• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Problem to bake normal map using diffeomorphic and Xin's HD addon
bigoskar00bigoskar00 Posts: 36
April 14 edited April 14 in Blender Discussion
im trying to add some veins in the body of a figure from this product https://www.daz3d.com/add-some-veins-hd-for-genesis-8, thing is I dont want to use an HD mesh because the amount of polygons blow up into the millions and my computer struggles to manage all that so im trying to bake them into a normal map
Here comes the issue, when I bake using the bake maps feature that comes with diffeomorphic by default it does produce a set of normal maps but the normal maps are broken and are unusable, they have noticeable seems and end up affecting the colors so for example the face and the body have completly different colors and stuff like that
I tried to use Xin's HD addon to see if it would give me higher quality normal maps but every time I try to use it it throws the next error message
Python: Traceback (most recent call last):
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_common.py", line 59, in invoke
    return self.execute(context)
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_normal.py", line 634, in execute
    r = self.generate_maps_from_blender(context)
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_normal.py", line 571, in generate_maps_from_blender
    ub.set_scene()
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_normal.py", line 171, in set_scene
    self.unwind_settings(bake_settings, scn, self.saved_bake_settings)
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_normal.py", line 155, in unwind_settings
    cls.unwind_settings(v, obj2, d2[k])
  File "C:\Users\Dell\AppData\Roaming\Blender Foundation\Blender\5.1\extensions\user_default\daz_hd_morphs\operator_normal.py", line 157, in unwind_settings
    d2[k] = getattr(obj, k)
AttributeError: 'RenderSettings' object has no attribute 'use_bake_multires'
im kind of desperate since I have been trying to build normal maps for a while using the addon with little success and the normal blender way of baking them is useless since it completly kills my computer
Post edited by bigoskar00 on April 14
  • ThomasLarssonThomasLarsson Posts: 102
    April 14
    That is due to a API change in recent Blender versions. Try an older Blender version, e.g. 4.5, until Xin makes a fix.
  • bigoskar00bigoskar00 Posts: 36
    April 14
    Alright so that explains why Xin's addon doesnt work, thanks
    but what about the textures created by the HD mesh section of the base addon not working correctly? like the weird seams
  • PadonePadone Posts: 4,354
    April 15 edited April 17
    As for the seams, be sure to export HD uvs on the daz side, as baking doesn't work fine without. As for the materials, will have a look and let you know. Then some pictures of what you get may help to better understand the issue, instead of going blind.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2676/bake-maps
    update. I can confirm the seam bug, it is reported now with the fix. Also ATM it is better to use blender 4 to bake, as blender 5 is terribly slow, eventually we'll investigate that as well.
    update. Seams are fixed in the last commit, also baking works without HD uvs. Blender 5.1.1 is fast again.
    https://github.com/Diffeomorphic/import_daz
    Post edited by Padone on April 17
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
