DS Format Products That Import To Carrara. Or Not.
I've had mixed luck with DAZ products in DS format importing to Carrara.  Some work well, maybe without the lights, but certainly useable.  Others don't show any geometry at all.  I dunno why.  This is a first pass, I'll add more as I test. I'm sure someone will point out  what I'm missing, if anything.  Anyway ...
Products that work:
Toymaker Workshop
Steampunk Helicopter (Can't Move Parts)
Victorian Medical Equipment
Toilet Paper On Floor
Do Not Work:
Library Bluson
Police Station Interior
Detective Room
Cyberpunk Launderette
Security Gatehouse
  • StezzaStezza Posts: 9,212
    lots of DS products use instances and emitters
    Carrara equivalents are replicators and glow channels
    usually all the textures have to be adjusted, UV mapping unticked ect...
    for opening and closing stuff you need to do manually not by the sliders or the product needs to be changed to blended weight. surprise
    and some products no matter what you do just won't work.. like the curiosity mars rover. frown
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,505
    edited November 2023
    if all else fails I export obj from DAZ studio
    I have Totte's plugin too https://www.daz3d.com/instances-to-objects
  • Bunyip02Bunyip02 Posts: 9,342
    Products that work:
    Steampunk Helicopter (Can't Move Parts) - Converted to blended weight in DAZ Studio, saved as Scene Subset, was able to rotate rotors when opened in Carrara
    Do Not Work:
    Security Gatehouse - opened in Carrara, tried Blended Weight conversion in DAZ Studio, movement morphs still not working in Carrara. As Wendy said export as obj from DAZ Studio
    those Aurelio NY sets remain my bane in Carrara
    load perfectly won't save
    I have at least found a workaround for the obj exports exploding
    select and parent everything in place to a null (not keeping hierachy) the problem is they have mixed parenting
    look in this thread for a better idea of what works in Carrara and how to fix what doesn't
    https://www.daz3d.com/forums/discussion/8916/buy-something-that-doesn-t-work-in-carrara-post-your-questions-and-workarounds-here-please#latest
  • Steve KSteve K Posts: 3,535
    All good points, thanks.
    Disappointing, those sets are great.
