• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
OBJ export/import settings?
liugiaducaleliugiaducale Posts: 10
March 2023 in Blender Discussion
This is probably really simple, but I can't seem to find a quick, straightforward answer to my issue.
So, I'm trying to import some clothing from a game character into daz, I've already edited them to fit around the figure I need it for - but whenever I export it from blender as an OBJ and then import it into daz, the item is at a different angle/position than where it was in blender (usually laying horizontal, turned 180 degrees and also mirrored). It hasn't been an issue when I needed to simply import item files for a quick prop as I could just move them where I needed, but even with moving the item in its rightful position on the model when operating transfer utility it gets reversed to its original position and it messes with the rigging. So, what are the blender export/daz import settings supposed to look like for it to port in the right place?
  • felisfelis Posts: 6,546
    March 2023
    When you import something to Daz Studio for use of transfer rigging, it must default be in the right position, orientation and scale.
    And there is a difference between blender and daz studio.
    Blender has units in meter an DS has it in cm.
    In blender Z is up, in DS Z is depth.
    It doesn't matter if you change the orientation when exporting from blender or when importing to DS, as long as it load correctly in DS.
    I use DS orientation (forward -Z, up Y) and blender scale for my obj files.
  • Richard HaseltineRichard Haseltine Posts: 111,676
    March 2023
    Find a combo that works and then use the Save Preset button - you can then use the saem options, correctly inverted, for Import/Export/Morph Loader just by selecting the preset.
  • PadonePadone Posts: 4,347
    March 2023 edited March 2023
    The blender export settings below work fine to import in daz studio a 100% scale with default axes. That means blender does the conversion and daz studio does nothing. The absolute path means you can share textures and move the object around in a project folder, that's what you usually do when working with a asset library.
    To export materials you have to use the principled node in blender. The conversion is limited to basic attributes as diffuse and specularity.
    Be sure that everything you export is uv mapped because daz studio can't import geometry without a uv map.
    231 x 370 - 27K
    Post edited by Padone on March 2023
  • stem_athomestem_athome Posts: 526
    April 2023
    Is the version of DS you are using broken? I have never had an issue importing geometry without UV.
    If needed you can apply UV projection via "Shader mixer -> Coordinate Projection" and project texture map onto object using world/object space
    April 2023
    You are right, with 4.21 I can import objects without uv map. I remembered this limitation from old versions and didn't check.
    April 2023
    It has always (or at least long) been possible to import an unmapped object - hence the need to ask if the item is mapped when people cannot apply maps.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
