Exporting instanced geometry
Doc Acme
The other night, I happened across a utility for a product that I've had for awhile, that I knew had to exist but couldn't find. Anyway, it's for "The Streets of The Wild West" to turn visibility on for instances; a .dsa file so assuming a script. It does what it says anyway.
I've tried exporting the entire scene out as FBX and OBJ, but in each case no instanced geometry gets created, just the primary shapes. Bringing files into Lightwave. Looked at results with PolyTrans too and nothing there either.
Is there some prep step I need to do prior, like baking them or such?
https://www.daz3d.com/instances-to-objects
Excellent. Thanks. Never saw that before.
M.
Where do I find the script in the UI to run it? Ah, found it. Didn't reallize Totte - Code 66 was the vendor.
