyway, thank you again for your help. I appreciate it. wink
    Edit: Oh shoot, dopey me strikes again. It was I who missed seeing your comment; only noticed it just now. Yep. I'm a dope. I can see now how that looks too, like I claimed credit for your discovery. Oof! Not at all intended. Sorry about that!!! blush
    "Node" is a generic term to refer to all elements of the scene that you can position and manipulate, for example figures, figure bones, props, lights, cameras, groups, dformers, geometry shells, instances...
    The main difference between "node selection tool" and "universal tool" is that "node selection tool" simply selects the nodes in the viewport, while "universal tool" selects nodes and activates the transform gizmos to translate, rotate or scale the node directly in the viewport.
    I was just joking abiout not caring abut nodes. I was just glad I got the answer to fix my problem. Again, thank you very much. smiley
  • Richard HaseltineRichard Haseltine Posts: 111,935
    You can also see which tool is active by looking for the check mark in the Tools menu - which is more relable as not every tool will necessarily be on the tool bar.
    edited April 29
    Yes, but dopey me initially did not know to even do that as being related to the problem I was having at the time. As thery say, too little education is a dangerous thinbg. blush
  • jmucchiellojmucchiello Posts: 2,548
    Even better is the Tool Settings panel. As it will show you various ways to use the tool you many not have known about. :)
    edited April 29
    Lol. I don't even know enough to know how to use that, tbh. Perhaps I should take the time to check that out, and hope I can figure it out for myself when I do... though of course I have my doubts about that because when it comes to learning technical stuff I am often a hopeless moron. blush
