A forest...
Cyklone
in The Commons
Hi everybody,
I'm looking for a forest with the same look and athmospere as on the attached image...
Any ideas or suggestions would be greatly appreciated !
In advance, thank you for your help !
Cheers !
1600 x 1600 - 204K
Ultra scenery will give you the path and the trees, but you will have to find a night time hdri. And there are plenty of fog options out there.
https://www.daz3d.com/ultrascenery--realistic-landscape-system
https://www.daz3d.com/ultrascenery--pines
Do you own Carrara ? - Stoney Creek Beechdale - https://www.daz3d.com/stoney-creek-beechdale
Thanks guys for these precious infos.
Nope, I don't have Carrara, I've been thinking about getting it since a while though...
I quiet like the mystical forest....I'm gonna try with this one.
Thanks !!
Cheers !!
Actually I have found just the perfect one, in the Ultrascenary series : https://www.daz3d.com/ultrascenery--tropics
This setting is simply perfect : https://gcdn.daz3d.com/p/86979/i/ultrascenerytropics04daz3d.jpg
Just need to add a moody mysty dark weather and it should be just fine !!^^
Make sure you understand UltraScenery though! To use that set you chose, you need the main program. And there is a speed booster that makes everything so much more amazing! You may want to see some of the images and info in this thread if you are going to begin a journey with UltraScenery. It is AMAZING, but there is a bit more to it than first meets the eye. There are some tutorials in the store, and it looks like everything is on sale, so a good time to dive in!
