bicep peak for Genesis character
are there any morphs that will give a peak to the upper arms?
  • Noah LGPNoah LGP Posts: 2,617
    edited January 2023
    Do you mean like Lord of the Abyss ?
    Post edited by Noah LGP on
  • Drogo NazhurDrogo Nazhur Posts: 1,340
    edited January 2023
    Referring to the attached image starting on the left :
    The first image is a bitmap drawing and the bicep has a peak
    The second image is Genesis (Genesis 1) -- notice that compared with the other images, the bicep does not have a peak
    The third image is Genesis 2, again the bicep has a peak
    The last character is Genesis 8 and it also has a peak.
    Post edited by Drogo Nazhur on
  • felisfelis Posts: 6,504
    I don't see any attached images?!
  • arne207arne207 Posts: 165
    edited January 2023
    Genesis 9 seems like a step backwards in that regard, G8 and 8.1 were advertised as improvements in terms of muscle contraction. What is needed here is a muscle morph pack, and so far there isn't any. We'll have to see what turns up eventually, especially since apparently there are Ivar 9 and Freja 9 characters on the way that will probably be pretty beefy.
    Right now you can either try post-render work with something like Photoshop or mess around with ManFridays Mesh Grabber tool -> https://www.daz3d.com/mesh-grabber-win
    Post edited by arne207 on
  • Lee MoonLee Moon Posts: 935
    edited January 2023
    I've tinkered with this a little on Genesis 9.
    Here's a sample and parameter dials screenshot where I set the parameter dial limits to 300% on the main automatic flexion controller dial and on the bicep flex dials.  That made a marked difference in bicep flexing.  Haven't played around with the other flex dials much, but probably works the same if needed.
    Lee
    EDIT: Finally got images to upload. Yay! :)
    967 x 1251 - 374K
    4064 x 2696 - 1M
    Post edited by Lee Moon on
    Lee
    Forum not allowing image uploading of my samples.  Will edit this post when it works. :)
    Look forward to seeing your pics, but that's a great idea. I might have to experiment with that a bit. Thanks for that.
    Muscle morph packs or Swole characters, one recently $2.99, can do that. Also several G8 characters like the Brute should work.
    Lee
    Leemoon, thx for that tip on the G9 platform, I have been trying and failing on making some believable morph packs for that platform.  TD
    RenderPretender and Terry, you are most welcome.  I hope it's of some use.  I haven't really messed around with it as much as I'd like.  It's far easier to work with G8/8.1 due to the variety of add-ons. :)
    Also, I've updated my earlier post with the images now that the forum is letting me upload again. :)
    Lee
    edited January 2023
    For Genesis 9 ?
    For Genesis. Genesis 1
    Before Genesis 9. Before Genesis 8.1. Before Genesis 8. Before Genesis 3. Before Genesis 2. The FIRST Genesis.
     LOL!  My fave Genesis!  RamWorks came out with an enhancement set of morphs for Genesis, and one slider is bicep bulge.  That might do what you want, assuming you have all the other potential sets.
    https://web.archive.org/web/20130329030413/http://www.ramwolffsworld.com/3D_Directory/Packs/RAMWorksMorphsGenesis.zip
    edited January 2023
    https://www.daz3d.com/genesis-evolution-muscularity and https://www.daz3d.com/genesis-evolution-body-morphs
    The Muscularity product has the following morphs:Biceps, Biceps Flex Left, and Biceps Flex Right.
    Adding to that, the Body Morphs product has the Fitness Details and Fitness morphs which add more punch to the biceps (as well as the rest of the body.)
    This is for Genesis 1 - not any of the other Genesis variants.
    Lee
    4064 x 2696 - 433K
    edited January 2023
    Lee
    I purchased the morphs that you recommended. Thank you.Not as good as G2M (middle below) or G8M (below right) but better than what I had before. Thanks again.
    EDITTED TO SAY: The forum attach feature appears to be broken so I can't show you but you can see it here --> https://www.deviantart.com/dim35/art/RL-me-with-different-versions-of-the-software-944739783
  • vonHobovonHobo Posts: 1,715
    edited January 2023
    This one is really good for Genesis 8. It's the best as far as being very customizable:
    https://www.daz3d.com/musculature-hd-morphs-for-genesis-8-male
    This one is awesome too, very realistic, and much easier to use in my experience:
    https://www.daz3d.com/auto-muscle-enhancer-hd-for-genesis-8-males
    There is one more I tried which is really incredible, but it's mostly for the SWOLE character:
    https://www.daz3d.com/swole-for-genesis-8-male-fibo--advanced-muscle-deformation
    Note: I have not tried any of these on Genesis 9 and I don't know if they would work. They were all designed for Genesis 8.
    I have not seen anything for Genesis, but I started with Genesis 8 when I started using DAZ.
    For realistic muscle contractions, I personally would upgrade to Genesis 8 because there are a lot of products for muscle enhancement, both male and female. And the realism is amazing to me!
    I had fiddled around with Poser and Genesis, then with Genesis 2 and pretty much gave up, until Genesis 8 came along and that really knocked my socks off! But I know that if you have invested a lot in a previous generation (time and or money), you may not want to switch. I am not purchasing anything for Genesis 9 for that reason. Personally, I just can't afford to purchase all new content at this time.
    Good luck!
    Post edited by vonHobo on
  • RawArtRawArt Posts: 6,216
    edited January 2023
    Post edited by RawArt on
    Good luck!
    I have ESTABLISHED characters in every generation. Moving them forward is difficult because my followers are use to a ceetain look.
  • TimbalesTimbales Posts: 2,451
    You've probably already tried it, but you might get enough of a tweak to the bicep you're looking for using the deformer tool.
  • Faeryl WomynFaeryl Womyn Posts: 3,777
    Was that a free or paid pack back then cause that's a direct download link.
    Deformer tool? Link, please.
    Big yes, I noticed that too, default mesh on G8M/F’s arms seem to have minimum human muscle retraction that respect human anatomy, with great 3rd party support products over the years, it's close to perfection (only if AME female version did release) but G9 mesh just totally ignored the human muscle retraction altogether, big reason I'm not very into G9 at its current state
    To OP, forum user terry_duquette just uploaded an extremely useful tool (currently free) that enchance the bicep morph for G8F, you will get that realistic bump and split, that's the best solution I found so far for G8F, highly recommanded
    Here https://www.daz3d.com/forums/discussion/607446/free-flexion-enhancement-for-g8-8-1f-also-swm-flex-vein-control#latest
    For Male, you will have to use AME, most realistic G8M muscle morph https://www.daz3d.com/auto-muscle-enhancer-hd-for-genesis-8-males
    Other way to do realistic G8F bicep morph is to use G8M as base than use transgender tool and abrunch normal map turn him into G8F's likeness.
    2879 x 2399 - 3M
