System 50 for Genesis 3 Female(s) problem
i see rivtets not in there place [in System 50 for Genesis 3 Female(s)] i want to know what is the fix
Edited for Please put your question in the post body and the title - Daz 3D Forums and moved to technical Help as it is a question about an existing product, not a suggestion for or search for a product that may not yet exist.
This, I assume https://www.daz3d.com/system-50-for-genesis-3-female-s ? What do you mean - missign elements, or elements thata re theer but not correctly positioned? Are you usign the character shape, a zeroed figure, or another shape?
not correctly placed
You need to provide more information. Richard asked you more questions. You could provide a screenshot. Just remember no nudity, if that is the case. https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
According to the produict page the rivets are a Geometry Shell, if you select the shell, open the Surfaces pane, and in the Editor tab select the legs surface what UV Set is being used? How about on the legs of the base figure?
it's g3f i just downloaded it then right away used it
You mean the UV Sets are both Genesis 3 Female?
