Fibermesh eyebrows
Dax Avalange
Hey Richard (Haseltine),
a simple question. In my new product I’m using fibermesh eyebrows. Question is, what is the procedure to conform eyebrows on the face to auto follow? Thanks
Dax Avalange
I'm using Figure Setup to make a rigging to G8F then transfer utility. Seems to work perfectly. If there's a different technique it's good as well!
I'm not aware of any special technique for fibremesh items.
So the technique I'm doing is the only one right then?
Actually I think you are over-complicating it - why are you using Figure Setup before using the Transfer Utility?
Simple, because if I export the fibermesh obj,import in Daz and use transfer utility it conforms the eyebrows not in the right position, means over the head. If I use the Figure Setup I set eyebrows in the right position placing the bones in the face over the eyes, in few words eyebrow arch. Then, conforming with Transfer Utility, eyebrows match the head!
It works perfectly!
Are they in the right position when you load the obj?
What PA I would be, if I place eyebrows into knees instead face? Loool! Joke!
Fact is that using Figure Setup it's fantastically locked into the face and any pose I set, eyebrows follow the face expression in any movement!
