Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeo Texture tiling?
DrGonzo62DrGonzo62 Posts: 423
December 2024 in Blender Discussion
Hi,
I've noticed that texture tiling doesn't seem to carry over from DAZ using Diffeo.
I can't find tiling parameters in either Cycles BSDF or Extended Principled imported materials, and the renders look accordingly with Blender not using the same texture tiling as DS does.
Is tiling data from DS not being imported into Blender?
Thanks!
  • PadonePadone Posts: 4,405
    December 2024
    Tiling is supported for the uber shader and the image editor, just tested with a simple cube and it works fine. You may want to give exact steps to reproduce the issue.
  • DrGonzo62DrGonzo62 Posts: 423
    December 2024
    Hi Padone,
    Thanks for looking into this!
    I'm using the Cafe Luca asset for this.
    I'm adding the DS export screen as well as the Blender import and the resulting shader screens. And two screens showing the renders from DS & Blender, where you can see the difference in floor tiling.
    Is there a way to export just that shader from Blender to post it here?
    I've fixed the issue by adding a Mapping node between the Texture Coordinate and the DIMG Woodflooring nodes and scaling it by 0.5% btw.
    1366 x 720 - 251K
    1066 x 724 - 195K
    1366 x 768 - 294K
    1280 x 720 - 174K
    1280 x 720 - 179K
    December 2024 edited December 2024
    The uv mapping is inside the DIMG group, but there's a bug because the conversion doesn't handle properly non-integer values, in this case 0.5 for tiling. I'll prepare a test scene and report to Thomas, thank you for pointing this out.
    update. Now reported to Thomas.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2315/
    update. Fixed in the last commit.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    Post edited by Padone on December 2024
    December 2024
    Good deal, thanks Padone!
  • ScarecrowScarecrow Posts: 199
    To add tiling to an image texture in blender you can add a mapping node in front of the image node in the shader editor, then adjust the scale settings. If you have the node wrangler addon enabled you can just select the node for your image then press control T. The mapping node will be added automatically.
    I have also noticed many textures do not have proper tiling when imported with diffeomorphic.
    Post edited by Scarecrow on December 2024
    December 2024
    Good to know, thanks!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
