G9 morph problem
Hello everyone,
I have a problem with the G9 morphs. The figure's thigh rates inwards. I don't know if I have changed anything, but it is the case with all figures. Can somebody give me advise?
Thanks.
Tom
(Image removed by mod. Please reupload with the figure untextured https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity)
Post edited by frank0314 on
  • crosswindcrosswind Posts: 10,357
    edited July 2024
    It's an issue comes from wrongly-dialed corrective morphs on G9... Go to Parameters pane, firstly Show Hidden Properties... from the "hamburger" menu in the upper left corner (Preferences). Then select Currently-Used, check if there's any unexpected corrective morphs (...cbs...) dialed...
    Post edited by crosswind on
  • Hi crosswind,
    Thank you. I tried this and the cause is a Charmaine Morph "em3dcharmine_body_cbs_shin_x155p_l".
    When I set it to zero, the figure looks normal again.
    The problem is every time I restart, the wrong Morph is back. I don't like g9 anymore ...
    Do you know a way how to fix it?
    Thanks in advance.
    Tom
    883 x 462 - 73K
  • GhostofMacbethGhostofMacbeth Posts: 1,781
    The easiest way is to uninstall Charmaine
    Well, it's because these corrective morphs have no 2nd Stage Controllers of Charmaine's Head / Body morphs (if you didn't dial them...). You can fix them one by one by adding Charmaine's Body Morph property to the 2nd Stage Controller of each corrective morph in Property Hierarchy... but that'll be a bit cumbersome ~
    Better send a ticket and uninstall the product in DIM for the time being.
  • okay, I will do it and wait for an update.
    Thank you!
