Fibermesh eyebrows
Hey Richard (Haseltine),
a simple question. In my new product I’m using fibermesh eyebrows. Question is, what is the procedure to conform eyebrows on the face to auto follow? Thanks
Dax Avalange
  • Dax AvalangeDax Avalange Posts: 342
    edited November 2020
    I'm using Figure Setup to make a rigging to G8F then transfer utility. Seems to work perfectly. If there's a different technique it's good as well! yes
    Post edited by Dax Avalange on
  • I'm not aware of any special technique for fibremesh items.
    So the technique I'm doing is the only one right then?
  • Actually I think you are over-complicating it - why are you using Figure Setup before using the Transfer Utility?
    Simple, because if I export the fibermesh obj,import in Daz and use transfer utility it conforms the eyebrows not in the right position, means over the head. If I use the Figure Setup I set eyebrows in the right position placing the bones in the face over the eyes, in few words eyebrow arch. Then, conforming with Transfer Utility, eyebrows match the head! yes
  • It works perfectly! yes
  • LeanaLeana Posts: 13,572
    Are they in the right position when you load the obj?
    What PA I would be, if I place eyebrows into knees instead face?  Loool! Joke! laugh
    Fact is that using Figure Setup it's fantastically locked into the face and any pose I set, eyebrows follow the face expression in any movement! yes
