Can't change hair color
omvendtomvendt Posts: 222
Hi, anyone else have this product
https://www.daz3d.com/dforce-strand-based-fe-shawl-long-hair-for-genesis-9
I can't change the hair color. I have checked that I am using G9 for hair and actor. The product has both materials and shaders, which I think is unusual. Mostly, it is just materials that you double click on, isn't it?
Hope you can help    (O:
  • felisfelis Posts: 6,593
    I don't have the hair.
    What does the log say, if you try to apply a material Help > Troubleshooting > View Log?
    You should be able to apply a shader (in reality shader preset), by having the object selected in the scene tab, and the surface(s) in the Surface tab, given the shader match.
  • jmucchiellojmucchiello Posts: 2,463
    edited January 3
    Are you trying to use the shaders that come with the product or external shaders? This is from the product in Content Library.
    1057 x 547 - 893K
    Post edited by jmucchiello on
  • crosswindcrosswind Posts: 10,344
    The material presets that come with the product are just used for changing non-color settings. You have to use Shader Presets within this product. Go to Surfaces pane, select all hair Surfaces, dbl-click a Shader Preset to apply the colors.
    edited January 4
    EDIT: the presets are also in content library. I used #48 "blue" in my post above:
    1508 x 875 - 1M
  • memcneil70memcneil70 Posts: 6,157
    I have been finding that I have to use the Spot Render camera to verify if my hair/makeup I thought I applied actually took. And yes, I have been known to forget to select my surfaces if I have been working in Materials and switched to Shaders. It is one of those smack my forehead into my keybord moments.
    edited January 4
    Yes, correct !
    In Surfaces pane, with hair surfaces selected, apply those presets that are marked as Shader in the upper-right corner of the thumbnails.
    2560 x 1392 - 1M
    Post edited by crosswind on
  • omvendtomvendt Posts: 222
    I feel dumb and happy that so many of you were willing to help.
    (O:
    It worked as advertized. Not sure why FE would make hair that works this way when all the other hair I have ever used (admittedly not for long) works in a simple click-and-you-are-done way
