Rendering DAZ Studio from AMD GPU
serifgen123serifgen123 Posts: 0
edited April 2021 in Daz Studio Discussion
Hello, I want to render from DAZ Studio via AMD GPU. How can I do? I wrote from Google translate.
Post edited by Chohole on
  • LeanaLeana Posts: 13,375
    AMD GPU are not supported by either Iray or 3DL, you can only render with your CPU.
  • MartirillaMartirilla Posts: 191
    You could do it, but only if you were prepared to forget all about Iray, and instead only render by using the Reality plugin.
  • PadonePadone Posts: 4,222
    edited April 2021
    https://www.daz3d.com/reality-4-daz-studio-edition
    As for 3Delight it's cpu based so it doesn't support any gpu.
    Post edited by Padone on
  • nicsttnicstt Posts: 11,715
    Use Blender.
    I use blender for some of my renders and I use Nvidia. If I only had AMD, then I would be doing all my renders there.
    edited April 2021
    Nicstt means this, but of course this way you will not render from daz studio. As a side note luxrender is much better than cycles as for pbr quality, especially with caustics.
    http://diffeomorphic.blogspot.com/p/daz-importer-version-15.html
  • RobinsonRobinson Posts: 751
    nicstt said:
    Use Blender.
     Sounds like a lot of work to do things like setting up materials if you do it that way?
    @Robinson Not at all, diffeo does a very good conversion of materials. And of course you get all the benefits of blender such as eevee and simulations. But may be this is a little off topic for what it is asked here. If you're interested there's a whole blender forum.
    https://www.daz3d.com/forums/categories/blender-discussion
  • mindsongmindsong Posts: 1,769
    Does not DAZ Studio's IRAY also work with CPUs and system memory, albiet slower?
    I've been curious how a mega-rigged AMD-Pro system would perform with IRAY.
    --ms
    --ms
     https://www.daz3d.com/forums/discussion/341041/daz-studio-iray-rendering-hardware-benchmarking/p1
    edited April 2021
    --ms
    brilliant reference. thanks for that link - I haven't been in the market for decent H/W for quite a while so following the benchmarks/trends hasn't been particularly interesting - if not downright depressing, relative to my current equipment, heh!
    (to the OP's question, it appears to be a question of performance rather than capability.)
    tnx,
    --ms
    Post edited by mindsong on
    Robinson said:
    nicstt said:
    Use Blender.
    Not at all.
    There is a learning curve, but once learnt, 5-10 minutes to get things over and rendering.
