Error on startup
Try as I might, I have searched the forum and not found the answer Im hoping to get.
Ive install Daz 4.10 using DIM, excitedly fired it up, only to recieve a fatal error message before the software has initialised. It seems its not an uncommon issue?.
Ive spent two solid days trying to nut this out- I can run it on my 3 year old laptop just fine but not my brand new custom built machine using a Geforce GTX 1050
I know enough to be dangerous, but not enough to be useful with this kind of stuff, is the only answer to this issue to delete the system file? (Im reluctant to do that) Ive got GPU-Z running so I can see my GPU is definitely in use. Ive been into the system settings to force Daz to use the GTX 1050 and still no luck.
Does any other kind soul have any suggestions?
Is there any detail in the error message? What security software are you using?
Hey there
Here is the error log, and the error message
I am using Avaast anti virus on all of my machines. :-)
I have done a bit of research on the error and It seems to be related to Intel? I have tried uninstalling Daz, updating drivers on my 1050 (which may also have been a mistake) reinstalling Daz without DIM, nothing seems to make a difference.
I also have a ticket lodged with Daz but I am not sure its actually a Daz issue...
See this thread.
https://www.daz3d.com/forums/discussion/243216/getting-a-fatal-error-on-launch-solved
@Darksapphire
Avast is not your friend.
What do you use? Perhaps I should look at removing that and having another attempt at installing Daz.
Thanks Fishtales, yes I did have a good read of that, Was hoping I didnt have to resort to deleting files, I have tried forcing my GPU to launch using Daz and it made no difference. Regardless. This may be the only option I have left. Thank you!
