Water props not wavy in DAZ 4.12
HeraHera Posts: 1,970
I tried to use the water props that come for instance in Lakeside Folly https://www.daz3d.com/lakeside-folly and Escape https://www.daz3d.com/escape in DAZ 4.12. Only to note that the water is not wavy anymore in DAZ 4.12, it only renders as an even surface, like a large, shiny floor.
In DAZ 4.10 it still works fine.
Is that a known error? And if so, is there a plan for fix it? And is there another kind of water prop that works in DAZ 4.12?
  • SevrinSevrin Posts: 6,314
    I don't own those products, but I just checked a couple I do have and they seem okay?  This is from Cave Island.
    1920 x 1080 - 581K
    What usually makes them wavy is the normal map, so i'd check to see if there is one first.
  • hacsarthacsart Posts: 2,037
    edited May 2020
    Hmm.  a test shows the OP is correct.. Looking at the surfaces, I see no normal maps, but the 3dl surface has "lacunarity" and "octaves" settings, which control the amount and size of the waviness... The Iray material has no nornal map, either..
    Stock scenes -
    Iray:
    3DL:
    1000 x 1300 - 510K
    1000 x 1300 - 635K
    Post edited by hacsart on
  • dawnbladedawnblade Posts: 1,723
    I have Escape and just tested it, and the OP is correct, the water is not wavy at all. There are user parameter settings in the surfaces tab, and I changed several but it didn't help.
  • alex86firealex86fire Posts: 1,130
    This doesn't seem to be a Daz problem.
    It seems to be a problem with the product itself. The iray material doesn't seem to be set up the right way.
  • NorthOf45NorthOf45 Posts: 5,896
    These are not standard shaders for either version. The 3DL version works okay, but the Iray version might have been broken with the Iray update that was used for the recent update to Studio. Maybe someone with 4.11 or 4.12.0.86 could verify...?
  • barbultbarbult Posts: 27,497
    DS 4.12 changed and deleted some MDL bricks (according to the change log) because of changes in Nvidia Iray. That could affect custom Iray shaders. Maybe this product's custom shader relied on one of those bricks. I imagine we'll start to identify other custom shaders that no longer work with the 4.12 update.
    Submit a help request. Probably the only way to fix it is to have the artist rebuild the shader for 4.12.
  • glaseyeglaseye Posts: 1,312
    edited May 2020
    4.12.086 also does not render Lakeside Folly correctly in Iray on my sysstem.
    Post edited by glaseye on
    edited May 2020
    hmmm, 4.11.0.231beta also doesn't render correctly in iray.... so it's not the result from a recent change. 4.10.0.123beta did render it correctly as far as i can tell. added 2 images: 4.10.0.123beta and 4.12.0.86 (not beta)
    edit to add; filed a support ticket for this. Now just wait and see if there's something that can/will be done.....
    1000 x 1300 - 547K
    1000 x 1300 - 512K
    The shader problems were addressed with a recent public (beta) build.   Try downloading the beta alongside your regular release and see if the issue persists.
    Are you sure? There has only been one beta release since the 4.12.1.117 release version. That is 4.12.2.6.  The change log says nothing about shader changes in 4.12.2.6.
  • xyer0xyer0 Posts: 6,505
    Daz tech support? Wait for it...
  • HeraHera Posts: 1,970
    Where do I find that beta?
  • TaozTaoz Posts: 10,345
    edited May 2020
    AFAIK it can only be installed with DIM (which will always list the latest beta under Updates (your DIM settings must be set to show DS Public Builds I think)). This will overwrite any previous beta version installed, so if you want the option to revert back, you should save the installer files for the currently installed beta first (are in the DIM Downloads folder).
    Post edited by Taoz on
